Question about Denon AVR-3300 Receiver
Receiver will not output any sound
The receiver powers up fine and no fuses are blowen yet no power is being outputted to the speakers.
  • 1 more comment
  • Anonymous Nov 22, 2007
    Did not understand your directions well.
  • sprainedrose Dec 03, 2007
    I have the same issue. The unite powers up and drives sound into speakers in other rooms but won't drive the sound in the main room.
  • stevehayes Feb 29, 2008
    Same here.
    Was just using the amp, then loss of sound from the TV input, and from all other inputs.
    Amp seems to be working okay. But no sounds from any of the speakers, including the passive sub woofer attached!!
  • 58 Answers
1st Try to push (ON) A/B speaker Selector terminal. 2nd try to reset the speaker relay by put the volume on 15% and short-cicuit the speaker terminal for just 1 sec. with the power ON. Good luck
Posted on Aug 11, 2007
SOURCE:
It stopped, while not being used.
Possibly taken the fuses out suppllying the power stage.
Mar 12, 2014 | Sherwood RX-4109
There is no sound from left speaker
The audio output stage on the left channel has failed or blown a fuse. Check the speaker wires carefully, if okay! I recommend a pro to examine the receiver.
Apr 08, 2012 | Harman Kardon AVR 225 Receiver
I think my receiver just blew. hissing noise from all speakers, now i get no sound - but the display still works...help
unplug the receiver, Everything- speakers, input/outputs. The only cord to the device left should be the power cord.
Power up the receiver, set the tuner on a strong station. check sound quality with headphones only.
If that was ok, now pick one speaker to test all channels with. Follow the procedure above with the
speaker. check each output channel with the tuner as a source using the one speaker. Good Luck!
Sep 03, 2011 | Kenwood VR-8050 6.1 Channels Receiver
I just bought a 98 concorde lxi and no sound coming out of the speakers, radio comes on and shows channels just no sounds
Hello georgouseyes,
The problem could be in the output from your receiver to the amp or in the amp itself.
First check to see if the amp powers up. If it doesn't, check the main power fuse (usually located under the hood near the battery). Also check the power and ground connections on both ends.
If the main fuse checks OK, check both onboard fuses. There's 2 35A fuses on the far right.
If the amp powers up OK and the onboard fuses are not defective, it's possibly the output from your receiver or line output converter. Replace the RCA cables with a known good pair. If there's still no sound, I'd suspect that the amp itself is defective.
Hope this helps.
Oct 17, 2009 | Infinity 475A Car Audio Amplifier
No sound out of left speaker
did the left channel work when u switched speakers, if so then the left speaker or wiring is a fault.if not then the output circuits on the amp are blown or the fuse is blown some amps have internal fuses in the output to protect the output transistors. unplug the power cord and take the cover off, look to see if u can find any fuses and check these for continuity u can hold these up to the light and u should see a fine filiment in one piece and not broken. these fuses sometimes blow just from age and use at high volume like a regular light bulb.If the fuse is blown replace with the same value else the output transistors will need to be replaced most likley along with the drivers.
May 19, 2009 | Sony STR-DE135 Receiver
Mp3 connect yamaha rx-v995 ---> muddy sound
Try getting into the configuration menu of the MP3 player and adjust the output controls for external devices....it sounds to me like it might be too high and/or the wrong output decoding.
May 09, 2009 | Yamaha RX-V995 Receiver
No output to speakers
Yes inside should be 2 for the speakers and phen a power fuse
Dec 16, 2008 | JVC RX-318 Receiver
No output from outputs to speakers.
Usually the outputs are not fused, but you can go thur speaker white noise test and see if that works first. If it does, then outputs are probably fine, IF not then the output transistors are most likely bad. Let me know and we can try some other things thur live chat if you would like. Good luck Guru Jay
Oct 29, 2007 | Yamaha HTR-5650 Receiver
Technics SA-DA10 Receiver-no sound
Most of these problems are rooted in a failed power amp module.
I'm working on an older technics unit but with the same troubles.
Aug 08, 2007 | Technics SA-DA10 Receiver
No output on main speakers
I have experienced a similar problem with my Sony STR-GX57ES and took it to a certified tech only to find it needed the power supply replaced. I opted to hunt down a compatible power supply but have been unsucessful thus far. That being said I picked up an STR-D665 for next to nothing and found the power supplies to be quite different (you would hope so any, with the ES meaning Elivated Standard and all) but with the D665 working flawlessly I'd rather have something working than nothing. Good luck!
Dec 06, 2006 | Sony STR-D665 Receiver
Denon AVR-3300 Receiver Logo
284 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
