Question about Legacy Audio American Legacy II LA290 Car Audio Amplifier
Car audio amp (?) issue
My JBL car stereo head powers on, can change stations and shows that the CD is functioning...but the only sound coming out is a constant beeping from the speakers. There was plenty of warning regarding trouble coming as the sound would go dim, sometimes off and occassionally pop and make other odd noises unexpectedly before this happened. Any clue if this might be the head or the amp? Is there a way to remove the amp and have it tested? Any help is appreciated. Thanks!
  • tlewiss12 Aug 11, 2007
    Great to receive a response and then followup so quickly!
    The guidance is appreciated. One small snag...this is a Toyota made model with proprietary harness wiring. No one in town, not three radio shops nor two toyota dealers I visited had the ability to confirm the condition of the amp due to this wiring configuration.
    Now I'll pull the amp out of my OTHER toyota and plug it in to check...wish me luck!
  • 12,061 Answers
To me, it sounds like your "Output Devices" in the MAIN Amp have gone faulty. BUT check the OUTPUT directly at the Head Unit & then the Amp's terminals to make sure.. if ya dont have any signal comming out of the "Head Unit" than thats ya fault.. however if that has a good signal out,there, then it's gotta be ya Main Amp. Ya can check to se if there is output with a small speaker with wires on it, or my favorite an modified earphone, with the wires ends exposed so ya can "Touch" them to the Output terminals/Plugs etc, of whatever ya wanna test. NB: Only test at a low level output.
Posted on Aug 08, 2007
Stuck CD in JBL 4 disc CD Changer / Navigation
before you press the cd on button keep holding the eject button while you press power on, I know this works for computers etc.
Feb 13, 2016 | 2013 Toyota Highlander
Unit has power and lights up. None of the buttons work and cd wont eject. The CD eject button turns the unit off but won't eject the CD. Cannot change the functions. Have reset the unit and checked th
Remove the face plate and clean the contacts on both the head and the radio. It sounds like a bad connection, The base and head use serial data to talk to each other(control).If one of these connections are bad the unit will not work properly.
Oct 06, 2014 | Sony MEX-BT2900 Bluetooth Car Stereo with...
Jbl radio A56840 loses station presets and no volume
Toyota vehicles have a fuse in the kick for the amp and sometimes there is located under the hood ... This is the switch turn on for the amp ... And 1 of the fuses is most likely the memory or constant power. B sure to check all fuses ... I do not have AllData pulled up . If the fuses are all good the amp or radio may be bad ... Or both ... Be sure to check all the fuses ... Many times I get clients that say allthe fuses are good and it is still the first thing I check ..Usually is a fuse ..Good Luck
Jan 27, 2014 | JBL Car Audio & Video
Head unit plays cd and i have sound thru the speakers....when stereo is on fm. stations i have no sound.
Is the antenna plug coming from the car connected to the back of your aftermarket cd player?
Jun 19, 2009 | Sony Car Audio & Video
No Audio
IT MAY BE A GOOD IDEA TO CHECK THE WIRES BEHIND THE HEAD UNIT AS THIS IS WHERE EVERYTHING IS POWERED FROM, MAYBE A LOOSE EARTH LEAD OR MAYBE A LOOSE POWER LEAD, SOMETHING SOUNDS LOOSE.
Jun 18, 2009 | JBL BP1200.1 Car Audio Amplifier
Three blue lights blink
check you speakers and power source make sure all connection is correct
May 26, 2009 | JBL CS300.1 Subwoofer Mono Amp - 200W CS...
Stereo will not save time or set stations. not
sounds like a very common power wire issue. if not connected to the cigarette lighter or other continous power source when the car shuts off all memory will be lost, ie... audio settings, station memory, clock memory
Feb 18, 2009 | Sony CDX-GT110 CD Player
Legacy Audio American Legacy II LA290 Car Audio Amplifier Logo
134 people viewed this question
Top Legacy Audio Car Audio & Video Experts
Richard Lukszys
Richard Lukszys
FastHarley
FastHarley
Are you a Legacy Audio Car Audio and Video Expert? Answer questions, earn points and help others
