Question about Hayward Pool & Spa
Pool pump turns off in a couple of seconds - Hayward Pool & Spa
  • 717 Answers
When a motor turns off after a few seconds of coming on then you have a bad motor.
Could be a bearing or windings but definitely the motor is bad if it is shutting off on you.
Rod
US Parts Center
Posted on May 13, 2013
What would cause a FLYGT 3152 submersible communator pump to keep tripping at the breaker in the control panel
earth leakage is tripping the breaker from bad insulation or water in the motor or wires
Jun 19, 2017 | Pool & Spa
Can I change a part(s) e.g., impeller, to improve the pump efficiency?
Replacing the impeller could help, depending on the condition of the existing impeller. If it\'s worn and chipped, yes, replacing it will help. Is there a better impeller you can use? Probably not. The pump designer probably used the best available. How does it fit within it\'s compartment? Does it squeal or rattle? The tighter the tolerances - without rubbing - the more efficient it will be.
I think the next big thing in pump rehabilitation will be some sort of Teflon-imbued epoxy spray for resurfacing the impeller chamber and other interior surfaces. They\'re doing it with ceramic paints on iron pumps to good effect, but I haven\'t seen a similar solution for plastic pool pump housings yet.
You said you checked output pressure, but did you check motor output? It could be that the motor is getting tired and just not putting out the power to efficiently run the pump.
Yes there should be a check valve to keep the pump from draining when you open the basket. In lieu of that, you can turn the pump on for a couple of seconds to get some pressure, then turn it off, for a couple of seconds, then back on. This will suck some water up and then back-wash a little. The result is some water in the pump to help create the suction to get more water in the pump. This technique can be hard on the motor, but easier on the pump - you choose.
Aug 15, 2014 | Pool & Spa
How to backwash a pentair de filter
turn off unit turn multiport to back wash when water comes out clear or in a couple minutes then turn off then rinse for 30 seconds then turn off then put in filter mode turn on and add recommended amount of DE into skimmer
Nov 10, 2013 | Hayward EC-40 DE Pool Filter with pump
My hayward 2hp ao smith turns on then kicks gfi breaker after a couple seconds. after several tries it works ok.
I think you have a failed start capacitor. Have your motor looked at by your professional pool supply.
Jul 18, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
Pool cover pump quit working without warning. was not in deep water. pump is clean, no cracks or compromised wire. air vent hole not plugged. tried in a couple different outlets (power source) then put in...
take the cover off of the automatic shut off and check for debris. Most cover pumps have an auto shutoff and most of them have the type of valve that can be inoperable due to debris getting into the valve.
Oct 07, 2009 | Pool & Spa
Proline 1.5 hp pump gets hot and trips breaker.
motor is locked up in the motor are two bearings they will rust if they are set up for a while.you can take the back off the motor and where the shaft goes thru the houseing take a pair of needle nose plires and try to free it up.
Jul 03, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Pool Pump won't turn on
Hi, this could be one of a couple of things, firstly check the pump is plugged in securly to the main panel, secondly, check the fuse inside the panel hasn't blown, third, there is a capacitor inside the connection box of the pump (where the mains lead goes in), this sometimes fails causing the pump to stop working, this should be replaced like for like. Good luck!!
Mar 13, 2009 | Smith Pool & Spa
Pool & Spa Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
