Question about Husqvarna Garden
Stalls slowing down
Bogging down after little use
  • Plink-plonk
    Plink-plonk May 01, 2013
    Which model in particular are you refering to.? The more information you can give will aid to the correct diagnosis. :)
  • Husqvarna Master
  • 1,807 Answers
Air filter plugged - Clean air filter
Tank vent faulty - Clean or replace tank vent if necessary
Leak in fuel line between tank and fuel pump - Seal or renew connections and fuel line
Pump diaphragm damaged or fatigued - Fit new pump diaphragm
Main jet bores or ports blocked - Clean bores and ports
Fuel pickup body dirty - Fit new pickup body
Fuel strainers dirty - Clean fuel strainers
Posted on May 01, 2013
My 1994 5-speed manual Pathfinder sputters and jerks when it's cold
Here are the common cause of surges, stalls at stops, slow idle speed, erratic idle, it is in most cases the idle speed control air-bypass valve and/or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving
Mar 22, 2014 | Nissan Pathfinder Cars & Trucks
2004 free star bucking and bogging down
If your Freestar has the original fuel pump, it could be in need of replacement.
Nov 21, 2013 | Ford Freestar Cars & Trucks
92 dodge dakota stalling,running rough,loss of power
Did you replace the fuel filter when you replaced the pump ?
Was it running rough before the pump was replaced.
Did you replace the cap and rotor too ?
"Sucking a ton of air" could be a vac leak, or the sound of the throttle open when the engine is bogging down.
Is the check engine light on when it is running ?
Jul 05, 2012 | Dodge Cars & Trucks
Craftsman Platinum 190cc 22" Briggs
hi there
danielburgi
1 almost sounds like you may have a restriction in the main jet of the carburettor or idle circuit transtional holes or idle air bleed holes , also check emulsion tube
2 then if these are all ok try adjusting governor - as soon as load exceeds power output - unit will try and stall- once governor adjusted re-try -
3 the only other thing it may be is too low compression which ia major concern
try 1 and 2 options 1st
3 is the last option which means a leak test to check compression loss or worn rings
cheers pauly46
hope it helps
May 27, 2011 | Garden
86 4.3 litre V6 chevy el camino bogging down, stalling out
most likely a weak fuel pump or a clogged filter. Check fuel pressure with a gauge or as its bogging down spray brake cleaner in the Throttle Body. If this allows it to increase RPM then its the pump or filter.
Oct 30, 2009 | 1986 Chevrolet El Camino
STALLING
I had a similar problem. After changing just about every sensor under the hood, I finally fixed it by replacing the CCV valve and the vaccuum hose harness and all the hoses: http://jeep.off-road.com/jeep/article/articleDetail.jsp?id=257985 . It ran a little better and then I tightened down the throttlebody. That did the final trick. To be safe, I ended up changing the TB gasket. All cheap fixes after spending a few hundred dollars listening to Mighty Mopar Men.
Dec 01, 2008 | 2000 Jeep Grand Cherokee
Garden Logo
69 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
