Question about Boating
Autopilot raymarine st1000
When I press auto, it show me a nurnber 1000 . How can I fix it. Please help me.
    Problem Solver:
  • 8 Answers
Firstly, I don't know why you have removed the cover housing on the unit. Unless you are a marine electronics service trained individual or have been directed to do so by one, PUT the cover back on and get out the OWNER'S MANUAL. This is an ERROR CODE. Consult the troubleshooting page(s). This may be as easy to fix as any RTFM problem. If this doesn't give you the solution, CALL or e-mail Raymarine and SPEAK to a service rep for help. It is, afterall, their product and who but they can best diagnose the problem and resolve.
Posted on Jun 02, 2013
  • 3 Answers
SOURCE: Installing a Raymarine 8002/6001 on my 2005 Sea Ray 270
If you have a basic knowledge of electronics and can follow instructions. It's easy the hardest part is connecting the pump and bleeding the system.
Posted on Jun 25, 2009
  • 16 Answers
SOURCE: raymarine autopilot swings hard over immediatly i select auto
CHECK RUDDER REFERENCE UNIT FOR CONTINUITY(IT IS A POTMETER) CHECK IF MOTOR IS RUNNING IN THE CORRECT DIRECTION ,CHECK CONNECTION OF RUDDER REF UNIT.
Posted on Apr 22, 2010
  • 43 Answers
SOURCE: Display control unit frozen, display just reads standby
The reason is because the housingin is a little bit broken or throw the keypad water came inside yuor Display and after this the oxidation ha destroyed a part of the printid circuit or the switch of the keypad
Posted on Oct 13, 2009
SOURCE: Autopilot shows "no rudref"
how do connect my autopilot
Posted on Mar 17, 2010
SOURCE: ST6000 autopilot kicks out
I have exactly the same problem, It is very unpleasant, all the time we have to be close from the helm. if you founded the solution, I am very interrested. I will try some test. If I find something, I will post it.
Posted on May 02, 2010
I'm trying to fix an autohelm 1000 and ned the schematic
Go to Raymarine website and look under Technical Support, Manuals and documents. All of their product manuals are listed there. If you are burning out the transistors, it sounds like you are puting too much load on the auto pilot.
Dec 05, 2013 | Raymarine St1000 Plus Tiller Pilot
Raymarine st 1000 displays 1000 (flashing and beeps) and the actuating rod will not move
Have the same problem, sick and tired of it. It is 18 month old, had repaired once 2 months ago by raymarine, some soldered joints came undone on the board, not working again! Used it 4 times since new out of probably 20 attempts. Every time I try to use some new problem raises. Possibly just my luck. Just ordered a new Navico st 32 heard it is better unit.
Jun 10, 2012 | Raymarine St1000 Plus Tiller Pilot
My Raymarine ST1000 12 months old, started cutting out a couple of months ago and displaying 1000 them return to standby mode. The frequency of this happening has increased 10 fold. sometimes it happens...
I have the same problem. Do you have a solution for it yet?
I do think it has to do something with decreasing power from my onboard accu. The first hour(s) sailing I don't have any problems, but after a while mine is jumping to STANDBY too, and the periods between become shorter, until less then 5 minutes.
Jan 10, 2011 | Raymarine St1000 Plus Tiller Pilot
When I plug it in it reads the degrees but when I press any button it just reads 1000 and the shaft does not move hold down any button and it clicks the 1000 message rapidly. No movement of the shaft of...
Same thing happened to a friend using an ST2000+ (was reading 2000 instead of 1000). Found that that power (12 V) and ground had been mixed up, so that the internal reverse voltage protection keeps resetting the pilot each time a button was pressed.
Jul 25, 2010 | Raymarine St1000 Plus Tiller Pilot
My ST1000 tiller auto pilot has broken screw mounts inside the cover, and while to the compass and gyro work, the plus or minus keys don't seem to move the hydraulics. When I removed the cover I found two...
Yes it can be repaired. Any Raymarine dealer should be able to help you out. If you can't find a local dealer, email me: kevin@sun-me.net and I can give you pricing on the repair. I would need your serial number of the pilot.
May 28, 2010 | Raymarine St1000 Plus Tiller Pilot
The rudder sensor works like a light dimmer, so you get 5V and ground on the outside two connections and a varying voltage between about 1 and 4 volts depending on rudder position
847-746-0100 www.technicalmarine.com
Jul 07, 2009 | Raymarine Smartpilot Autopilot St6002 S1g...
Problems talking to autopilot
I think you use the NMEA output to the autopilot .
The plotter shows you only when you have a seatalkconection with a Raymarine autopilot on you Plotter
Apr 06, 2009 | Raymarine E120 Multifunction GPS Receiver
Raymarine autopilot swings hard over immediatly i select auto
Apr 04, 2009 | Raymarine St8002 Smartpilot Autopilot...
Auto pilot
difficult is it to install Raymarine 8002 autopilot in 270 Sea Ray
Jan 14, 2009 | Raymarine St8002 Smartpilot Autopilot...
Boating Logo
292 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
