Cmi inc intoxilyzer 300
E1 error then shuts off
Javelin cs 300 shows e1 error when subtotal.can u help
Javelins are very rare. I have worked on the low end model but not the 300. You might need to get a manual. C-tech has it:
https://the-checkout-tech.com/manuals/cashregisters/Javelin1.php
Jan 08, 2017 | Retail Supplies
Has error e1
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem.
Air Conditioning Inc
Apr 06, 2015 | Heating & Cooling
ERROR CODE 400 ON MPC 2050/2020
No.
Type
Details (Symptom, Possible Cause, Troubleshooting Procedures)
The machine detects a High signal from the drum motor: CMY for 2 seconds after
the drum motor: CMY turned on.
• Overload on the drum motor: CMY
• Defective drum motor: CMY
• Defective harness
• Shorted 24 V fuse on the PSU
• Defective interlock system
1. Check or replace the harness.
2. Check if torque output value for drum motor is proper if not replace the unit.
3. Replace the drum motor: CMY.
4. Replace the 24V fuse on the PSU.
SC4xx: Image Processing - 2
No.
Type
400
D
ID sensor adjustment error
When the Vsg error counter reaches "3", the machine detects "SC400".
The Vsg error counter counts "1" when the Vsg detected by ID sensor is more than
the value (default: 4.5V) specified with SP3324-005 or less than the value (default:
3.5V) specified with SP3324-006.
• Dirty or defective ID sensor
• ID sensor detection surface dirty
1. Check the harness of the ID sensor.
2. Clean or replace the ID sensor.
• After replacing the ID sensor, input the ID sensor correction coefficient
with SP3362-013 and -016. For details, refer to "ID sensor board" in the
Replacement and Adjustment section.
3.
Check the spring at the PTR unit contact lever. (See "PTR Unit Contact Motor"
in the chapter "Replacement and Adjustment".)
4. Replace the BCU
Oct 31, 2013 | Ricoh Office Equipment & Supplies
I have model 665 95154 300 I am trying to clean the oven I push clean oven and I get a code E1-F5 what should I do now?
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.)(*YIHJ
Jul 03, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
Ricoh CL2000N Error SC441
It means the PCU (CMY) motor error.
Try removing and reinserting properly the CMY PCU drum or replace it with a new one.
Jan 08, 2009 | Ricoh Aficio CL2000N Laser Printer
Oven will not turn on. Kenmoore Model # 66592142300
That is the control board and sensor error code. One or both of those items is malfunctioning. A new sensor is about $5-10 and a new board is around $150-300. You'll need a volt meter to check the functionality of the sensor and i can walk you through it if you like.
Dec 28, 2008 | Kenmore 96422 / 96424 / 96429 Electric...
I constantly got E1 Error code on my Kenmore Elite H3 GAS dryer
E1 error code indicates an open thermistor or open thermistor circuit. A thermistor is a component that relays the temperature in the dryer to the control board. If the thermistor has failed, Error code E1 will be displayed.
You need to call a repair person to fix it.
Dec 18, 2008 | Kenmore Elite HE4 Electric Dryer
SC 441
Hi there the following is the description from the service manual hope this helps you Thanks J
441 PCU (CMY) motor error
The drive motor of the CMY
PCU is not locked.
• Defective gear
• Voltage between pins 2 and 14 (CN12 on engine
control board) abnormal (not +24V), or pin 12
(CN12 on engine control board) unable to send
motor clock
• Defective CMY PCU drive motor
1. Replace the CMY PCU.
2. Replace the engine control board.
3. Replace the main drive unit assembly.
I would try replacing the CMY PCU (Drums (Photo Conductor Units) first before any of the others.
Thanks J
Jan 06, 2008 | Ricoh Aficio CL2000 Laser Printer
Heating & Cooling Logo
165 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
