Question about Iomega gdhdu2 - 2tb Select Desktop Hard Drive - External Usb 2.0
My IOMEGA 2TB won't turn on, power adapter is Ok
    Brigadier General:
  • Iomega Master
  • 3,400 Answers
A SUGGESTION,TRY A OTHER POWER-ADAPTER.
Posted on May 01, 2013
Iomega 2TB Prestige External Hard Drive NOT COPYING FILES
A shot in the dark but partition it as two 1tb drives.
Sep 02, 2017 | Iomega 2TB Prestige Desktop HDD USB
Loose hardware
There are not many parts in a hard drive.
  • Data platters (secured with 5 or 6 screws)
  • logic board (doesn't move)
  • Actuator arm moves rapidly to read data.
Some whining or crunching sound is normal. I'd say either the logic board is burnt out, the reader head crashed or the data platters have lots of bad sectors. If it isn't working or detected your best bet is to replace it.
Nov 24, 2012 | Iomega Minimax 2tb Minimax 2048 Gb Usb 20...
The device does not boot, flashing white light.
It's likely you have a failed drive. You might ask for help at http://www.iomega.com/support
Or if you need remote data recovery http://FreeDataRecovery.us
Aug 09, 2012 | Iomega Home Media Net HD Cloud 2TB (34766
Hi....my Samsung external HD G3 2tb won't turn on again after I erased all data on it. It is connected thru a hub to my iMac and taking off the power or USB and plugging back in won't do the t
It sounds like the drive has failed. The fact that you erased the drive just before it failed is coincidental.
Take the drive back and request a replacement under warranty. Also, demand that they destroy the drive in order to protect your data.
Feb 11, 2012 | Samsung Computers & Internet
I need a new internal power supply for my 2tb external its an Iomega prestige. I just want the part number for it so i can order a new one.
There is no internal power supply. The unit gets it's power from the computer. A USB port has 5 Volts DC.
Inside that external enclosure of the IOmega external harddrive is just an ordinary harddrive as used in a desktop computer. A SATA harddrive.
The harddrive plugs into a small circuit board with an interface on it, or there are cables, (wires), which come from the circuit board, and plug into the back of the harddrive.
It is this small circuit board that is usually the problem.
The solution to this problem is to simply just buy an economical external enclosure, and install the harddrive out of the IOmega into it.
Just one example from a quick search for an economical SATA 3.5 external enclosure,
(Note*
A laptop harddrive is 2.5 inches across in width. 2 and 1/2 inches.
A desktop harddrive is 3.5),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
Have additional questions or need clarification to what I have stated, please post in a Comment.
Regards,
joecoolvette
May 29, 2011 | Iomega 2TB Prestige External Hard Drive
Am I able to password protect the 34974 Iomega external hard drive? I am not interested in encrypting, just having a password so it cannot be seen by others
Plug your Iomega hard drive into the USB port on your computer. Click the "Start" button and choose the "My Computer" icon. Double-click on your Iomega hard drive's icon. Right-click in a blank space on the window and choose the "New Folder" option from the menu that appears. Highlight and drag all of your data into the new folder that you created. Right-click the new folder and select the "Properties" tab. Navigate to the "Sharing" tab and check the small box next to "Make This Folder Private." Click the "Apply" button and then choose "OK." Use your Windows login password to access the folder and the contents. Hope this helps
May 20, 2011 | Iomega Select 2TB USB 20 Black External...
Just brought 2Tb iomega hard drive, got home, pluged in, status light stays flashing and windows doesn't pick it up... Roy
> just brought ...
Just take it back to where you bought it, and get them to show you that it works.
If it does not work, they will replace it.
Dec 14, 2010 | Iomega 2TB Prestige External Hard Drive
No Power to External Hard Drive
Do you have access to a multimeter or voltmeter? If you do you can check the voltage coming out of the adapter and make sure it matches what the power adapter says it is. If it doesn't, then it is the power adapter. If it does, then it is the drive or enclosure.
Jun 21, 2007 | Iomega (33090) 250 GB Hard Drive
Iomega gdhdu2 - 2tb Select Desktop Hard Drive - External Usb 2.0 Logo
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
