Question about Brother PS-1250 Pacesetter
Machine pl1050 sewing
Presser foot
  • 3 Answers
SOURCE: Presser foot down, but still get error "E1"
I had the same problem. It started after I took the cover off to fix something else. After I screwed the cover back on, I kept getting the E1 message even when the foot was already down. I took the cover off again, and I found that there is a metal tab at the top left of the front cover, that is pushed by a metal tab in the back that moves when you put the presser foot up or down. You can see this metal tab moving in the back if you put the foot up and down with the cover off. Just putting the foot down(I think) before putting the cover back on fixed it so one metal tab is on the correct side of the other metal tab.
Posted on Aug 04, 2008
  • 37 Answers
SOURCE: The presser foot came off Brothers sewing machine
position the foot under the shaft making sure the horizontal pin on the foot is in line with the horizontal groove on the end of presser foot fitting on the shaft. Lower the pressor foot arm and it should snap right on. If not, press it up manually. the directions should be in your manual. If you don't have your manual, you can get it online at www.brother-usa.com
Posted on Apr 16, 2009
  • 980 Answers
SOURCE: presser foot lifter is stuck can i fix it
If you can't lift the presser foot up at all undo the presser bar screw on top of the presser bar, if you have a dial turn it to 0, you should now be able to move the lever, if it is still tight put some WD40 on the presser bar and leave it for a couple of hours.
Posted on Nov 04, 2009
JeremySew
  • 65 Answers
SOURCE: looking for part for brother ls2125i sewing machine
That foot is available here:
Brother LS-2125 Sewing Machine Parts
Posted on Dec 02, 2009
SOURCE: F4 Error
my machine displays a f4 and does not want to work, what can I do?
Posted on Feb 10, 2010
Husqvarna presser foot icon flashes and will not sew
Be sure the presser foot is installed correctly and that the presser foot is lowered before beginning to sew. If that doesn't help, try a different presser foot. If there are still issues, your machine may need service.
Feb 07, 2018 | Husqvarna Sewing Machines
Error message foot too high. To correct this, it is necessary to restart the machine. Unless it is impossible to continue sewing.What is the problem?
Try taking your presser foot off and lower the presser foot lever. Does the error code go away? The machine won't sew without the presser foot to hold the fabric down, but without threading the needle, will the machine run without the presser foot? Now try the standard presser foot (usually J ) and if you get the error code then the sensor at the top of the presser foot assembly is out of adjustment. Without knowing more about your machine this is all I can suggest.
Good luck,
Bob
May 30, 2017 | Sewing Machines
I need instuctions on using different presser foot for ja nome schoolmate
Please add a comment with the specific model of Janome Schoolmate sewing machine.
Fpr the Janome Schoolmate S-3015, make sure that the needle is fully up and raise the presser foot. Then press the red button on the back of the presser foot holder to have that foot drop off. Set the pressure dial to 3 before attaching the new presser foot. For snap-on feet, align the pin of the presser foot (the horizontal bar in the middle of the foot) under the presser foot holder. Lower the presser foot holder (using the presser foot height lever) until it locks onto the foot.
For the zipper foot, you need to fit the rear pin on the foot into groove at the back of the presser foot holder. Then lower the presser foot holder onto the zipper foot.
These are shown on page 11 (14 of the PDF) of the manual. You can download the manual here: http://janome.com/en/machines/sewing/schoolmate-s-3015/ . The direct link to the manual is http://janome.com/siteassets/support/manuals/school-models/schoolmate3015.pdf .
For the S-7330, you need to again raise the needle and the presser foot. Press the lever towards (it moves slightly up, not down) the presser foot holder. Then line up the pin on the foot under the presser foot holder and lower the presser foot holder onto the foot so that it locks. This is also in that sewing machine's manual, here: http://janome.com/siteassets/support/manuals/school-models/inst-book-s-7330esf.pdf . See page 14 (18 of the PDF).
I hope this helps.
Dec 21, 2016 | Sewing Machines
Presser foot wont connect
It is most likely the presser foot you are trying to install was not made for your machine. There are so many machines available and most of those machines have their own presser feet, which are not interchangeable. Unfortunately, even a Singer presser foot is not interchangeable with other Singers. Some have screw attachments, others have lever attachments, some have long shanks, others have short, some are straight, others are slanted. You need to figure out what style presser foot your machine takes and then search for either the presser feet that fit or a shank adapter that you can then use snap-on feet (kits are available on eBay).
http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
Sewing Machine Feet eBay
Jul 17, 2016 | Sewing Machines
I have a Sears Kenmore sewing machine I want to get a 1/4 in presser foot for it, is there one and where would I get it/
You first need to determine which shank the presser foot uses on your machine. You can compare your shank (current presser foot) with these photos to see which one your machine uses.
NOTE: If you purchase a snap-on presser foot, you will also have to buy a "shank adapter" that will attach the presser foot to the needlebar. Here are some pictures of snap-on adapters:
Kenmore sewing machine snap on adapter Google Search
However, you will still need to make sure to buy the correct adapter for your machine. The GREAT thing about buying a snap-on adapter is you can add a lot of presser feet to your sewing machine accessories because you can purchase additional snap-on presser feet or even a complete set of snap-on feet that will all work with your adapter and your machine!!!
Kenmore Presser Feet eBay
You will just snap one foot off and snap another on!!! Great idea!!!
OR--you can take your current presser foot along with the make & model of your machine and check with the local sewing repair shops to see if they have what you need.
FYI, once you know what shank your machine has, you can probably also find other specialty feet for your machine, ie walking foot, free-motion foot, etc.
Jan 17, 2016 | Kenmore Sewing Machines
Where can i get a presser foot for a Janome 1017
Sep 18, 2012 | Janome Harmony 1017 Sewing Machine
Is the presser foot supose to be touching rhe
your machine is for embroidery only, embroidery machine do not have presser foot.
Mar 30, 2010 | White Sewing White 4400 Computerized...
Presser foot 7 lever on Pfaff 1471
You may not be using the correct presser foot for your machine.
Sewing Machine Feet
You may be using a low shank when your machine needs a high shank.
May 12, 2017 | Kenmore 15218 Mechanical Sewing Machine
Sewing Machines Logo
49 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
