Question about Panasonic Microwave Ovens
NNSN7898 My microwave oven (Panasonic Inverter) will not warm the food. The number H98 keeps popping up on the screen. The timer works for the amount of time that I want but the number H98 pops up and the food is cold. Thanks!
SOURCE: PANASONIC INVERTER MICROWAVE, 1300 WATTS
  1. Same exact problem
  2. I've noted 3 different ones with the same problem
  3. Panasonic has produced a lemon, north fixing
Posted on Apr 11, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: panasonic inverter
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 01, 2008
bestdarngood
  • 3037 Answers
SOURCE: My Panasonic Microwave Genius 1300W will not heat
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on May 26, 2009
localwonder
  • 6784 Answers
SOURCE: Microwave seems to be operating but does not heat food. Popping sound was heard just prior to this problem. Popping sound no longer heard but still does not heat food.
Replacing the Magnetron will fix this heating issue you are having with this microwave. The Magnetron is the device that is responsible for the heating action.
Posted on Jun 03, 2009
SOURCE: need a manual for a panasonic inverter combi
my microwave is saying h98 what does that mean. it's a panasonic inverter.
Posted on Aug 20, 2009
Code H98
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
You can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
You can order Panasonic parts & accessories from Encompass here or you can call them toll-free at 866-779-5835.
Nov 30, 2013 | Panasonic Genius Prestige Inverter...
Our microwaze is shutting off after ~25sec saying H98
Your microwave generation system has failed and Panasonic recommends that you get it serviced by a qualified tech. Hope it is under warranty!
Sep 14, 2012 | Panasonic Genius Prestige Nnsd997s...
Model NN-ST659W works for about 30 seconds then displays H98 on the display panel how do I fix this problem
May 31, 2012 | Microwave Ovens
Error code H98
Hello
Unplug the microwave and plug it back in after 30 seconds to make sure the message did not appear because of a simple glitch. If it does not come up again, use the microwave as normal.
The "H98" error means that the microwave's inverter has shorted out and does not work any more. The microwave cannot transfer power to create heat, and the part has malfunctions and requires replacement. Use your microwave serial number and customer service to find the proper part for the microwave.
Your microwave comes with a warranty that will cover the inverter if the warranty is still valid. Call the number for the warranty department or bring the microwave, with receipt, back to the store you purchased it from. This will save you the hassle of replacing the par
Oct 04, 2011 | Panasonic NN-SD797S Microwave Oven
When I go to use the microwave h98 shows up on the screen and does not work it is the 1.6 cubic panosonic microwave with inverter technology
f it is displaying error h98, this generally means that the inverter(power supply Panasonic part number: Z606YM300BP,) is not functioning. The magnetron may also be faulty.
The microwave may also have a faulty magnetron. If you are unsure, then you should get someone to look at the unit for you before you go buying parts.
An inverter microwave oven is one without a high voltage transformer You will know you have one as it is not extremely heavy at one end. This type of microwave uses a high power DC converter, called an inverter, to produce the high voltage and filament voltage required by the magnetron.
If you purchase this item for replacement in your microwave then we recommend that you do this only if you are qualified and aware of the dangers of tampering with electrical equipment.
Failure of the magnetron is common and at times the inverter can fail as well. Sometimes the inverter fails on it's own. If your microwave blows the 10 amp mains input fuse as the cooking cycle starts then you probably need a new inverter. An instruction sheet with basic guidelines on fitting will be provided but please do not purchase this item unless you are confident about fitting it. We only accept returns if the inverter supplied is defective which is extremely unlikely.
If you have one of these ovens that is not cooking then it is worthwhile looking at the magnetron. It often shows signs of distress through overheating.
Dec 27, 2010 | Panasonic NN-SN657SMicrowave Oven
What does H98 mean on the display of the microwave screen?
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In Canada, you can find an authorized Panasonic servicer here.
Dec 26, 2009 | Panasonic NN-SD797S Microwave Oven
Microwave will not work...display reads H98
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Dec 14, 2009 | Panasonic Microwave Ovens
Need a manual for a panasonic inverter combi microwave oven model number NNA514A
Aug 05, 2009 | Panasonic Microwave Ovens
Error code h98 when trying to use either the timer or to cook.
Aug 23, 2008 | Panasonic Microwave Ovens
MESSAGE DISPLAY H98
The H98 fault on a Panasonic can be a bad magnetron, inverter or control panel.
Jun 27, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
