Question about Ematic Audio Players & Recorders
Sound issues No sound from speaker or headset jack unless in sleep mode
  • 3 Answers
What i would do reset it or turn it off or look up a videos
Posted on May 01, 2013
No sound at all, but power on. Should I replace the phone jack?
Hi Hermann ,
This is a typical issue with Logitech speakers . You need to bring them back to the the dealer and get an exchange set for free replacement onder warranty . If the warranty has expired , you will need to solve the problem by testing the cables or the printcircuit inside the sub , BUT first connect your head phones or another speakers set to the correct output of your computer's soundcard to verify if the issue actually commes from the speakers . If the test is negative , the issue is to be found in the soundcard and you will need to replace it .
Best regards .
May 10, 2014 | Logitech X-230 Computer Speakers
Iphone 4s sleep button, speaker, microphone, headset jack are not working
It probably fell onto the headphone jack and something got messed up there. That's a problem that you could maybe fix by taking it apart and reseating the button actuator. If it fell onto the button, it may have pushed the actuator farther into the phone. The button pushes down on another button inside that is part of the actuator module, so may have been pushed around.
Mar 27, 2014 | Cell Phones
Laptop won't detect plugged in headphones
Is the speakers working? Did you try to uninstall the sound card from the device manger, then restart it. Some time this helps
Mar 01, 2014 | Toshiba Satellite Computers & Internet
My system is stuck on (c2) headphone and I can not any sound, unless I put the headphones in.
Hi Steve,
This is an indication of faulty earphone jack, this is where the headset directly hooked up. See sample picture below.
When the you hooked up the headset to this jack, internal switch will released the contact to cut the audio goes to the main speaker out of the unit. Once you pulled out the headset plug, the audio will back to the main output speaker out through this switch.
In your cased, there's a malfunction in the internal switch of the earphone jack that's you haven't sound output at the main speaker out.
You may spray contact cleaner directly to the earphone jack while inserting and pulling out the headset plug to clean the lead. If the symptom still persist, you must replaced it with new one to back the unit in normal operation again.
Hope I helped you.
Have a nice day!
Thanks for using Fixya
May 17, 2011 | Sony DAV-S400 System
No sound
Hi tom2105,
First make sure that the sound is not in "mute" mode.
Plug your headset to the earphone jack(if installed) of the TV.
If you can hear the sound there, the fault may due to open(defective) internal speakers or the earphone jack itself. Faulty internal speaker may replaced with new sets to back your sound to normal again. If the earphone jack was faulty, you may spray it first with electrical contact cleanerwhile inserting and pulling the headset plug into it for one minute to clean the contact. If nothing happens, this jack need to replaced with new one.
If you can't hear the sound after inserting your headset, this is an indication that the audio circuitry was gone bad. The most common caused of this trouble was the faulty sound IC(mounted in heatsink). This is the one converts the audio signal to sound and feed to your speaker's. I would advice you to look for a qualified technician to check this parts.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Apr 25, 2011 | Vizio L30WGU 30 in. HD-Ready LCD...
How do i fix the volume because i do not have sound? my tv has no volume/sound. tried turning the tv up and down but still no sound
1 - hi
2 - check the jack for headset
- if you heard any sound with headset = your speakers are burned
3 - if you always use this jack for head set its maybe got problem = when push or pull the headset jack if you hear any sound from speakers your headset socket should change
4 - if you didnt hear any sound from both (speaker and headset) it means your ampilifire should repair
May 23, 2010 | Emerson CR202EM9 TV
Laptop speakers does not work, headset does
When you connect your headset in to the laptops 3,5 jack connection there is a little switch inside that socket.If you push in the jack it turns the pc-s speakers off.Probably that little switch is stuck,you can move around the jack to try to free the switch.No other explanation for this issue.
Jul 13, 2009 | Dell Inspiron 700M Notebook
My speakers work but my headphone jack won't
The Solutions that will mostly work :
1) Go to sleep mode - wake up ! - tada !! the headphone jack will work again .. I know it sounds crazy.. i had the same problem.. (ie speakers onboard worked while headphones jack didnt work) usually restarting solves any problem, but this time even a restart did not worked while putting the laptop on standby(sleep) mode and waking it up worked !!
2) If the above does not work, uninstall the sound drivers from device manager - restart the computer - then let windows detect appropriate drivers by itself. Sometimes the Sigmatel drivers(which are provided by manufacturer) do not work well compared to windows vista's HD sound drivers. May solve the issue... Do not worry doing this, in the worst scenario you can always download and reinstall the dell drivers from dell support page.
Please update on sutarianiral@gmail.com if the problem gets solved..
Mar 01, 2009 | Gateway MT6707 Notebook PC
No speaker no sound on my treo
I had to have my Treo swapped once already because of a problem with the headset jack. The same problem is happening now - the phone always thinks the headset is plugged in (even when it isn't). That results in phone ringing (unless on virbate / silent mode) but no audio through the speaker in the back, and no speakphone icon appearing.
Given the symptoms you describe I would go to your service provider and (hopefully) get support under warranty - very likely hardware related.
Aug 10, 2008 | Palm Treo 650 Handheld
No more sound from speaker
I had a similar issue on mine. The easy fix was to insert a headset jack and pull it out quickly. I think something got stuck that turns off the speaker after I put the headset in the jack once. If this is the problem, I think you should also see a headset icon when making calls, even though no headset is attached.
Jun 15, 2007 | Sprint Vision PPC-6700 Smartphone
48 people viewed this question
Top Ematic Audio Players & Recorders Experts
Lawrence Oravetz
Are you an Ematic Audio Player and Recorder Expert? Answer questions, earn points and help others
