Onkyo htr 250
I have an older onkyo receiver and a newer vizio TV. Is there a way to hook up tv to receiver to get surround sound through the speakers? WE've put in AV cable to both component to get sound to come out. Tried remote buttons tv settings but can't seem to figure it out. Tried to find old manuals and they don't seem to go that far back. Thanks, Ricci
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
taran_2005
  • 10515 Answers
SOURCE: No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Posted on Jan 24, 2009
SOURCE: Yamaha HRT 6130 cable questions
You would need 1 component and 1 HDMI cable.
Posted on Mar 21, 2009
  • 5 Answers
SOURCE: I HAVE AN ONKYO TX
The symptom you described can be caused by any number of things. I always start with the output power transistors which are the first things to blow with a speaker output overload condition. Unplug the power cord to your unit, remove the top cover and use an ohmmeter to check resistance from C to E on all 10 of the power transistors (Q6050 thru 54 and Q6060 thru 64) attached to the large heat sink. Blown transistors typically read <1 ohm, compared to good transistors that are >10k ohms. If you find a bad transistor it will need to be replaced.
Posted on May 03, 2009
satavlad
  • 405 Answers
SOURCE: Yamaha HTR-6230 receiver set up w/HDMI no sound
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
Posted on Nov 28, 2009
How do I get the TV channel for sound to go through my Yahaha HTR-6130 ? What connections or leads do I need to connect the Amp to the TV???
Is it a newer flat-panel tv? Should have an optical audio output jack. Just connect that to an optical input on the receiver.
Jan 23, 2013 | Yamaha HTR-6130 Receiver
I have an older model Yamaha HTR 5830 receiver and I want to set it up for surround sound (5.1). When I test the receiver all five speakers give back a signal, but nothing ever comes out of the center or...
The broadcaster of the TV station has to tell you they are transmitting surround sound - sometimes they are just transmitting stereo. Also, the media as in CD's and DVD movies must have surround sound embedded or recorded on it to allow surround sound.
Jan 02, 2011 | Yamaha 5.1-Ch. Surround Sound Home Theater...
TV/DVD surround sound through receiver
Try running digital audio from the source - cable/sat - to the receiver. The fewer intervening connections and entities, the better. TV's are NOT considered sound sources for high end purposes or we wouldn't have Yamaha HTR-5860's and better speakers, would we?
Apr 22, 2010 | Yamaha HTR-5850 Receiver
I have no TV box but do have cable, how do I hook up TV,VCR,DVD, and YAMAHA HTR 6030
For watching TV, your TV should have a monitor out. This will go to your CBL/Sat input on the receiver. If you have a newer TV, it will have an optical output,if you use that, you will have Dolby Digital surround when available, and digital stereo at all other times. For the VCR and DVD, if they are separate units, Run audio video from the VCR to the receiver to VCR 1, for the DVD, use Component video and optical or digital coaxial to the receiver. Then from the receiver run component video to the TV. If you need further help, post a comment and I will help you further. Hope this helps
Dec 28, 2009 | Yamaha HTR-6030 Receiver
I just bought a Blue Ray player but my surround sound has a dvd player built in and only one input which I have my new Sharp TV plugged into. How can I hook up my Blue Ray . I have the HDMI cables
Depending on if your surround system has a hdmi input or not. if it does you can connect the blu-ray player to it. If it doesn't have an hdmi input you will have to run the hdmi cable from the blu-ray to the tv then run a set of rca cables (red and white plugs) from the tv audio out to the surround systems' audio input jacks to get sound through the surround system. Most surround systems don't have an auxiliary input for another video device.
Nov 21, 2009 | Onkyo TX-SR606 Receiver
No surround sound on ps3
Set the sound out put on ps3 to the optical out put then set sound on ps3 to give you dolby digital,dts,aac etc.
PS, do not set the hrtz range above 100 as this can damage your speakers.
hope this helps.
CABLE GUY.
Jan 05, 2009 | Onkyo HT-SR800 System
Wireing
Consult HT-R500 operations manual for hook up
Feb 08, 2008 | Onkyo HTR500 Receiver
71 people viewed this question
 Grubhead
Grubhead
