Question about Fedders D Chassis A7D18E2A Air Conditioner
Need Fedders Manual
Just bought it used and need manual badly
Coil is freezing up.rusted coil sensor bracket. i need a new freeze switch sensor for the front coil. i guess it turns the compressor on and off so the coil doesn't freeze solid. can't find the...
Buck, as you seem to be aware, Fedders no longer exist as the Fedders you may have been familiar with 8 years ago. Finding manuals and parts, is like looking for a needle in a hay stack. However, the new company Airwell-Fedders may be able to help you. There Customer Support Dept 866-829-2440, is who you need to contact.
There is one other possible source, as some parts are interchangeable. Appliance Factory Parts
http://www.appliancefactoryparts.com/airconditioners/fedders/ does carry some of the older Fedders Parts, as well as Maytag. So, that may be worth a try.
Hope this helps you find the parts you need. Good luck and please let me know how it worked out for you. Thanks.
Jun 11, 2011 | Fedders A7DH45B2A Dehumidifier
Living in Burlinjgton Ontario Canada. Looking for owners manual. How can I get one?
Henry, unfortunately Fedders as you knew them is now out of business, A company by the name or Airwell bought parts and manufacturing and it's now call Airwell-Fedders. You particular model is no longer available. However, if you contact Airwell-Fedders Customer Service 866-829-2440 or email them customerservice@airwell-fedders.com they should be able to help you with the manual.
Good luck. I hope this helped you.
May 24, 2011 | Fedders SFPEB08F2B Air Conditioner
Need User's Manual
Fedders made exact same unit for Maytag. Juts a different model number. The link below is for the Fedders Owners Manual. You can download and print the pdf format for the manual,
http://www.retrevo.com/d/df/document.pdf?doc=1361468de71c8749530c445c5e979550&ts=1304020994998&rk=0.4552581818908856
Hope this helps you.
Apr 28, 2011 | Maytag MEY12F7E Air Conditioner
I was looking for a manual to download, the fan is bad and I need a parts list. The download on the manual section did not work
Fedders made that unit for Maytag. Check the Fedders website for the same model number (just drop the M off the front of the model number) and you should be able to find what you need.
Apr 25, 2011 | Maytag M7DH45B2A Dehumidifier
Can't find a manual for air conditioner
BTU means "British thermal units" and is a measurment of cooling and heating capacity. Other units are Kw "Kilowatts", and HP "Horse Power".
To convert
Multiply by
To obtain
kW
1.341
hp
kW
3,413
Btu/hr
hp
2,545
Btu/hr
May 21, 2010 | Fedders Q Chassis A6Q10F2A Air Conditioner
We have a Fedders window unit and we do not have an owners manual. When we plug it in it beaps and then blows air for 2sec and then it goes off with the signal E3 showing in the digital box. We need to...
Without the model number, I can't point you to the exact manual for your particular unit. However, here's a link to a web site that has about 38 manuals for various Fedders models. You can download a manual and/or users guide for free and look at the operation and troubleshooting sections to see what you need to do to get your unit working properly.
Just scroll down the page once you get to the web page to locate your particular model number, then click on it.
http://www.retrevo.com/samples/Fedders-Air-Conditioner-manuals.html
Hope you found this helpful and best regards!
Aug 06, 2009 | Fedders Appliance Air Conditioner Wall
Need Owners MAnual
Go to safemanuals.com and then to this link: http://safemanuals.com/user-guide-instructions-owner-manual/FEDDERS/A6Y12F2B-E-_E
to get your manual. If its not the specific one, put in ur request and leave ur email. They will inform you the moment they find one.......sodeep
Jun 25, 2009 | Fedders A6X05F2D Air Conditioner
Fedders a need manual/crooftop unit on popup trailer
http://www.fedders.com/ds_info.asp
Browse this web site and you might be able to find what you need.
good luck
Jun 20, 2009 | Heating & Cooling
Fedders D Chassis A7D18E2A Air Conditioner Logo
149 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
