Question about Panasonic SC-HT75 System
STAND BY MODE
THE SYSTEM SEAMS TO GO INTO STAND BY MODE FOR NO APPARENT REASON IT CAN RUN PERFECTLY FINE FOR 15 -16 HOURS THEN FOR NO REASON IT WILL SWITCH TO STAND BY MODE AND WILL CONTINUE TO DO SO AT DIFFERENT INTERVALS COULD 1 - 2 HOURS THEN 3HOURS A SO FORTH. HAD IT TO A REAIR SHOP AND THEY ARE SUGGESTING WE REPLACE A BOARD AT A COST OF APPROX 200 DOLLARS. CAN SOME ONE OUT THERE HELP - HAS ANYONE ELSE HAD THE SAME PROBLEM
We had a similar thing (after using it for 4-5 years). After haveing it on for e few hours
some resistance or condensator or so gave a sound (bang) and it went back in the stand by mode. Now it really broke , while showing in the screen "F61" which means that there is something wrong with the eletricity supply. Well, we will start from there with an official repair man. Let you know what it takes to get it repaired. Frasha
Posted on Mar 07, 2008
SOURCE:
I have a 1994 Toyota Camry. It will run perfectly for several days then I'll go out and it will not start. It will crank and crank without starting. Then for no apparent reason after several hours, it will...
First have your starter tested by a shop or an auto parts store like NAPA, Auto Zone, ect. If its not that move on to ignition problems, I.E. coils, plugs, wires. Since you already changed the fuel pump and filter it shouldn't be a problem with either of them. Unless its a problem within something inline on the fuel system.
Dec 03, 2013 | Cars & Trucks
I need to reset my remote start. My car is starting every three hours
Your remote starter is in timer mode. Pressing the lock and unlock buttons simultaneouly activates the timer mode. When you activate the timer mode the vehicle automatically starts every three(3) hours and runs the preset runtime for a maximum of six(6) starts.
You can cancel the timer mode by starting the vehicle with the key. If the timer mode is a problem then apparently you are setting the timer mode everyday.
Sep 30, 2012 | 4103P Python 413 Remote Start System with...
The fridge isn't cooling though the freezer half is working fine. It was recently transported quite a distance in its side (well braced and padded), and left to stand 20 hours before being plugged in. We...
There are 2 reasons. While transporting if they lifted with won wards to discharge side, chances are there to oil entering. And while switch on it starts pumping the oil.Secondly, chance for gas leak.
It's advisable to remove gas and check for leak. If no leak, flush out the system and replace drier.
Vacuum and do gas charging. Please write if it's helpful.
Dec 31, 2010 | Heating & Cooling
Hi If I turn on my HS 100 it will freece at
From what you describe, it sounds as if one of the microprocessor(computer) ICs is defective, or the soldering to it. For more information, please visit my website at audioserviceclinic.com. Thank you.
Oct 30, 2010 | Harman Multimedia HS 100 System
My 2006 Ford Focus sometimes won't turn over. Had the battery and starter replaced and same problem. Happens about once a week. Hot or cold doesn't seem to matter. Just out of the blue it won't turn over....
Try moving the gear selector to neutral . If it starts then the transmission range switch (park neutral position switch ) That is if i'am under standing you correctly . When turning the key to the start position nothing happens ?
Nov 24, 2017 | Cars & Trucks
Intex Krystal Clear Saltwater Water Sanitizing System
Code 93 means the system is in Stand By (Operation Finished) mode. It will start the next cycle in 24 hours and run for the number of hours you have set, Codes are: 88 Stand By (Start Up) 00 Zero Operating Hours 01 Min Operating Hour or (1 Hour Remaining) 02 thru 12 Operating Hours remaining 90 Alarm Code (Low Water Flow/No Flow) 91 Low Salt Level 92 High Salt Level 93 Stand By Mode (Operating Process Finished)
May 30, 2010 | Intex Automatic Salt Water System for ...
Tsunami computer power saving mode problem
When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key.
Jan 12, 2010 | Zeus Components Tsunami DV (SYTDVXP2800A)...
Sharp Aquos LCD intermittent display
Hi there.
The backlight inverter board is defective.
Replace it and your problem will be solved.
Oct 15, 2008 | Sharp Aquos LC-45GD6U 45 in. LCD HDTV
Mr heater 75,000 btu kerosene heater
HLS should stand for high limit switch(control) this model does show one in the parts diagram.
Feb 27, 2008 | Mr. Heater MH75KT
Error message/Switching off
Hi.
What is the model number on the rear of set & chassis number if it has one.
Oct 10, 2007 | Televison & Video
Panasonic SC-HT75 System Logo
91 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
