Question about Furniture
Fit vanity unit - Furniture
I want to replace my vanity top in the power room. i vanity top touches the wall on each side. I have measured wall to wall and it's 36 inches wide but all standard vanity tops are 37 inches wide. To...
yes simply remove the drywall from both sides of where you are installing the cabinet then either cut the old pieces to fit above and drywall tape over the seam where you cutthe old piece out or get a new piece of drywall and cut it to fit into the space above alternatively you can try to cut into the drywall perfect fit which you would then just silicon around to fill the seam
Jan 10, 2015 | Televison & Video
We have the Kokols Wallmount Bathroom Pedestal Glass Sink Vanity Combo but the p-trap keeps leaking. How do we fix it?
Remove it, (Don't forget water will come out when you uncscrew it!!!) clean it thoroughly, especially the ends, clean and check seating of any rubber washers to make sure they are fitted correctly and not being distorted when the rings are tightened, reseat it with no force (it should sit naturally without having to force it in) and tighten rings. There are lots of videos on youtube showing how. If you cant stop it leaking buy a new trap. It's worth while looking very carefully for exactly where the leak is before you remove the trap, it might be coming from higher up. Repair Leaky Sink Drain Pipe
Jun 21, 2014 | Kokols Clear Vessel Sink Pedestal Bathroom...
Does Ikea sell bathroom vanity units?
They do, however they are sold as separates. The sink unit and the mirror piece are sold individually, rather than as a complete set.
Sep 04, 2012 | Belle Foret Furniture
What are some current trends in bathroom vanity styles?
One of the more popular trends is floating vanities. A second popular trend for vanities is teak wood vanities. Below I have attached two pictures to help identify each type.
What is the most common type of bathroom vanity?
Cabinet style vanities are the most popular style. They are mounted on the floor, along a wall and have a mirror installed above. Here is what a typical cabinet style bathroom vanity looks like -
Sep 03, 2012 | Belle Foret Furniture
What are some of the styles to choose from in terms of bathroom vanities?
There are three main styles of bathroom vanities - shelf vanities, wall-mounted vanities and cabinet style vanities.
Removing silicone from a basin underneath while its stuck to the vanity
is the unit free from the wall? if so feed a piece of bare wire between sink and vanity wrap wire around two screwdrivers work wire back and forth with even pressure . you might have two double the strands of wire
Feb 26, 2011 | Music
Installing above counter sink and is leaking on
They make a replcement over flow kit.
Mar 21, 2010 | Plumbing
Fitting a door to Kenwood dishwasher KDW243A
Hello, Found this while looking for the answer myself. The vanity door fell off last night onto my foot and so needs must as it really hurt!
Anyway there are 2 top pillars that fit into the upper appliance door. Then there are two plates that need to set to finished height.
To fit. First insert the top pillars into the large openings. Now open the dishwasher door a bit, took two of us to get this right, and push the vanity door as high up as you can. Next slide the door back down and gently push the bottom plates into the recesses on the appliance door.
Job done! Well almost. When you have got this far open the dishwasher door completely. You will see a plastic white cover caps on either side of the door. Remove these and drop a screw into the hole.. Make sure you measure the screw against the vanity door so that the screw does not go all the way through!! Now screw the appliance door to the vanity door.. Now the job is now complete!
Hope this helps!
Jan 01, 2009 | Danby DPAC120061 Portable Air Conditioner
Furniture Logo
76 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
