Question about Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine
Husqvarna lawn tractor idles up and down then cuts off when hot.
I know not its not a clogged fuel line. once I let it set an cool off it works again for an...other 5-10 mins then same thing. turns over but doent seem to be firing...
  • Parks Optical Master
  • 7,482 Answers
Hi charlie
Hi
When your mower quits after it gets hot, you either have a problem with gas flow being restricted into the engine or with the spark. This is a common occurrence on older-model mowers. By replacing your spark plugs and keeping your gas lines clear you can reduce the chances of this problem recurring.
Possible Vapor Lock:
Vapor lock happens when excessive heat and vapors build up in the gas tank and aren't vented properly. Check for this problem the next time your saw dies when it's hot. Unscrew the gas cap, vent the gasses and try to restart your saw. If it starts you have vapor lock, and will need to carefully inspect the fuel tank's vent hole to see if it is plugged or damaged. Clean this hole with a brush and rag.
Possible Ignition Problems:
A common problem is an old or dirty spark plug. When the plug gets covered in black carbon the spark will have difficulty firing, especially when hot. You may also have a problem in the ignition module or the coil in the module. Again, run the mower until it quits and then squirt a little starter fluid into the open choke valve,
If it starts up you likely have a fuel system problem, but if it doesn't start, your ignition module or coil is likely almost finished.
Fuel Supply:
At certain times when the engine gets hot, the flow of fuel to the carburetor can get restricted. This can occur with a dirty fuel filter on the end of your main hose. The hose itself, when hot, can also lose its proper seal to the carburetor, restricting the flow. Replace your fuel filter and hoses on a regular basis, usually once a season. Try adjusting your carburetor's screws to see if you can richen the fuel mixture in the carburetor.
Other Problems:
A dirty or worn-out carburetor can also cause similar problems when hot. You should get your carburetor cleaned and serviced. Try installing a carb kit to older carburetors to help with the flow of fuel. A fuel pump inside the carburetor can also start failing and any warping in the diaphragms will also cause similar problems. You can check for a dirty carburetor by squirting a shot of carb cleaner into the open choke hole just after starting the engine. If you see a lot of thick, dark smoke pouring out the muffler, your carburetor is dirty.
Please take time to rate me
Bud
Posted on May 01, 2013
2 Suggested Answers
dataware
SOURCE: Husqvarna 2009 Tractor Run 30 minutes, sputter, loses power, dies
Replace/Rebuild Fuel Pump, Carbureator. STOP using Ethanol Gas
Posted on Jul 26, 2012
Why does my husqvarna riding lawn mower engine stall when I turn to the left
Probable something in the fuel tank that clogs the fuel line when you turn to the left.
Aug 16, 2014 | Husqvarna Garden
Husqvarna riding mower
It could be due to idling problems. See solutions in this video
Learn How to Fix Idling Issues on your Husqvarna Lawn Tractor
Also may need to make sure the carburetor and fuel filter are not dirty.
Aug 13, 2014 | Husqvarna Garden
Engine stops running when hot.
Sounds like the coil is breaking down when gets hot.
Jun 01, 2012 | John Deere Garden
Tractor runs fine for about one hour then shuts down and wont run
It might be overheating, check that it is cooling properly. It is a safety system to shut down one engine is hot.
Thanks.
Jul 18, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have a husqvarna YTH150 hydrostatic kohler motor 1995-1999 upon starting it takes many tries then when started its like its on a steady idle it'll idle high then low in a steady rotation until it cuts...
Sounds like fuel starvation, clean the fuel filter and lines, make sure there's no muck in the fuel tank. It's also possible the choke is sticking, although the exhaust would smoke and smell of petrol (gasoline).
Aug 20, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
The tractor stop at every 10 min. I wait 15 min it start again but after 10 min it stop. Please tell me what's the problem Thank you!
could have bad gas cap try running with cap loose see if works if not may have clog in fuel line bottom of tank or debris in needle valve in carb ,will let fuel in but not fast enough to keep up last option is u could have a bad ignition coil fails when gets hot then works when cools off hope this helps
Aug 10, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Engine acts like it is vapor locking.. Can Mow 30
heat related problem, probably needs the valves adjusted. When the engine gets hot the valve clearances change
Jul 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Going dead atfer fuel system simple repair.
Try checking the carburator, spark plug/wire, idle setting, tightening all the hose connections, and, maybe check the manual's trouble shooting guide, and if you still have problem with your mower, try and find a good repair shop and have them diagnose the problem.
Hope this helps! :)
Sep 06, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My husqvarna 46 in. cut back fires when i turn it off
oi the carburator gremlins are at it again!!!
ur gettin too much unburnt fuel in ur exaust
Jul 31, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine Logo
196 people viewed this question
Top Parks Optical Garden Experts
colesmowers
Renee Knafel-Bullock
Adam Jasar
Level 1 Expert
Are you a Parks Optical Garden Expert? Answer questions, earn points and help others
