Question about RTO 50cc Moped Scooter
Tao tao scooter
Y tao tao was working. Fell on it on the side with the silver pipe. Was not going fast 10 mph. the scooter slid just a bit because of the scratches on that side. It ran after I got up but the power was much less than it was before. Got it home and turned off. Started it back up it worked. Next morning it wouldn't start up. It made sound like it was goiing to start, but never kick over. Now the scooter was making a little start up noise, now nothing. tried to jump start it, but it wouldn't start. Lights on the dash comes on. Why does the tail light stays on even when the lights are off and when I not even holding the breaks? What could be wrong? It didn't hit the ground too hard.
4 Suggested Answers
miket756
  • 2702 Answers
SOURCE: The magneto went out on my scooter.
its not got a feed for charging the battery you need the right part to fix it, swoping bits from an older bike some times realy wont work out for you,, get one from the same moddel and year of bike and its then just a case of a strate swop over,,,
you can fit a lorry wheel on a car can you?
Posted on Oct 24, 2009
  • 43 Answers
SOURCE: My 50cc scooter had problems starting this summer
No it's not normal. According to your description, you may have a grounding kill switch. It's not common, but may be so. Disconnect the switch completely (underneath the plastics) and see if this helps, our replace it. It may be something else, just perceived as a coincidental switch problem
Posted on Dec 31, 2009
SOURCE: my scooter PanTerra no start, not even turn over
Most scooters have four things that need to be done before they can be started with the electric starter:
  • The ignition has to be turned on
  • The kill switch (usually near the right grip) has to be in the "on" position
  • The rear (left) brake lever has to be squeezed.
  • The starter button must be pressed.
Some scooters may have other interlocks on the front brake or the center stand. Check your owner's manual to make sure that you are doing all you need to to complete the electrical circuit which enables it to start.
If the scooter doesn't turn over when you've done all the required operations, there's an electrical problem with the battery. Make sure the battery is charged. If it is, make sure the fuse hasn't blown. If it hasn't, check to see if you are getting voltage to the starter motor terminals. If you are, the starter motor is likely defective.
If the scooter does turn over but still doesn't start you have to check for a spark and make sure gas is getting to the engine. To check for a spark, remove the spark plug from the cylinder, hold the tip of the plug against the cylinder head and crank the engine. You should see a spark across the gap. If you don't, there's a problem with the ignition. Could be a faulty coil or electronic ignition module which will have to be replaced, or it could just be a lose wire.
Hope this helps.
Posted on Jul 04, 2011
TaoTao 50 will not idle
Hi, Misty you need to make sure you have no intake leaks by spraying some Brake Kleen, Contact Cleaner, Starting Fluid etc. around the intake manifold and seals, if the RPM's go up or down significantly then you have a leak that needs to be fixed before you can continue with the carburetor adjustment.
The engine should be at operating temperature with the choke off to set the idle between 950-1050 rpm. Turn the idle skrew clockwise to increase the idle speed and counterclockwise to decrease the idle speed. If you have access to your air-fuel mixture skrew you may turn it as well, if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air-fuel mixture skrew clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back the skrew out 1-1/2 full turns to establish a starting point start the engine and check the idle rpm's and turn the idle skrew accordingly for 950-1050 rpm if necessary, turn the air-fuel mixture skrew 1/4 turn at a time and let the engine settle for about 10 seconds, turn the skrew clockwise for a leaner mixture and counterclockwise for a richer mixture, you are seeking the highest rpm your air-fuel mixture skrew can acquire without going past 3 full turns from the bottom then resetting the idle skrew back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture skrew all the way in then your pilot/low-speed jet is too big and needs to be replaced with the next size smaller. Final adjustment should be made with a clean air filter mounted to the carburetor.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Bought China scooter Won idle properly scooters
Tao Tao 50cc scooter idle problem fix
My chinese scooter wont idle or start Check the fuel petcock http://www.family-motorsports.net/GY6-50cc-150cc.pdf
TaoTao 49cc Scooter Parts
TaoTao ATM50 A1 Owner Manual
Mar 29, 2018 | Motorcycles
Ignition switch for a 49cc Tao Tao scooter and an ignition switch wiring diagram
Hi, Michael for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your TaoTao, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Tao Tao 49cc scooter wiring diagram Google Search
My Wiring Diagrams 49ccScoot com Scooter Forums
http://www.49ccscoot.com/manuals/Symply50_Service_manual.pdf
Eagle Atv Parts
Apr 06, 2017 | Tao New Scooter 50cc Street Legal New Look
Which service repair manual do i need ?
