Question about Samsung HL-R4264W 42" DLP HDTV
Samsung dlp popping sound
If your Samsung DLP HDTV audio is crackling, or popping, check that you have it pulled at least 6"-8" away from the wall, and if it keeps happening, use a fan to blow air behind the TV from the Bulb side. It will keep it cooled down and take the audio issue away as long as it has air.
  • 192 Answers
SOURCE: HDTV Rear Projection
The color wheel is the most common problem when it comes to noise from DLP's. To determine if it is a color wheel or fan: Turn on the set. When the noise starts, turn off the set. If the noise goes away within 5 seconds, then the color wheel is bad. If the noise goes away after one to one and a half minutes after the set was shut off, then one of the fans are making the noise.
Posted on Apr 01, 2007
video-tek
  • 150 Answers
SOURCE: My Samsung 50" DLP HDTV keeps humming when the DLP lamp comes on.
Hi, you have one of two problems, either the color wheel is going or one of the cooling fans are going, the color wheels are a very common problem in samsung dlp`s, sorry I can`t nail it to a specific part but I`d bet it`s the color wheel as they are notorious for failing in samsungs, video-tek
Posted on Mar 26, 2009
coupondeal
  • 76 Answers
SOURCE: samsung DLP keeps turning off
http://guides.fixyourdlp.com/samsung/bp96-01579a.php
Light Engine assemble problem
Posted on Jul 16, 2009
Slinteriors
  • 8617 Answers
SOURCE: Obtain repair manual for Samsung DLP projection TV's.
You can get the service manual by download link within minutes from the following link. Just scroll down the page and you will see your model listed.
http://www.tvrepairworld.com/service_manuals
Posted on Dec 24, 2009
Testimonial: "Your solution was very timely and helpful. Thanks"
  • 336 Answers
SOURCE: TV made a big popping sound, and then a crackling
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php That crackling sound could be of the color wheel:The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is BP9601073A you can find original here:http://www.discount-merchant.com/Samsung-BP96-01073A-lamp-p/samsung-bp96-01073a-lamp-oem.htm?Click=48173 .Have a blessed one!
Posted on Apr 02, 2010
My 50 inch dlp makes a crackling and popping sound, then starts to fade out and eventually makes a loud beeping sound. how do i fix this?
Look to see if this happens at all inputs--tuner and rear first.
This issue is not clear to me---sound is popping or you are hearing a sound from inside the set?
Jun 16, 2012 | Samsung SP50L6HX 50" DLP HDTV
Have a 61" dlp samsung tv, making a humming sound
Bad Color Wheel.will cause this and it is a common problem for DLP Samsungs.
Part number is BP96-01103A
Samsung Parts 1-800-627-4368
Jun 24, 2011 | Samsung HLR6178W 61" HDTV
Apr 02, 2010 | Samsung HL-R5668W 56" HDTV
Had one last week and now there are 6. they are
You get white spots inside the samsung DLP tv due to bad Digital Micromiror Device , or bad DMD board .
What is actually the problem is the DMV chip connected to this board . Inside this chip are 3 million tiny mirrors ,and when they physically get stuck , they either show black or white instead of a color
This is well know problem with SAMSUNG DLP...
The DMD chip is failing.If not under warranty expect to pay a few hundred to several hundred to get it fixed
The mirrors on the DLP chip are slowly sticking either fully open (white) or fully closed (black). The part that contains the DLP chip is the Light Engine. It is the most expensive part of the TV.Only the Samsung TVs has this issue.
Replacing the DLP chip and the micro mirror would solve this issue...
Pleaserate this solution,
Rnj VINODKUMAR
Nov 11, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP made a "pop"
Sounds like your color wheel was warped and finally cracked and broke.
Jun 26, 2009 | Samsung DLP HL-P5663W 56" TV
2 y/ old Samsung DLP TV (HLR6167) - no sound
your problem is most likely not the Tv i bet you are using an air antenna arent you
Feb 16, 2018 | Samsung HL-R6167W 61" HDTV
Samsung HL-R4264W 42" DLP HDTV Logo
174 people viewed this question
Jerry Greenberg
Jerry Greenberg
