Question about Lexmark X2250 All-In-One InkJet Printer
X2250 won't print form pc
Had a functional printer. Refilled black cart before it ran out. Color cart is probably empty. Runs through all printing motions but pages are blank. Test page only has Win logo. Getting 3 overlayed images of printers on alignment page but bars and lines are clear. Have reloaded drivers several times. Cable tested good on another printer. Other printers on this pc work fine. Changed print processor from LEMF to RAW and NT EMF 1.008 all have same results. Copy function on printer gives very clean but double images. Is it plugged in, is it turned on? Yup checked that too. Also tried "New" cart and "Used" carts. Everything gives same results. Tried printing from Notepad and again, printer goes through printing motions but page is blank.
  • Lexmark Master
  • 684 Answers
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!
Posted on May 13, 2013
SOURCE: Lexmark Z600 ONLY print test pages
Seemes very daft, and sounds like a twit, but not really.
When I recieved the new cartridge I placed it in the correct cartridge retainer in the printer matching up the dark green colour of the cartridge and the top clip, and it printed nothing even after a tryed re-seating it.
So I placed it in the other thinking maybe I somehow might have placed it in the wrong slot, so I placed it in the other (Colour), and set that up as I did the other, and it printed a blurred page but then stopped printing.
After that I then placed it back in the other cartridge retainer, set it up as the previous times when it did not work, and then it worked.
Seems strange and simple, but it did not work the first time at all, and after faffing with it finally did.
This might help someone, and then again might not.
Posted on Oct 09, 2008
vegakitten20
  • 685 Answers
SOURCE: Lexmark X2250 Printer. Windows Prints blank pages
check your cartridges
Posted on Mar 14, 2009
  • 1335 Answers
SOURCE: Its very good at printing blank pages, tried all the fixes I found. Nothing!
It sounds like you've gone through all the normal processes to correct the problem. This indicates a problem with the refilled cartridges. The refill ink may not be up to HP specs and be clogging the nozzles. The next step is to put in OEM cartridges (not refills) and go through the cleaning and alignment process. This should clear the problem.
Let me know if this clears the problem otherwise we can try something else.
Thanks.
Posted on May 31, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: I have installed a new
    Doing the "clean printhead/cartridge nozzles" multiple times would have cleared clogged nozzles. You can also try to manually wipe the cartridge nozzles with a slightly moistened soft cloth. If that still won't help, try to replace your cartridge with a different known working cartridge to determine if your other cartridge is faulty.
    Posted on May 12, 2011
    printmastert
    • 3344 Answers
      Verified Fixya Pro
      SOURCE: Lexmark S405 won't print or
      Please visit the Lexmark support page to determine if your printer is affected with the printhead issue. Also, make sure your printer is updated. The firmware update will help give you a highly reliable print system.
      Click here to validate your serial number and/or update your firmware.
      Posted on Sep 26, 2011
      Mg5250 printer won't use other black ink when big one has run out.
      The reason that there are two black carts is that one is for printing on standard paper, and the small one is for printing on photo paper. It's not a spare, and it is not supposed to use the small one when the large one runs out. You will need to replace the empty cart.
      Jan 08, 2018 | Canon MG5250 Printer
      WITH THE LEXMARK X2250 ALL-IN-ONE PRINTER CAN I USE THE COLOR INK CARTRIDGE TO PRINT BLACK, IF MY BLACK CARTRIDGE IS EMPTY? HOW CAN I DO THIS?
      when your black cartridge goes empty , the printer automatically goes into the reserve mode where it mix up the colors in the color cartridge to produce black color
      Aug 06, 2012 | Lexmark X2250 All-In-One InkJet Printer
      HP PRINTER DESKJET F4135 HAVE INSERTED REFILLED CARTRIDGE AND PRINTER IS BLINKING EMPTY HELP.
      New carts should work, it is the old ones that usually fail. If you shut down the printer, turned it back on and still no communication; then the Cartridge Contacts are not making a good connection or there is oil film from you fingers on the contacts. Remove the cart, take a q-tip dipped into rubbing alcohol and rub against the metal contacts and also the print head contacts. Let air dry. Replace and see if that works for you. If not, check with HP at HP.com for a printer Firmware Update and install it. Also get the free HP diagnostic programs to check the printer.
      Feb 20, 2018 | HP Office Equipment & Supplies
      I have a PIXMA iP4300 and just want to use it for black and white document printing. My 'M' and 'C' color cartridges ran out a while ago and I disposed of them but didn't replace them...
      Most of the Canon printers form the PIXMA iP series block printing when one of the cartridges is empty. You have some options: 1) change the cartridges (with original or compatible) 2) buy a chip resetter and reset the empty cartridges chip so they can cheat the printer that they are full. This way you will clog the nozzles of your print head and the printer will become useless and won't print.
      That's why I suggest you to but even cheap compatible cartridges and replace them.
      Hope this helps. Alex
      Sep 11, 2011 | Canon Office Equipment & Supplies
      Installed new black cartridge in Deskjet 810C printer and after doing this it will only print in pink color. Please help.
      Make certain that the cover is off the jets - if you forgot to pull the strip off or it broke leaving part of the tape on the cartridge, it won't work. Try to do a clean process on the cartridge. If that doesn't work, and you don't have another printer to try the cartridge in, return it to the place you bought it and get another new one. If the printer is printing pink, the color cartridge is probably empty also so that it cannot make black from the other colors. These sound like refilled cartridges - OEMs would have failed with some form of error code or warning.
      Apr 11, 2011 | HP DeskJet 810c InkJet Printer
      Hi, My Canon MP210 printer is displaying E3 code. The colour light and alarm lights are illuminated constantly and black one is flashing. When opening the "lid", the cartridges do not align to...
      I have workaround for the empty tank issue:
      - buy or borrow another not empty tank
      - place it in
      - start the printer
      - it recognises the "new" tank
      - turn off the printer
      - put back the old, empty, but refilled tank
      - turn on the printer
      - print something
      - it will pop up a dialogue window saying
      "The ink level of the black/color tank cannot be
      determined. The ink level determining function will be
      disabled for the black/color tank.
      If you want to continue printing without this function
      press the Start button on the printer."
      - Press the Start button on the printer and ignore the
      button 'Cancel Printing' appearing on the dialogue window.
      - The dialog window disappears.
      You can print your refilled tank as many times you want from this time.
      When you go to 'Printers /Canon /Properties /Maintenance / Printer Status / Ink Information' it says that the ink level measuring function has been disabled for: black [40] / color[41]. You can ignore this this message, the printer will work perfectly without this stupid function.
      Mar 18, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
      Cannot print
      Change the cartridge ...
      but, in case E3
      - place it in
      - start the printer
      - print something
      Mar 18, 2011 | Canon PIXMA MP160 All-In-One InkJet...
      Kodax Eps-5 Printer want print with one cartridge
      No you need functioning colour cart for black to work.
      Apr 28, 2009 | Kodak ESP 5 Printer
      No print capacity
      do you have an error code on the display. plz give us some more details.
      Some quick hints:
      -Is the cart secured by help of the colored latches (you should hear a clicking sound).
      - Do you use generic carts? might be a prob of air ventilation = drill a hole on top of the missing one.
      -did you tell the printer that you have changed the cart by pressing 1 for yes?
      -is another cart empty?
      Feb 26, 2008 | Brother MultiFunction Center MFC-440CN...
      Lexmark X2250 All-In-One InkJet Printer Logo
      139 people viewed this question
      Top Lexmark Office Equipment & Supplies Experts
      Don  Farrell
      Don Farrell
      Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
