Question about Klipsch Audio Players & Recorders
Subwoofer no sound - Klipsch Audio Players & Recorders
  • Daniel Mann May 01, 2013
    My Klipsch 12" subwoofer isn't putting out any sound through either LFE or speaker-level input. The light is blue to indicate that it's on, the fuse isn't blown, and the actual speaker driver itself is fine. Just no sound :(
  • Klipsch Master
  • 15,557 Answers
Try connecting another speaker to see if it is the amp
Posted on May 13, 2013
Sony sa-wm500 subwoofer is crackling
If the sound is a scratchy type of sound then the voice coil has been damaged and is rubbing up against the internal magnet producing the scratching and low sound since the cone is barely moving;.
May 19, 2015 | Sony SA-WM500 Subwoofer
When the volume is low the subwoofer sounds good, but when you go up a little volume, the sound is more acute. I have two subwoofer 1000rms each, when use 500rms power aprox, it sound great, but when
If the sub doesn't appear to have any damage like broken surround or a torn spider then I would suspect the amp may be having problems. What impedance are the speakers, what impedance can the amp handle, how do you have it wired to the amp?
Feb 23, 2014 | Fusion FEW12PK Car Subwoofer
My gigaware subwoofer wont work
Audio subwoofers are used to augment the sound quality that is released by stereos and other audio component systems. As a result of actively using subwoofers, the sounds projected from the sound systems (such as music and voice) not only become louder, but also have a fuller output. Subwoofers, however, are not immune to problems. These issues often result in distorted sound.
Issues Among the most common problems of audio subwoofers is the loss of their bass effect while playing music or other sound files. The majority of people that experience this problem do so because they have installed their subwoofer on a different sound system than the one where it was originally installed. Additionally, there are scenarios where the subwoofer does not produce any sound. b> Troubleshooting b> Subwoofer issues are typically caused by one of two things: improper settings or broken receivers. You can troubleshoot the lack of bass or other sound effects that decrease the quality of sound by checking and adjusting the settings of the subwoofer as well as your audio system. Although subwoofers work on almost all types of audio systems, some have to be adjusted to ensure quality sound while utilizing them. Broken receivers, on the other hand, have to be replaced with new ones. b> Significance b> Fixing subwoofer problems proves to be important, not only because it will increase your enjoyment while listening to music, but also because utilizing a subwoofer improves the audio system's overall performance. When subwoofer issues go ignored, there is a tendency for the audio system to become overworked, as the user likely works the controls on the audio system rather than using the subwoofer's settings. As a result, additional audio problems may arise due to playing at full-blast volume and making other unnecessary adjustments to compensate for the lack of a subwoofer. b> Recommendations b> One way of handling subwoofer issues is by reviewing the owner's manual, paying special attention to the speaker settings. Different audio systems have their own recommended settings to ensure quality sound and that all the effects can be felt and heard while the sound file is being played. If the manual does not provide any recommended settings and/or adjustments, tweaking can be done on the audio system's subwoofer menu to create your preferred sound. Through tweaking, you will be able to find the desired quality, as well as detect and correct any unnecessary noises and vibrations coming from the subwoofer. b> Maintenance b> Audio subwoofer problems can be prevented by regularly cleaning and maintaining both the subwoofer and the audio system where it is connected. The speakers should be dusted off periodically to ensure clean release of sound and the wiring should be checked for open exposures. These exposures should be immediately repaired to prevent further damage. Fix a Subwoofer b> A subwoofer, or a "sub," is an important part of your overall sound system, whether it's in your home or car. A sub's most important quality is bringing out sounds you can feel rather than just hear. However, they are also susceptible to wear and tear from overuse, and the sound quality will be greatly affected by this. Here are some steps to fix a subwoofer.
