Question about All-Power America All Power 10000w Apg3090 Electric Start Generator
Carburator Leaking Gas is leakinging out of the carb
    New Friend:
    Problem Solver:
  • 9 Answers
The float in the carburator is not working the needle & seat. Probably stuck from gumming & trash..Try tapping on the carb with a small object ...If this works put some carb cleaner in the fuel & run it for a while... This problem is caused by letting old gas stay in the tank & carb. If that doesn't work take the carb apart & clean the needel & seat area.. Good luck
Posted on May 01, 2013
Carburator gas overflow
Hi, Kevin and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
My carb leaks fuel out of the overflow hose at the bottom of my carb
Carb overflow What could cause this to happen ninjette org
http://www.motorcycleforum.com/59-motorcycle-repair/96188-carb-leaking-gas.html
Carbs leaking Here is how to fix it
Carburetor Carb Leaking Gas How to Fix Repair it Motorcycle Honda DIY...
Mar 29, 2017 | GAS Motorcycles
Um dtf 110 fuel hose loose
Sounds like the carb overflow hose. It it's leaking gas the float in the carburator is stuck and letting too much gas into the float bowl, causing the excess gas to drain from this hose. You will have to remove the carb and set the float to the proper level.
Jun 14, 2012 | 2006 UM DTF 110
2002 sportster wont spray gas to the carb sometimes
Hi Anonymous, if you have a carburator the usual suspects are:
1. Damaged or restricted fuel tank venting system (gas cap).
2. Inlet system air leak.
3. Vacuum piston malfunction.
4. Accelerator pump leaking or no output.
5. Plugged bowl vent.
6. Fuel level (float chamber) too low.
7. Restriccted fuel supply passages.
8. Plugged jets or passages.
9. Worn or damaged needle or needle jet.
10. Enrichner valve not seated or leaking.
Good luck
Apr 02, 2012 | 2002 Harley Davidson XL 1200 C Sportster...
Gas began running out of the tube that exits the top of the carburator on the Yamaha TTR-50. So much gas that I had to use a gas can to put the excess gas into. It appeared to be leaking from the...
hi,sounds like the float in the carb is stuck in the fully open position,you will have to take the carb out,take the bowl off the bottom of the carb and inspect the float needle assembly,the little clip that holds the float to the needle valve may have come off,allowing fuel to run unchecked into the carb and ultimately out through the overflow..hope this helps..cheers
Mar 09, 2010 | 2003 Yamaha TT-R 125
How do I put the float and bowl back on my Troy-Bilt generator. Gas is leaking out of carburator unless gas is cut off. Also where does the spring goes?
The fuel needle sets in a recess in the carb. the retaining clip is attatched to the tab on the float and the needle attaches to the clip carefully install the fuel needle/float assembly into carb inster pin to retain float into carb replace rubber seal on carb. / bowl cover assemble
Dec 19, 2009 | Electrical Supplies
Truck starts, but has a hard time staying running. smells like gas under hood and smokes. could my carburetor be bad?
I wouldn't say that the carburator is bad, but it may have some defective components in it, like a sticking float or leaking gasket. Can you see any fuel leaking in or around the carb? You can purchase a carburator rebuild kit at most autoparts stores. You must have the right number for the carb. There is usually a metal tag attached under one of the bolts that hold the carb to the throttle body that will have the number on it and sometimes it is stamped on the carburator body. Before you dig into the carburator, however, check for more mundane causes, like a faulty or fouled spark plug. Hope this helped and best wishes.
Jul 31, 2009 | 1982 Ford F 150
Coleman powermate 2500 won't start and gas is leaking out of the
it sounds like mine I think it is the carb is clog up
I am still working on mine
Feb 04, 2009 | Coleman Powermate Proforce 2500 Generator
89 ford f 150 4.9
Spray starting fluid near the carburator if equipped. It may be a leaking main gasket under the carb.If you spray and the engine turns off. It is a vacuum leak. meaning the main gasket under the carburator .
Jan 22, 2009 | 1993 Ford F150 SuperCab
All-Power America All Power 10000w Apg3090 Electric Start Generator Logo
93 people viewed this question
Top All-Power America Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an All-Power America Electrical Supply Expert? Answer questions, earn points and help others
