Question about Garden
Cant figure out what is wrong
It's firing it was sitting in a shed for at least 5 years with gas in it
    New Friend:
Take apart the carb and clean it with carb cleaner. Be careful when you pull off the bowl some of them have springs that are tricky to put back in. Drain all the fuel that was in the tank. Check the plug and make sure it's still good if it hasn't run in 5 years then it's probably still good a visual inspection should tell. After the carb is clean put it back together and it should start right up.
Posted on May 01, 2013
2 Suggested Answers
SOURCE: Lawn mower won't start
Take Breather element off,and try to start it Then or if it starts that way cut it off and replace the breather and if it doesn't start You May need to change spark plug also, As if You have flooded it, Gasoline will kill a spark plug
Posted on Mar 27, 2013
Will not autostart sitting in shed for 3 years new. autostart turns over but no combustion or limited combustion in engine how do I choke this engine?
If it was sitting for 3 years, I would do a complete tune up. Oil change, air and oil filters, plugs and put in new gas. Good luck!
Mar 15, 2016 | Garden
Honda Harmony II HRR216 won't start
Check for spark of smell of gas on the plug when you try to start it. That will tell you if it is fuel or ignition
May 18, 2013 | Garden
Mar 27, 2013 | Garden
110cc suzki wont stay idling
Hi, Mark and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
13. Multi carburetors not in sync.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
DRZ 110 wont stay running
How to fix dirt bike that wont idle
Kawasaki KLX110 Service Manual
OEM parts for Suzuki
http://mybikemanuals.com/suzuki
Jun 12, 2017 | Suzuki Motorcycles
Craftsman LT2000 w/ 18.5 HP B&S engine- will not start-been sitting up for year in shed- new battery- checked fuel flow to carb: OK - checked spark plug: cleaned , seems OK- engine turns over but not...
A 'cranks but doesn't start" problem just needs to be narrowed down to compression,fuel,or ignition.The compression is pretty obvious-does it sound like the stater is getting a load when cranking?The next one is fuel-do you smell raw gas fumes coming out of the exhaust?The last one is spark-take the plug out and clamp it to the block,crank it,do you see a spark? If you have compression and spark,try a shot of starter fluid down the carb.(sometimes the float needle can get stuck,and just getting the engine to fire will shake it loose).If you don't have spark,then look for why(not sure if you have a magneto or ignition coil system).
Apr 14, 2012 | Craftsman Garden
My car has been sitting for 2 years and won't start. The engine turns over but it sounds like not getting gas. I read somewhere to spray gas starting inside air intake valve. Where is the air intake v
Safer is to use 'carburetor cleaner' which is also flammable but a little less dangerous than using gasoline.After sitting a long time, our modern gasoline gets tired; never allow something to sit so long without adding some 'fuel stabilizer.'If possible with your car, I would drain (siphon) the tired gas out and replace it with a few gallons of fresh.
Really tough starting problems can also be overcome with 'starting fluid' which is pure ether and very flammable.Any of these may require the removal of the engine air filter so the liquid gets into the intake manifold.
Stale gasoline can also gum up the fuel injectors which may have to be removed for service if none of the fluids causes the engine to fire.
Nov 23, 2011 | 2005 Jaguar S-Type
The 1990 XJ6 has been sitting for the last 2 years and now won't start. The engine turns over fine. The dash gages don't seem to operate. I filled the gas tank with 5 gallons of premium gas. HELP!!!
I wish I could give you an instant fix, but I can't. Do you have spark? If so then its either your fuel pump or the CPS, crank position sensor. If no spark then it could be your coil.
Nov 12, 2011 | 1990 Jaguar XJ6
I have a bored out 281 xp, I just put a carb kit in it but I still cant get it to run properly, at idle or full throttle it sat in a shed for five years but i thought that would help, it didnt
Check if the fuel lines are still intact. More importantly, the introduction of ethanol into the gas supply has caused many issues with small engines, because of its corrosive nature. Sitting five years might have done this saw in with its effect (even if the tank is emptied) on internal parts.
Oct 29, 2011 | Husqvarna Models 181, 281, 288xp
Saw will start. runs a little sluggish at first. then it will smooth out and rev high and run strong for a few minutes then gets sluggish again and dies. will not start again for 5 to 7 minutes minimum....
Being springtime, I'm thinking you may have had your saw sitting all winter with last years gas in it. If so, you'll need to clean the carburator and spark plug real good, then put fresh gas in it. Always remember to run your saw out of gas before putting it away. Gas only stays fresh for a few weeks and will foul up your sparkplug as well as plug up the inside of your carb when it gets stale.
May 03, 2011 | Garden
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