Check with your manufacturer's Tech Support Web site. Usually with a subwoofer, the problem lies with the voice coil, which might just be burned out. These are usually fixed by sending them into the manufacturer, so determine how much you want to spend to repair it versus how much it would cost just to buy a new one. Roam through the Tech Support forums. It's likely that someone had the same problem as you with your sub, and you can run the symptoms past a few other consumers to see what diagnosis they found. Identify the specific problem if you can. You can look for tips to fix this problem on the manufacturer's Web site, or if you're technically savvy, you can try opening the sub and looking at it yourself. Two major manufacturers of subs include MTX and MK Sound. Check the bronze-colored coil underneath the foam cover. Note whether it looks worn, burned, warped or distorted. This may be the cause of your sub sounding fuzzy or muffled, which means it needs replacement. Look at the fuse inside the speaker and test it if you know how. This is a likely problem that causes your sub to power up improperly, play sounds at about half the volume or intermittently fade in and out. If the fuse is discolored or shows a short, you'll need to replace it.
b>
Jan 28, 2013 | Computers & Internet
8 INCH MTX ROAD THUNDER SUBWOOFER WON'T WORK NO SOUND NO NOTHING
has it ever worked, if so did you ever use it in the cold because in the cold it is possible for the wiring inside the speaker to crack and break
Oct 29, 2012 | Velodyne CT-80 Subwoofer
I Need To Know What Size Box to Build.. To Get The Best Sound Out OF The R 10's
Depending on the amount of speaker that you have, Alpine recommends that you use anywhere from .85 cubic feet to 1.25 cubic feet per subwoofer. This choice will be reflected by the sound of your subwoofers. If you choose to use .85 cubic feet per subwoofer, you will get a tight sound without excessive cone excursion.
However, if you decide to use 1.25 cubic feet per subwoofer, your subwoofers will hit lower notes and be able to handle more power.
These are factors that you, as a listener, will have to bear in mind when choosing a subwoofer enclosure. Regardless, enjoy your speakers!
Jan 16, 2011 | Alpine Type-R SWR-1042D Car Subwoofer
How to set up a soundbar with a subwoofer. Where to place the subwoofer. Does it need to be behind us? Is it ok if its in a corner? Will it sound as good if it is in front of us next to the tv?
The subwoofer deals with low frequencies, which are not very directional (ie, it's harder to tell where the sound is coming from).  So where you put it isn't critical to the sound, provided that it's not behind curtains or something that will soak up sound.  The bigger speaker you have in your subwoofer; the less important the position is.
Putting it in a corner is something you're going to have to try, but you may even end up with better bass if you do, as a corner can act as a soundbox and emphasise bassy sounds.  Conversely, your subwoofer may not like being in a corner and interference effects from the sound reflections could degrade the sound.  Like I say, try it and see what it sounds like.  It depends upon your subwoofer, what else is in the corner, precise positioning, and how reflective to sound the corner is.  If it sounds terrible, move it a few inches and try again.
You can put it in front of you next to the TV, no problem.  The only downside it it's a big ugly box.  My wife always makes me hide my subwoofers behind something.
Mar 23, 2010 | Sony HT-CT100 Theater System
Subwoofer output no sound...
Check to see if it is properly hooked up to the player, and if it is, then either the amplifier's LFE(Low Frequency Emitter/Subwoofer) channel has failed, or the CPU is not beginning to forward frequencies 200Hz and below to the subwoofer. At 200Hz, the subwoofer adds to the satellite speakers, an then at 110Hz and below, only the subwoofer is playing.
Feb 28, 2010 | Samsung HT-DS630T System
I am trying to hookup my AL subwoofer to my existing comp system.Inserting a wire jack into one of the comp spkrs and subwoofer shuts the sound off.?? It is a FMC0034326 Altec Lansings Subwoofer.Thanks.
You can't just do that. Your sound card needs to have a specific jack just for subwoofers. If you plug it into the speakers, the computer recognizes the subwoofer as a pair of headphones and routes all sound through it. Remember, a subwoofer is not a normal speaker. It only allows a frequency of extremely low sounds (a.k.a. BASS) and won't play anything that you would need a tweeter for.
Jun 11, 2009 | Altec Lansing Multimedia Computer Speakers
Connecting a subwoofer to JVC KW AVX800
Hello pmdharan, It sounds like the subwoofer is not turned ON. Go to MENU ITEM > SPEAKER SIZE >SW (subwoofer) and select ON. Hope this helps.
Jun 06, 2009 | JVC KW-AVX800 CD Player
Built in subwoofer not working
check for the volume of the subwoofer
see the voume sttings
Mar 28, 2009 | HP Audio Players & Recorders
123 people viewed this question
Top Klipsch Audio Players & Recorders Experts
rhodesworks
richie46
Are you a Klipsch Audio Player and Recorder Expert? Answer questions, earn points and help others
