Question about Pool & Spa
I have a raypak 11kw hot tub heater model # els-r-1102-2 got it used worked great . we adjusted temp it got to 120 then to low kept playing with it. then we had to use reset button now heater won't heat and reset button won't reset think this is problem ??? Don't have manuel , have replaced conductor and pressure switch. Need help and name of part
  • 5 Answers
SOURCE: No Heat from Spa
Tcarrigan,
Heater contactors "buzzing": Do you mean normal buzzing or extra loud buzzing? Loud buzzing or chattering can be caused by low voltage to a contactor. If normal sounds, then probably the relays on the contactors is working, but the contacts may be stuck, or burned enough so as not to make contact. First, get a voltmeter and check for 240 volts AC at the heater contactor terminals. If the voltage is low, most likely you need to check the contactors further. Check for dirty contacts, clean if needed. If the contacts are not moving when energized, then you will probably need to replace one or both of the contactors.
Posted on Jan 18, 2009
PartsCenter
  • 125 Answers
SOURCE: Jaccuzi hot tub will not heat?
sounds like it maybe the heater again. Have you pulled it out and checked the ohms? it should be at least 10.5 ohms
it could be the thermostat or the pressure switch - if either of those are not working it will not heat either.
Posted on Feb 24, 2009
SOURCE: low pressure reading on Pool Heater
I had this problem with ours last year. I replaced the water pressure switch and it began working fine. We later had a symptom that the blower would start but it would not ignite. The ignitor rod was corroded so I took it out and sanded it with some sandpaper---worked fine...until I dropped it trying to reinstall and it broke. Bought a new one and it works fine now.
Today's problem is related to the blower now.... it is always something, isn't it?!?
Posted on May 30, 2009
  • 244 Answers
SOURCE: richman gas lp tankless hot water heater. used for
I had the same problem with my Paloma a year and a half after installation...contacted Rheem\Paloma\Richman customer service (800-432-8373) and they recommened a local installer in my area. The technican diagnosed the problem as the "flow control valve"; he managed to get Rheem/Paloma to cover the part under warranty...I only had to shell out the money for the install.
Posted on Nov 11, 2009
slingspade
  • 6 Answers
SOURCE: My new heater does not work on my hot tub.
Test across both terminals at the same time. If you are getting 230V, disconnect power and check the resistance across the terminals. For 4kW, you should get roughly 13 ohms. If not, the element is bad.
If you get 0 Volts across the terminals, the tub is not heating. ManyBalboa packs switch both leads to the same leg of power, so you can get 120V to ground from each terminal, but you get 0V from terminal to terminal.
The clincher here is that the "heater on" light is off. I would double-check the pressure switch. You should test it with the tub running in heat mode. Disconnect one of the flag terminal leads from the switch, THEN test for continuity across the terminals. If you get none, you have either low flow or a bad pressure switch. You can verify by jumping the two wires together and see if the "heat" light comes on. Again, check for flow. I would run any of these tests with the filter removed. The symptoms you describe are very commonly caused by a dirty filter causing low flow. Again, pressure switch test. A bad sensor would cause the "current temp" to read too high, and a hi-limit problem would cause the little "heater-on" light to flash. Unless that little light is just dead (I've never seen it go bad), everything you say points to the pressure switch (or a dirty filter).
Posted on Dec 13, 2009
My Raypak spapak 11kw 1102 has deveolped a leak at the base of the heater tank. Small pin hole leaks in the copper tank. This is the second one to leak (replaced one two years ago) at the same place? Why...
make sure pool chemistry is in balance too low of PH and too low alkalinity will eat through the heat exchange copper PH should be between 7.2 and 7.8 alkalinity should be between 80 and 120
Oct 01, 2012 | Raypak Spapak Electric Spa Heater -...
Hello, please tell me what breaker (amps) do I need to use with Hayward 11kw Electric Spa Hot Tub Heater Cspaxi11. What is the normal amp consumption for this equipment? Thanks
Hi and welcoe to FixYa, I am Kelly.
11,000W is the maximum power that it could draw. Given the wattage is over 10,000 I am certain that your Spa / Tub heater is 220 VAC If it is 220 VAC then you will need a 50 Amp breaker. If it only 110 VAC you will need a 100 Amp Breaker. (Gasp!)
Amp consumption will always vary.
Heater on / Off
Number of Blowers and pumps in operation at any given time. Then add lights to the equation. My best guess at any given time it is in "full operation" it will average 6,000 - 7,500 watts. When not in full use it the average amp usage would drop substantially.
Thanks for choosing FixYa,
Kelly
Feb 21, 2011 | Hayward 11kw Electric Spa Hot Tub Heater...
ELS 1102-2, THE HEAT CONTROL IS SUPER SENSITIVE. THE SLIGHTEST MOVEMENT HIGHER AND THE WATER IS TOO HOT, THE SLIGHTEST MOVEMENT LOWER AND THE WATER IS TOO COLD. THIS IS A FACTORY INSTALLED...
Mechanical thermostats such as the one in your heater are only accurate between 3-5 degrees once set. Unlike a digital thermostat that is accurate to .1 degrees. You can purchase an aftermarket thermostat for $120 that is digital and can be installed in your heater.
Jan 29, 2011 | Raypak 130,000 BTU Propane Gas Pool...
I have a 2004 great lakes hot tub with a balboa controler. My hot tub heats up fine when the pump runs on high but the temp light never comes on when the pump runs in low.
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
Feb 04, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
My Raypak versa gas heater for my hot tub will not heat the tub more then 96F, temp control is turned all the way up, just stated doing this, it was fine for a year, thanks
Water flo through the heater is too fast and the water can't get hot enough. Your by-pass valve is stuck closed and you need to open your water header and check it out. Or you may have an external by pass that need's to be opened 10-20%. This will be a valve between the inlet and outlet water pipes going to the heater. Good luck and HAPPY NEW YEAR.
Dec 24, 2009 | Raypak 130,000 BTU Propane Gas Pool...
Can't get my commercial hot tub heater to fire up
It sounds like this is in your circut board and I could not begin to tell you how to check this without tools and diagostnic equip. Sorry but it may be time for a pro. Good luck
Nov 10, 2009 | Raypak 130,000 BTU Propane Gas Pool...
Pool & Spa Logo
35 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
