Question about Savage Arms Savage AXIS XP Camo 223
Unjam instructions bolt won't open, live round in gun
    Problem Solver:
  • 7 Answers
Check safety
Posted on Nov 26, 2014
I shoot my 30-06 Remington an now the trigger an the bolt is stuck
1) If the round did not discharge, you must take this to a qualified gunsmith as the riffle could discharge when manipulating the bolt, safety, trigger, or due to mechanical shock. Make sure you transport the rifle with the muzzle pointed at something that can stop the bullet - consider a sandbag, phone books or several pieces of wood. Do not carry it in to the shop, ask them to come out and assess the gun
2) If the round discharged, do the following:
Empty the clip
Point the gun towards a safe location
try pushing the bolt forward and then rotating the bolt, once it moves do not put any forward or back pressure on the bolt
Failing that, repeat the process with the trigger pulled
IF THERE IS A LIVE ROUND IN THE CHAMBER YOU COULD GET A BLOWBACK SO DO NOT DO THIS IF THE ROUND IN THE CHAMGER DID NOT DISCHARGE
Failing that, remove the trigger assembly if you know how
I highly recommend going to a gunsmith as the gun is not longer trustworthy once the bolt tangs are in question
If you want to see the results - look up blowback - think the entire bolt going through your eye and out the side of your head - seriously - bolt failures are extremely dangerous.
Nov 16, 2014 | Garden
Gun won't sync on 2013 cabelas dangerous hunts
Good game equipment can help you solve this problem, a good gun model controller can let you enjoy a live-action version
Dec 06, 2012 | Activision Cabela's Dangerous Hunts 2011...
Gun is full of nails, but acts like it is empty (the plunger won't advance). You go to tap it with the trigger pulled, and it just does nothing. Seems like firing pin is not getting air or somet
If no air is leaking from the gun, take out the nails, remove trigger by removing 3mm hex head bolt to expose the trigger pin. With air connected and side door open so that you can see the feeder, quickly depress the trigger pin with finger. Gun should fire. If gun does not fire (only makes air sound at trigger) dissconnect airline, remove head and lube headvalve with white grease and reinstall. Test again. If ok replace trigger. If still no joy, replace trigger valve with new factory or generic (part # TVA6). If gun fires but does not activate the feeder claw, remove two 6mm hex bolts from front of gun and split apart upper and lower body and check white oring (part # 149885) Good luck
Oct 16, 2012 | Stanley Bostitch Rn461 Gun Coil Roofing...
My framing nail gun won't fire when trigger is squeezed air leaks out but won't fire
Time for oring kit # d518005 available at Dewalt service center or at www.toolpartsdirect.com.
May as well order the replacement trigger valve while there. These two items will renew your gun. Good luck
Sep 16, 2011 | Dewalt Round Head Framing Nailer D51845
Can't remove right front caliper bolt to replace brake pads on 1984 toyota pickup deluxe king cab 22re, now the bolt is striped, broke the 17mm open end wrench also try to hit the sock wrench with...
Might want to get it all buttoned back up and head to a shop. Maybe even call first. Ask if they can use an impact gun to break it loose for you and hand tighten it so you can get back home. A good mechanic should even have tools that will grip a rounded bolt head.
This is a type of good friendly service I would provide to people (until they abused my kindness and mistook it for weakness).
Sep 05, 2011 | 1984 Toyota Pickup Deluxe
Blows air out the top of gun won,t pressurize to shoot a nail and can't get screw out of directional air port to inspect
getting that screw out isn't going to help. You have a broken seal or o ring in the cylinder area. You need to remove the 4 bolts that hold the cap in place. You might want to take pics of the disassembly or you can also go to "dewaltservicenet.com" for a breakdown.
Jul 13, 2011 | Porter Cable FR350A Factory Reconditioned...
Paper feed problem
Just open up the printer lid, don't be afraid, you won't break anything. Usually inkjet printers have a panel on the back aswell which you can open by twisting a big knob. It's there especially for unjamming paper. Also, make sure the paper in the tray is arranged in a neat stack and the things that keep the paper in place are tightly placed against the paper.
May 03, 2011 | Office Equipment & Supplies
Arrow T50P gun jammed - how do you unjam it?
Buu a different brand or model this one is junk and should be taken off the shelf
Feb 06, 2010 | Arrow T50P ARROW STAPLE GUN
I have a craftsman nailer full head framing gun. There is a jam of 2 nails in the cylinder. How do you unjam the gun
On that nailer, you have to remove the nail Magazine. And then clear jam thru the sloted open side. And then put the Magazine back on. Usually one big bolt on each side of the nose and 1 or 2 bolts on the rear body.
Aug 25, 2009 | Air Tools & Compressors
Savage Arms Savage AXIS XP Camo 223 Logo
115 people viewed this question
Top Savage Arms Optics Experts
raysaw
james laughton
james laughton
Are you a Savage Arms Optic Expert? Answer questions, earn points and help others
