Question about Euro-Pro EuroPro 6Slice Toaster Oven with Convection Cooking
Broken door Door is detached at the rt side. Oven has not been dropped, or abused... I found a small metal ring on the counter under the toaster oven but nothing else. I can't locate a repair shop nearby. Any hints?
SOURCE: Instruction book for Euro Pro X toaster oven
Euro-pro.com, select toaster, plug in your model and choose manual. Just printed mine.
Posted on Mar 29, 2009
cactus bob
  • 267 Answers
SOURCE: Using rotisserie in Bravetti Platinum Pro Toaster Oven Broiler
no the bottom element stays off when rotissereie is used . if it was on the liquid that drips from the cooking meat would smoke or might even start a flash fire ....... if this answer helped please rate a3 or 4 stars this high rateing will help keep me in the paid answer department thank you
Posted on Apr 02, 2009
SOURCE: knob to my toaster oven broken
the knob on my euro-pro model to289 is broken. Where can I find another
Posted on Oct 22, 2010
SOURCE: I have a brand new Euro Pro Toaster Oven, Model #
My mother had/has the exact problem right down to the teapot. I am in the process of fixing it, but don't have time to post solution right now. I will post later today. I should probably post a video as it is not real simple.
Posted on Mar 18, 2011
tech4allmen
  • 666 Answers
SOURCE: model to161 toaster oven.....plastic timer
We cannot, but of course Euro-Pro can. Contact them through the information below and request this part to be shipped to you.
Euro-Pro Corp.
180 Wells Ave
Ste 200
Newton, MA 02459
Phone: (617)243-0235
Fax: (617)243-0778
Tollfree: (800)798-7395
www.euro-pro.com
Posted on Aug 09, 2011
How do I fix the door spring on my Everstar toaster oven?
Request an assembly drawing from Everstar.
Oct 31, 2017 | Toaster Ovens
Tension spring on door
I found the answer (see below) posted on another web site. I followed the instructions and replaced the spring. I found, as the original poster had, that the new spring works better than the original and is much more sturdy. To the original instructions, I would add the following:
1) There are about 20 screws so have patience removing and replacing the screws.
2) Step 3, "Slide off the rear panel" requires further clarification as the panel will not slide off even with all screws removed. I had to turn the oven over, with the top of the oven sitting on the work table. I then used a screw driver to lift the two tabs that hold the back panel to the bottom panel. With the tabs lifted, the back panel will rotate away from the oven along the edge where back panel slides into the top panel. The back panel can then be slid out. I have included three photos that show this step.
3) Step 7, "Re-attach feet": Be sure to use the guides on the bottom of the oven to slide the foot assembly onto the oven. I had unsuccessfully tried to screw the feet onto the oven without using the guides.
Oringinal instructions for replacing the broken spring:
Just repaired this yesterday.
Got a spring from Lowes (Hillman Part # 543028 for about $4), it's larger than the original but seems much sturdier, original is really thin metal. Fit the space provided without problem.
Oddly, end result was a more 'giving' spring action, prefer it to original, which loved to snap shut unless door was 100% opened (ie fully 90 degree open).
This is for BOV800XL:
1. Remove all rear screws
2. Remove feet entirely
3. Slide off rear panel
4. I was not able to remove top housing - but I was able to gently pry sides open just enough to thread the new spring with a little ingenuity and effort. Watch out for sharp metal edges everywhere.
5. Slide back in (remember that top edge goes under the top edge/lip)
6. Put all screws back in
7. Re-attach feet
7a505b80-f785-4973-b674-12594d9dcb1d.jpg 2e67ee3d-99c9-4e88-8b9f-8d1721e5caa6.jpg 529808f4-8d72-4aea-8286-b525347addee.jpg
Apr 02, 2014 | Breville BOV800XL 1800 Watts Toaster Oven...
The door spring came off of hamilton beach 31100
The door of the Hamilton Beach Model 03008 or similar toaster oven does not stay closed when the door return spring or the hook it connects to breaks. The repair is very simple and takes just a few minutes!
The door spring is about 1 inch long and connects to a small clip on the inside of the left side panel of the unit. To see the small clip and the door spring, you simply remove the left side panel of the toaster oven which is done by removing just one screw.
The mounting clip on the side panel for the door return spring is located about half way up the side panel near its front edge.
The other end of the spring (its bottom end) connects to a metal hook. If the spring is not connected on its bottom end then the wire hook is broken. This is a simple repair that only requires a few inches of metal wire.
The other end of the metal hook (its bottom end) is connected to the bottom of the door hinge where it inserts into a small hole in the left side mounting hinge of the door.
When the steel hook breaks on either end then the spring cannot function, so the door does not stay closed.
To fix this problem, you simply get a piece of steel wire that is about 1/16 inch thick and a few inches long.
Bend the wire to make a hook at one end that the spring will connect to.
Then insert the other end of the wire into the small hole on the left side mounting hinge of the door. Then bend the wire on the inside of the hole to make a U or hook so the wire stays mounted in the hole of the door hinge.
Then adjust the position of the bend on the other end of the metal wire so the spring will have good tension when it is attached to the hook and to the clip on the side panel.
To do this you make the U shaped bend on this end of the wire to be about 1/2 inch from the end of the open end of the spring when the top end of the spring is attached to the mounting clip on the side panel.
To attach the spring to the wire hook, first remove the spring from the mounting clip. Then hook the spring onto the hook (bend) you made at the top end of the wire, then just stretch the spring to connect it to the mounting clip. The door will now stay closed.
Nov 10, 2013 | Hamilton Beach 31197 120 Watts Toaster...
My KRUPS FBC2 glass door hinge is broken. We use a pan to keep door in place when using it so it doesn't fall down. Any ideas on how to fix it will be appreciated. I'm pretty handy with things but I just...
