Question about Vizio M3D650SV 65" 3D 1080p LED-LCD TV - 16:9 - HDTV 1080p - 120 Hz M3D650SV
Need replacement vizio lvds cable
Wide vertical black stripe on left side of video screen. Replaced Main board. Suspect LVDS Cables Part # 0460-3441-0180 and 0460-3451-0630. Where can I get them
Axle80
  • 73 Answers
SOURCE: 50" Plasma Vizio P50HDTV10A - no video - just flashing B & W
Don't replace anything, Vizio has issued a lifetime warranty for this set because of this problem. No joke, call the customer service line and tell them you got the pop of death. They'll send someone out to 'repair' the set free of charge. If they can't fix it they'll give you a new one. Even if your mfg purchase warranty has expired. Call them and post the results. I've been fixing TV's longer than I care to admit and this is the first time I've actually seen a company stand behind their products like this. I bought a broken tv with the intent of fixing it and after replacing almost every board I could only manage to get the vertical racing stripe line, except mine was purple. I put it all back together and called to find out if there was a recall on this set and within 5 minutes the (Actual English speaking) gentleman told me to sit tight and he'd have a repairman come and do his thing. He did, and long story short, he couldn't fix it. Last week they delivered a new TV to replace this one. I was shocked. I think Vizio will have all my future business.
Good luck.
Posted on Mar 23, 2009
SOURCE: 52" VIZIO LCD backlit with no display
Hi Crewzen,
I have the same problem as you. You just didn't mention which was the culprit. I assume it was the mainboard, correct???
Thanks
Posted on Jul 25, 2010
budmrtn
  • 11361 Answers
SOURCE: My Vizio HDTV has green/red snow on dark/white
Usually if the LVDS cable between the main board and the T-CON board is bad, you will loose one of the three color signals, you may have thermal problem with the T-CON board. I would run the TV with the back open to see if it will take longer for the problem to appear, or get a can of freeze spray for electronic troubleshooting and cool down the T-CON board (board is under the metal shield that you will have to remove to get to all the cables, I would remove the shield and put the screws back in to keep the T-CON board in place).
The TV as shown in my album has bad T-CON board, the pictures get pixelated and scrambled after about 1/2 hour, I was using a small fan to keep it cool until I finally found a replacement T-CON board. Bad LVDS driver IC on the main board can also be the problem. Right now we need to find out if it is heat related problem or not.
http://s807.photobucket.com/albums/yy352/budm/VIZIO%20L32HDTV10A/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Dec 31, 2010
Slinteriors
  • 8617 Answers
SOURCE: how to replace lvds cable
The LVDS cable has a small tab on either side of the connector which gets pressed in so the connector can be slid out of its socket.
Posted on Feb 11, 2012
mullen5
  • 93 Answers
SOURCE: How to fix Multi color Vertical Lines on a Vizio E470i-AO TV
Does the menu function display the same lines? What kind of cables are using ? (HDMI, Component vid, S-video, co-ax)
Were you as tenacious checking all cables/connections as you were the electronics? Lets rule out this all too often over-looked possibility.
Do you still get the lines with nothing connected to the TV? (no source connected)
Posted on Feb 28, 2016
Testimonial: "The lines are present with nothing connected I am not able to see the menu screen. I turn it on and all the lines are there no image."
I have vertical lines on my vizio screen, and I already replaced the t-con board. Should I replace the lvds cables and or the main board? Or is there something else that I can do?
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 03, 2016 | Vizio Televison & Video
Feb 28, 2016 | Vizio E-Series E470I-A0 47" LED TV...
Vertical black bar on my LG 47" LCD shifting the image to the right
Two possibilities are there. The first one is, with loose LVDS cable, that connects the T'Con board to display panel. The second is the fault with its main digital processor board.
May 21, 2013 | LG 47LC7DF 47 in. LCD HDTV
The picture looks pinkish sreen
Does it do this on all inputs? I had a problem like this, turned out to be a defective LVDS(cable from the main board to the t-con board)cable. To see if you have this same problem, wiggle the LVDS cable at both the main board side and t-con board side. If wiggling the cables clears up the problem, your cable is bad. They can be ordered for about $15
Jan 21, 2013 | Vizio VO47L 47 in. LCD TV
Today my 55" vizio screen popped and then turned red. I unpluged and restarted everything and now the audio is on, the chanels change, but the screen is completely read. some images are readable.
If this is a VO47LFHDTV20A TV set, the problem is most likely your LVDS(cable from the main board to the t-con)cable is faulty. When you turn the set on, do you have a red screen instead of the standard blue screen? Do you also have red tints on all images on all inputs? If this is the case, your LVDS cable is bad. If you are comfortable opening up your set, track down where the LVDS cable goes into the t-con board. Turn on the set, and wiggle the cable, if the red tinting goes away, you will need a LVDS cable, about $24 part.
Dec 09, 2012 | Vizio VO47L 47 in. LCD TV
Vertical green haze on right hand side
You have a bad T-Con (timing control) Board or a problem with a cable going to it
This link shows some examples to compare to and gives some repair info and pictures
Bad T-Con Boards LVDS Cables and Ribbon Cables
Jun 07, 2012 | Vizio 42 in. LCD TV
How can i fix gray line in center of screen of my vizio e320vp
Check lvds cable and ribbon cables going out of t-con board going to the lcd panel.
Nov 14, 2011 | Televison & Video
My screen has vertical coloured lines on the screen. which part should i replace?
Replace the D board! That is the 5x5 board behind the main board with all your jacks on it. Be very careful disconnecting the LVDS cable from the top of the board and the ribbon cable that is on the left side. The connector for the ribbon cable is very delicate, so be careful. UN_PLUG THE SET FIRST
Apr 13, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
Big black bar in the middle of the screen vertical
You will need to replace the Main board and I would also replace the LVDS cable that connects the main board to the LCD panel. Very easy to do, but might take about 2 hours depending on your comfort level.
You will need:
Screw Driver
LVDS cable – Part # 0500-0505-0540
Main board – Part # 3632-0652-0395
Those part numbers will work if you have a model number VOJ320F1A.
If you post the model number I will try to find the part number for you.
thanks
Aug 11, 2009 | Vizio L32 32 in. LCD HDTV
Lg 37 inch lcd has a dark shadow vertical line down left side of screen about 1cm wide and does not seem to go right to the top or bottom and is slightly wavey
reseat the LVDS cable inside the set. this is the multi wired connector that connects the main board to the panel. if that doesn;t solve your problem replace the main board. if you turn off the set and you can still see it in the screen it is the panel.
Feb 14, 2008 | Televison & Video
Vizio M3D650SV 65" 3D 1080p LED-LCD TV - 16:9 - HDTV 1080p - 120 Hz M3D650SV Logo
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