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
TAOTAO under 50cc Scooter Fully Automatic VIP 50 10 Tires CY50
Two hoses that run from the carburetor Is the upper hose cut and zip tied...
Scooters TAOTAO USA INC
TaoTao 50cc Scooter Owners Manual
TaoTao Scooters Mopeds Parts
Feb 07, 2017 | Motorcycles
150cc stator
Chinese Junk I am sorry to say. All made as cheaply as possible.
ROKETA MC-19 STATOR
www.roketapartsdept.com/products/ROKETA_MC_19_STATOR-16828-579.html
  1. Cached
Part# MC-19-150-06-01-09. Roketa MC-19-150 Replacement part. May Fit Other Makes and Models.
MC-19 ENGINE PARTS: Roketa Parts Department
www.roketapartsdept.com/catalog/MC_19_ENGINE_PARTS-579-1.html
  1. Cached
ROKETA MC-19 BREATHER HOSE CONNECT. Product ID ... ROKETA MC-19 ENGINE OUTPUT SHAFT. Product ID ... ROKETA MC-19 STATOR. Product ID ...
Roketa 150: Parts & Accessories ' eBay
www.ebay.com/bhp/roketa-150
  1. Cached
  2. Similar
Find great deals on eBay for Roketa 150 in Scooter Parts. ... MAGNETO STATOR 8 COIL POLE GY6 125cc 150cc SCOOTER ATV GO KART ROKETA TAOTAO ...
Roketa Scooter Parts - All Street Brands - Monster Scooter Parts
www.monsterscooterparts.com/scooterparts/street-brands/roketa
  1. Cached
Roketa MC-16T-150 Scooter Parts. Roketa MC-17-50 (Sicily 50) Scooter Parts. Roketa MC-17-150 (Sicily 150) Scooter Parts. Roketa MC-19-150 Scooter Parts.
Roketa MC-07-150 (Bahama 150) Scooter Parts - Monster Scooter Parts
www.monsterscooterparts.com/scooterparts/street-brands/roketa/roketamc07150
  1. Cached
Items 1 - 6 of 6 - 8 Coil Magneto Stator with 3+2 Wiring Connector for 125cc GY6 152QMI & 150cc GY6 ... 19 99. G07-1459. Medium Weatherproof Cover for Roketa Scooters ... Quality replacement parts for the Roketa MC-07-150 scooter.
Roketa Scooter Parts - Chinese Parts
www.motopartsmax.com > Roketa Parts
  1. Cached
  2. Similar
Roketa Scooter Parts By Type ... Air Filters & Intake (19) · Intake Pipes & Water Pipes · Air Filters · more · Cables (16) ... Roketa MC-19-150. Parts List · MC-20-150. Missing: stators
And TAO TAO
tao tao powermax Google Search
Dec 29, 2016 | Motorcycles
Bike wont work after riding all day no headlights no horn nothing its a tao tao 50
Hi, Andi and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Headlights SOLVED SCOOTER PROFESSOR
Blinkers Horn Fuel gauge not working Scooter Doc Forum
http://www.49ccscoot.com/manuals/Derbi_Scooter_Manual.pdf
Nov 03, 2016 | Tao New Scooter 50cc Street Legal New Look
What spark plug does a tao tao 50 use ? My scooter is suppose to have an 88 cc big bore kit in it. What is the plug gap ?
Hi, Jim sorry you can't find the first and best tool you ever bought for your Tao Tao despair not for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Differences between two tao tao scooters Page 3 ScootDawg Forums
TaoTao Cruiser 50 Gas Street Legal Scooter
http://www.49ccscoot.com/manuals/139QM_Engine_Manual.pdf
Mar 26, 2016 | Big Motorcycles
Free repair manual Tao Tao VIP 49cc scooter 2012
owner'spperator manual 2011 tao tao
Jun 15, 2012 | Motorcycles
Manual for tao tao 50cc scooter
Hey you said you don't know of any dealerships that deals in a taotao scooter in the USA there is one in Muncie Indiana they have manuals for those type of scooters
Feb 27, 2012 | Motorcycles
RTO 50cc Moped Scooter Logo
65 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
