The hammer frame had broken while in use anew hammer frame was installed along with tune up kit parts. when the impact is used now it has good free speed but will not hammer at all acts like it wants to but wont. thanks for the help!
THE IR 2141 HAS A 2 HAMMERS, ON 1 SIDE IT IS FLAT AND ON THE OTHER IS HAS A BEVEL. THE 2 BEVELS HAVE TO FACE AWAY FROM EACH OTHER AND 180 DEGREES OPPOSED (1 UP AND 1 DOWN) IF NOT ORIENTED CORRECTLY IT WILL CAUSE THE MECHANISM TO LOCK. FOLLOW THIS LINK AND LOOK AT ITEM 15.
http://irtechpubs.com/ir_pdfs/Tools/Impact%20Tools/Air%20Impactools/04584009_ed1.PDF
SOURCE: electric impact wrench runs slow with no power
ALL Sears products have the replacement parts listed at;
http://www.searspartsdirect.com/partsdirect/index.action
Enter you model number and you will get a diagram and parts/price list.
The people at Sears should have known that. Sears also have free-standing hardware stores in many areas.
SOURCE: craftsman 1/2' impact gun
Use a good grease. Don't pack it, just lube the parts. If it is all together, put in about half an ounce of air tool oil through the plug.
SOURCE: I need copy of instructions for Ingersoll Rand
Follow this link:
http://www.irtechpubs.com/ir_pdfs/Tools/Impact%20Tools/Air%20Impactools/04584819_ed4.pdf
This is the manual for the 231C Impact Wrench.
There is a barrel that goes across the impact in the back, you can press this from right to left an vice versa. If the barrel will not move there may be damage inside and further inspection is necessary.
SOURCE: Runs fine in reverse, but will not run full speed
make sure the power /speed controll is set on high in both directions yes it can easily be rebuilt i can do it cheaper than most places, i have 30 years experience at fixing air tools - i worked for snap on tools also check and see that the front housing screws are equally tight.
