Does any body know why my 2004 Truck oil pressure gauge goes really high sometimes I drive it. It goes as high as off the numbers on the gauge. Do I need a new oil pressure sensor . Thanks
If it is electrical oil pressure sensor I would start there. The best way to see if you have a major problem is to use a mechanical oil pressure tester. Take off the oil pressure sensor and put the mechanical tester on. The tester should come with a Gage. If it comes within your trucks oil pressure range than all is fine and replace the sending unit and see if that don't help your problem.If the tester runs high then the oil pump is bad or your cam-bearings could be the problem. But with cam-bearings you would usually get a low reading.
oil pressure sensor on 2003 gmc van
oil pressure gauge goes all the way around
engine oil pressure sensor/switch high voltage code
dic and gauges don't work
