Question about Kitchen Ranges
I have an Amana range in which the on indictor remains on when all burners are turned off. It just stays pn. How do I fix the problem? I have unplugged it for me an hour and plugged it back in and the loght still illuminates.i
    Prodigy:
    An expert who has answered 500 questions.
  • 650 Answers
I assume it is an electric stove. The switch for one of the elements has a welded contact internally in the switch. You will have to determine which switch and then order that switch for that particular burner element. Take care with wiring a new switch if it differs in appearance from to original switch. It may be better to refer the service to a professional.
Posted on May 02, 2013
the dr
  • 447 Answers
SOURCE: problem with electric range
Most likely the switch has welded closed
Posted on Sep 28, 2007
fridgetech
  • 473 Answers
SOURCE: burner will not turn off
I will need the complete model #. There should be a sticker near the bottom front behind the drawer. Can't use the # that is on the owners manual.
Posted on Oct 09, 2007
huuum
  • 750 Answers
SOURCE: whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone burners - the burner power indicator light stays lit whether the heat control knob is on or off, there is no heat coming from the burner on or off. You pulled the burner from the receptacle and one of the tabs broke off and stayed in the receptacle. You removed the tab and made sure no pieces remained in the receptacle then bought a replacement burner, no change. You put the replacement burner in the back burner of the same size and had heat within 10 seconds. You changed out the burner with the one that had been in the back of the range, no heat. As long as the breaker to the range is on the power light stays lit but no power to that one burner only.
What is the model number and the age of your range?
Waiting for your reply.
Huuum
Posted on Oct 03, 2008
Maytag317
  • 1136 Answers
SOURCE: Whirlpool Range Stove Top Indicator Light Stays Lit
Hi, You will need to change the burner switch as well. It shorted out when the element went bad.
Please let me know if I can assist you with part # or anything else.
Vic
Posted on May 30, 2009
SOURCE: burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Posted on Nov 03, 2010
Range light
the light stays on tell it cools down
Nov 29, 2011 | Amana AER5845QAS Electric Kitchen Range
Trouble with an Amana oven
sounds like a bad valve that needs to be replaced. If that doesn't fix it let me know but 90% of the time this is the problem and the fix.
good luck and let me know if you have any other questions with this
Jun 06, 2008 | Amana RanARG7302 Gas Kitchen Range
Electric range amana model number AER5515QAW right rear burner repaired 2 times by sears still broke again is the it defected wireing? how do i fix it
It sounds like the Sear's repair person should be looking at the amperage while the burner is in operation...there seems to be an higher output at sometimes.
Oct 27, 2009 | Amana ACS3350AS Gas Kitchen Range
Burner light stays on even if burner is off and stays cool
you have the ground wire for that burner on the wrong pin your loosing ground somewhere
so the sensor is reading hot
Sep 26, 2009 | Kitchen Ranges
Amana gas oven not working
The ignitor may be too weak to open the gas valve. If you have a volt/ohm meter capable of reading AMPS you can hook up to a ignitor wire and turn the oven ON. If you read less than 3.5 amps replace the ignitor. If 3.5 amps or more are read,replace the gas valve.
Aug 30, 2009 | Amana ARGS7650SS Gas Kitchen Range
Red light stays on indicating burner is on when burner is not on.
It should stay on after the burner has been turned off and remain on until the top has completely cooled down,if it stays on and never goes off, the thermostat for one or more burners is faulty and will need replaced.
Jul 26, 2009 | Frigidaire FEF366 Electric Kitchen Range
I have a GE glass cook-top electric range. burner stays on.
You need to replace the switch which controls the burner.
Apr 07, 2009 | Kitchen Ranges
Amana gas oven will not stay lit
i'm having the same thing happen to me however the broiler works fine.
Nov 17, 2008 | Amana ACF3355 Gas Kitchen Range
Whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
Huuum
Sep 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Burner on range will not turn off
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Kitchen Ranges Logo
43 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