I just fixed the problem with my Krups FBC-212. The door would not stay closed because the spring that keeps it in the closed position was broken. I ordered another from one of the small appliances parts sites (about $7 plus shipping) and that fixed it. I will describe how to do it and how to avoid the mistake that made it much harder and longer than it should have.
Remove the black screws at the back side, the ones holding the external black metal case to the silver chassis. There are 9 of these on my oven.
Also remove the 3 screws holding the left-side foot on.
Now you can probably slide the metal case (previously held on by the 9 screws) out from under the black metal front frame on the left side, thereby exposing the broken spring.
If you cannot get it out from under the lip of the front frame, you can take off the right-hand foot, and if that is not enough, you can remove THREE of the 4 black screws just inside the door holding the front frame to the chassis. Do NOT remove the lower left one next to where the flat door hinge piece goes into oven (which was my mistake) because that screw holds a critical black plastic piece in place.
By now you will be able to slide the black case that covers the sides and top backward and outward enough to expose the broken spring. It will be obvious how to attach the new one.
Aug 28, 2010 | Krups FBC2 1600 Watts Toaster Oven with...
Door spring broke on Cruisinart CTO 350 series Toaster Oven
I had same problem with my cuisinar 350 series broken door spring. After disassembly found a broken extension spring measuring about 3/16 dia.,by 6.5 inches long.Spring was broken about a third down. I lifted ,or bended a loop and a halve up from each broken section and joined the two sections together. lifting each loop of the spring is tricky at first, requires a small screwdriver to be inserted between loop to be lifted and then gently bent the loop with needlenose pliers.
Not knowing how to disassemble the unit I had a hard time assembling the unit back.
I would start by taking off the screws holding the front black backlite first, then the main cover.
The main stainless steel cover does not have to be removed completely, by just gently unbending
the cover I was able to access the spring for removal.
Lots of luck
Jan 29, 2010 | Cuisinart TOB-175 1500 Watts Toaster Oven...
The spring detached causing the door to stay open
take the cover off by removing 6 screws around the back and 7 on the bottom (2 of these are safety screws but can be removed by a small flathead screwdriver); once you romove the wrap-around "hull" or cover you can see the spring on the left side of the oven from the frontal view.; the door stop is sort of a L shaped piece which you insert from the inside of the opening on the frame & thru the little hole on the left side of the door; once you do this stretch the spring and attach to the hole into hole you see on the middle of the L shaped piece.
May 29, 2009 | Black & Decker TRO910W Toaster Oven with...
Toaster oven door will not close completely.
This problem is caused by screws being loose or dropping off a limiting bracket on the left side of the oven behind the left outer wall.  This bracket allows the front glass panel to remain OPEN, as required for broiling.
To correct this, first check to see that the two black screws facing forward, behind the left side of the front glass panel are tight.  If not, tighten firmly, but be careful not to overtighten.  If this fails to correct the problem, then follow this procedure.
Purchase 2- #4 x 1/2" SS Phillips Pan Head sheet metal screws at your favorite hardware store.  Cost About $1
  1. Unplug the oven and place on a flat work surface. Place a rubber mat or towel under the oven to prevent scratching.
  2. Remove 2- #4 x 1/4" black phillips flat head screws on the left side of the front glass panel which screw into the black side panel.  These are NOT the screws which hold the bracket, which face forward, but are adjacent to the bracket screws.  Be sure to indentify the proper location of all screws for replacement.
  3. Remove the 4- #4 x 3/8" SS phillips pan head screws at the bottom of the left side of the oven.  Pry the metal tab of the back panel slightly off the bottom of the black side panel.
  4. Remove the 3- #4 x 3/8" SS phillips pan head screws from the back panel which attaches to the left side black panel.
  5. Carefully pry the bottom of the left black side panel up from the bottom of the oven until it is parallel to the top of the oven.  It will seem hard to pry it upward as you are bending two SS tabs holding the black side panel to the SS top.  It will come up easily once you get it started.  When it is parallel to the top, slide the black side panel to the rear to remove it from the two SS tabs.
  6. You should now see the limiting bracket at the front of the oven's left side.  Remove the 2- black Phillips screws holding the bracket.
  7. Slip the limiting bracket from the oven.  Place on a wood block and with a chisel (or large common screw driver) and hammer, strike the screw holes on the bracket firmly once, so as to close the screw holes slightly.
  8. (OPTIONAL)  If available, using a rat tail file (or small flat file), at the crook of the spring lever, carefully increase the indent of the crook ever so slightly.  This will allow the front glass panel to stop more definitely at the open point.
  9. Remount the bracket using the 2- #4 x 1/2" SS Phillips Head sheet metal screws you bought. Tighten firmly, but do not overtighten.  Check the front glass panel movement. It should have a definite stop to allow the panel to stay open approximately 1/2" for broiling and should close fully, easily.
  10. Slide the left black side panel on to the SS tabs.
  11. Pry the left side black panel down until it meet the bottom plate.
  12. Replace the bottom screws.
  13. Replace the 2- #4 x 1/4" black Phillips flat head screws at the left side of the front of the front glass panel which screw into the black side panel.
  14. Replace the back panel screws.
Feb 23, 2009 | Cuisinart TOB-50 Toaster Oven with...
Toaster oven door
Try sales@semenedis.com They do thousands of parts for white goods.
Dec 03, 2008 | Black & Decker CTO9000 Dining-In Toaster...
Euro-Pro EuroPro 6Slice Toaster Oven with Convection Cooking Logo
Top Euro-Pro Toaster Ovens Experts
eyecam
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Euro-Pro Toaster Oven Expert? Answer questions, earn points and help others
