Question about Coleman Air Tools & Compressors
Pump runs trips breaker - Coleman Air Tools & Compressors
  • 1 more comment
  • vincent farri Apr 30, 2013
    On my Coleman Black Max compressor, the motor runs slow if there is 40 psi's in the tan. If I bleed the air off the motor will start to run and some times it will pressure up to 100 psi
  • vincent farri May 07, 2013
    ok, I had the capacitors checked, first which one would I replace?Second the tank will not refill after pressure drops down to about 40 PSI. If I bleed off air back to zero, It will start back up. Thanks.
    Capacitors checked out, but not ruling them out.
  • Coleman Master
  • 15,557 Answers
Replace the capacitor on the motor.
Posted on May 05, 2013
  • Brad Brown May 08, 2013
    What is the make and model number?
2 Suggested Answers
compman66
  • 169 Answers
SOURCE: Trips motor circuit breaker at start up (zero air
Most likely the start capacitor is defective or the motor has internal problems. would advise having it checked at a motor repair shop.
Posted on Dec 01, 2009
Testimonial: "Basic advice kept simple and to the point. I got a response quickly and did so without being forced to pay or trial software. Very Nice service. A+"
Why do the pump and cleaner breakers keep tripping?
Are they all on the same breaker, if so they might be pulling to much from one breaker alone, if theres more than one breaker and theyre both tripping try running one thing at a time pump/ozonator/booster and it doesnt trip try two at a time and try to see what one the problem is with.
Jul 15, 2015 | Pentair Pool & Spa
The pump shorts out when heater is put on
Electric spa control?
what do you mean pump shorts out? Are you saying a breaker trips or a GFCI trips?
if so, it has nothing to do with the pump, if it's already running. But once the heater engages and the breaker trips, then you have about heater element.
Mar 28, 2015 | Pool & Spa
Why does my Pool pump and boaster pump on Timer (T104) trips breaker?
check your wiring sounds like something isnt correct
Oct 16, 2014 | Pool & Spa
Dishwasher trips out after running for a while
When you say "trips out" do you mean the circuit breaker trips? If so the breaker in the electrical box may be bad. Also do you have anything on that circuit pulling high amps when the dishwasher is running? Also when does it "trip out" during a pump cycle or when the heating element cycle starts?
If the pump does not work at all then the pump may have went out. If it happens when the heating element cycle starts then it may be the circuit is overloading or the breaker is bad.
Oct 14, 2014 | Smeg Dishwashers
Tripping circuit breaker
Hi Kathy
Sometimes when a breaker keeps tripping, it will wear and will be in need of replacement...try replacing the breaker and see if that solves your problem.
If not then check the amps on the pump and make sure the breaker is able to hand the amperage the pump is requiring.
Bud
Oct 09, 2013 | Pool & Spa
I have a Polaris PB4-60 booster pump, less than 3yrs old. I turned the pump and left. When I got back 1hr later, the pump was not running. Breakers had been tripped. Each time we reset the breakers and...
If the device that tripped is a ground fault circuit interupter (GFCI) breaker or receptacle then it is likely caused by 5mA or more of leakage current to ground within the motor. If what tripped is a circuit breaker then there are likely shorted turns within the motor. Usually either of this issues requires a new motor.
If you are not wanting to turn wrenches yourselfthen my best suggestion is to bring it to Leslies Pool Supplies and they oftencan put it right for the price of the parts while you watch (they might not have some parts in stock).
I hope this helps.
Sep 27, 2011 | Polaris Pb4 - 60 Booster Pump
Breaker trips on condenser unit on heat pump after several hours of operation
Hi, check amps on unit, and make sure breaker matches, check unit voltage tag, it will tell you what size breaker you need, or may be breaker is loosing resistance, replace breaker, if problem continues, a/c maybe over working because of high temp, temp. affect amperages, and that would be normal, if it trips after few hrs. also check a/c for lack of freon, sometimes, they need a tap up of refrigerant, not enough freon and they would run longer, get hotter and eventual trips. breaker doing his job. good luck
Aug 03, 2009 | Amana PTH123B25AJ Heat Pump Air...
Pump trips breaker
If the seals are damaged, water will leak into motor section and cause GFI to trip and yet the pump will seem that it is running fine if plugged into a non-GFI receptacle
May 28, 2009 | Tsurumi Pump s Submersible Trash Pump -...
Air Tools & Compressors Logo
41 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
