Question about Electrical Supplies
What spark plug for jd-tek 6500 propane generator
Stock plug is Chinese, what is replacement I can get from autoparts or hardware store
3 Suggested Answers
CarlGehrke
  • 169 Answers
SOURCE: No spark?
I answered a question very similar to this one here, when you do get it to start you may find that you have to flash the field on it to get it to make electricity, you can ask me how if you like.
Carl
Posted on Dec 03, 2008
  • 83 Answers
SOURCE: My troy-Bilt 5550 watt generator will not start
First drain the fuel bowl. Any old fuel in there will keep it from starting. Fuel stabilizer is not what it's it cracked up to be. I've worked for 6yrs at a rental yard and had no luck with any fuel stabilizer, the fuel still went bad. If after you drain the fuel bowl it still will not start, you will need to clean the carb. Remove the carb and spray carb cleaner through all the accessible passages. If this does not do it, you will need to replace the carb. For long term storage I highly recommend draining all the fuel and filling just the carb with fuel stabilizer to keep gaskets moist. Then drain the carb when you take it out of storage.
Posted on Mar 30, 2009
Need company location to get owners manual for JD-TEK generator. Also need service teck to check one out for Proper operation.
the link offering a free pdf owner manual for it is .... no good
has trojuns and malware...
to service and test
some mower tractor farm equipment type
service centre could be asked
you could call any electrician for the generator side
then any LPG certified fitter . for the engine side
try this . company for any parts
.has international coverage usiing contact us
http://www.generatorguru.com/about-us/
May 20, 2016 | Electrical Supplies
I have a 6500 lp onan marquis generator in my rv that wont start. any suggestions?
Check the fuel. If old, drain & refill it.
Check for spark.
If the fuel is there and good, trace it to the carburetor. Check the carburetor bowl for fuel.
Check the spark plug, the magneto, any switch that breaks the circuit or kills the circuit for spark.
If you're getting good fuel to the carburetor and you're getting good spark, try to start it with ether spray.
You might also want to check compression while you're checking everything else.
Jul 26, 2014 | Onan Marquis Gold 6500 Lp
Spark Plug on a A4
Autoparts store will look it up for you. For longevity, OEM are platinum. If you don't mind changing them more often, copper plugs work very good. On tune 1.8T (or chipped), I recommend NGK BKRE7E (one step colder than stock) copper plugs, gapped to 0.028 or 0.030 (B5 A4 have weak coils and they 'fade' with age; if misfires are detected, time to change coils (temp fix: even smaller gap).
Apr 08, 2014 | 1999 Audi A4
I need to find out what the proper spark plug is for a coleman 1850 genberator
Ken, The CM04143N originally comesw with a Chinese spark plug, LD E6TC. If you convert this to U.S. available plugs it is, Champion L92YC--AC 43FS--NGK BP6HS--Autolite 274 or Bosch W6BC
Feb 02, 2014 | Powermate COLEMAN CM04143N 1850W 2.4HP...
1996 Onan Propane 2500 Microlite Generator often will not start & dies when microwave is started?
Microwave ovens need to be connected to a separate, dedicated line.
Nov 28, 2013 | Grilling
Toy
replacement springs for some hobby horses are available at local hardware stores. Look for a select a spring assortment, or a store that can order from Servalite. They stock them in their catalog. Otherwise a handyman might be able to shorten the overstretched springs to raise the front legs.
Jun 15, 2013 | Tek Nek Toys Lucky Deluxe Spring Horse
Where can i find a manual for jd tek 6500e generator
JD Tek 6500E LPG Generator how to install wheels Battery handles
Mar 05, 2013 | Computers & Internet
What's the mag or coiul on a generac 6500 generator 13 hp
The "mag" is a magneto and it generates the high voltage pulse to fire the spark plug. The "coil" is about the same thing but it uses a set of points or an electronic ignition to control when the spark is delivered.
Sep 30, 2012 | Generac 6500 Watt Gasoline Generator - 49...
Difficulity removing spark plug caps to replace spark plugs in 2002 GMC Yukon
This is normal for the boots to be stuck on it is a very tight fit to begin with and the heat that is generated around them cause them to stick. Try rotating the boots back and forth twisting action as you pull up.If this doesn't work there is a tool available to remove spark plug boots at most autoparts stores.
Jun 06, 2010 | 2002 GMC Yukon XL
I have a new Kohler 12kw res generator on propane - backfiring
Is the outside air temp cold. These generators will backfire if it is real cold and if the propane pressure is low. It is suppose to be 11 to 12 inches of water colume at the generator fuel input. drygwals
Feb 18, 2010 | Kohler 12 kW Emergency Power System -...
Electrical Supplies Logo
43 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
