Question about Ruud UAKA030 Air Conditioner
Condenser fan mounting
What direction should the fan blade rotate when viewed looking down at unit? What is the blade mounting height?
  • 50 Answers
Most condenser fan turn ccw looking down into the unit and should be mounted about 1" from motor. A good check is that the air is moving up and out and drawing through the condenser. Thanks
Posted on Aug 10, 2007
SOURCE:
Water dripping from Friedrich Air Conditioner CP05 model annoying downstairs neighbour. Is there a drain hose for this model? Other solution?
Window unit A/C units must be mounted level side-to-side and slightly tilted down to the outside coil The condensation (water) that forms on the cooling coil drips from the coil and collects in a metal tray. The slight tilt of the case allows the water to drain toward the condenser coil and fan. The outside fan blade tip is positioned very close to the condensation water catch pan and the water is picked up by the rotating fan blade and thrown onto the condenser coil where it evaporates and accomplishes two things. This keeps water from dripping on the ground and lowers the head pressure of the system to improve the efficiency of the unit.
Aug 01, 2018 | Heating & Cooling
How does it matter which direction condensor fan turns
Yes. The fan is designed to draw air through the condensing unit to expel heat generated by compression and heat exchange in the refrigeration system. If the fan is running the wrong way, heat will not be disipated correctly and the unit will not operate efficiently. You could end up damaging the system.
Aug 18, 2014 | Dometic Rooftop RV Air Conditioner
I just replaced the motor to the condenser fan, after I put the blade back on, and finally got everything moved and screwed back down I am wondering if I put the blade on so the air flow is going in t
If you replaced the fan motor with the correct rotation replacement motor the fan should be blowing in the right direction or did I misunderstand what you are trying to explain? Sea Breeze If the part number is=> WR60X187 the motor should be turning clockwise rotation while looking at the motor from the rear. Thanks JT
Jan 26, 2013 | GE Monogram Side by Side Refrigerator
Condenser fan replaced one year ago, fan not turning but can hear motor
the answer to your problem is most likely the motor start capacitor. A AC motor can run in both directions. The start capacitor is used to cause the current to lag behined the voltage which determines the direction the motor will turn. Its posible the start and run capacitors are in one can. so changing one will change the other. However look for a wiring diagram. Do not asume that both capacitors are wired in properly. They may be fighting one another causeing premature failure.
Sep 18, 2012 | Carrier 38CKC036 Air Conditioner
Were is the reset button on the unit?
Hi, here is the theory on the reset button on Air Conditioners. They reset via the breaker panel box in your house. Check that first before anything else. However if your unit is popping breakers, it is because the rating for the breaker is incorrect, or there is something that needs servicing usually in the outside unit called the condenser. That piece contains the compressor. A faulty compressor and pop the breaker. Or If the condenser fan that blows over the coils of the outside unit stops (common failure) The compressor will overheat and shut down. That may not trip the breaker but the house will get hot anyway. Usual action for this is to replace the condenser fan motor and starting capacitor. Make sure the speed rating and directional rotation for the replacement motor is the same as the motor removed.
There are other reasons why the system won't come one fully. If the wall thermostat is digital and does nothing. including turning on the fan. There will be a small fuse located on the circuit board of the air handler (part of Air Conditioner mounted inside the house. It houses the circulation fan). That fuse could be blown. That one shuts down just about everything.
On air handlers mounted up into the attic crawl space there is an overflow pan. This pan is mounted directly below the air handler. This pan can fill with water when the drain pain contained inside the air handler starts to overflow because the drain system to that is clogged.
There is a "float switch" mounted in the overflow pan wired to the system in such as way as to shut down the entire AC system if that pan fills.
The handling is to clear the obstruction in the Drip Pan inside the air handler. Then remove enough water from the overflow pan and the AC will run as though nothing has happened.
If you have more questions, write to me on this site.
One thing more. The capacitor alone in the Outside condenser unit can fail and that will stop the condenser completely if it is of a "split" design and used for both the compressor and fan. When replacing this unit alone, ALWAYS find the same specification part.
I hope this helps,
Have a Happy New Year,
Mark
Jan 02, 2011 | Goodman CLJ30AR32 Air Conditioner
When the motor starts their is a rattle noise..When I looked in the back I noticed the fan blade had some play in it could that be the problem..
The shaft of the condenser fan motor will have some play in it, meaing if you are looking at it from the side, along the plane of the fan rotation, it will float to and from the motor itself, or left and right as you look at it from the side. You can isolate the noise by unplugging the refrigerator no less than 5 minutes, a minimum of 5 minutes and for at least 5 minutes. Before you plug the appliance back into the outlet, grab and hold onto the condenser fan blade, it will only be for a few seconds, and the motor is not strong enough that the blade will be ripped out of your hands. If you prefer, you can hold the blades in place by holding a screwdriver in between the blades instead. Plug the unit in, and if you still hear this rattle noise, its the compressor, not the fan motor. If you dont hear the noise, remove the screwdriver between the blades, and listen for the refrigerator noise as the fan motor starts up. If it made the noise then check for any obstructions to the fan blades, check that the three screws that secure the motor are tight, if they are loose, the fan will bounce. if they are tight, you probably have a bad condenser fan motor
Nov 09, 2010 | Whirlpool (ET1MTKXKQ) Top Freezer...
Can not find directions to reverse fan rotation for summer
it should be a simple slide switch on the side of the housing that moves up and down to change the direction of rotation of the fan motor and blades. look at the manual that came with the fan to make sure it has this feature but i personally have never seen a fan without one.
May 30, 2010 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Exhaust fan has stopped working Need to troubleshoot
Even though this is a pain, I need to suggest that you perform the following:
Remove the microwave from the mounting position as follows:
1. Place a cardboard box of sufficient height to have the microwave rest on it with no more than about a 4-inch drop. Cover the box with a bath towel.
2. Using a power screwdriver, remove the 2 mounting screws located in the overhead cabinet base. (microwave front will tilt down onto the box)
3. Firmly lift on the rear of the microwave to unhook it from the wall mount bracket.
4. Once removed, pull some slack on the power cord.
5. Slide the box and microwave forward (toward you)....enough to see the fan blades
6. Place a small cup of water in the microwave and press quick start (30 seconds)
7 Look at the fan blades. If NO movement, open door. Hand rotate blades a full turn to ensure free movement.
8. Restart microwave. (fan blades move - Yes/no)
If No, check power cable that supplies internal power to fan. Be sure it is connectied.
If yes - but only a slight movement - it is clogged with grease...remove it and spray with lots of Ammonia to clean fan elements. Shake excess moisture off. Retest.(fan blades move - Yes/no).
If yes, reverse removal procedure and enjoy....
If no, Replace fan assembly
Jan 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Frigidaire side by side model #FRS6R5ESBC
Fan rotation is determined by the motor direction of rotation. Cool air should pass over the compressor then over the condenser. Look from the motor end for the direction of rotation. Drive to driven. Motor is the drive and fan blade is the driven.
Jun 10, 2008 | Frigidaire FRS3R5EMB Side by Side...
Ruud UAKA030 Air Conditioner Logo
200 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
