Question about Tappan TGF320 Gas Kitchen Range
Tappan Gas Range
I just signed a lease for an older apartment that comes with an older Tappan Gas Range. The top of the range is EXTREMELY hot, even when it isn't on. How can I fix it? Can it be fixed? Thanks in advance! ~K
  • Anonymous Mar 14, 2014
    we need a wiring diagran tappan gas range
  • 163 Answers
Most likely has "ON PILOTS" As opposed to (electronic ignition/ Ignitors).. Change the stove to a more efficient model and being gas do "NOT" Do it yourself Period!.(Please)..Install should be tested and approved..
Call a local professional specialized in LP/Natural Gas Appliances. Flex lines on older Stoves tended to break down causing leaks as well as older construction codes where Black pipe feeds and shut-off valves break down after time. Sorry for the Negative info but Ive seen some Slum-lord homes in my days doing service calls.. Keep it shut off until you can get it fixed professionally..
Posted on Jan 16, 2008
Why surface control knobs become hot when oven is on
If its an older model gas stove, then its normal. I have an older gas stove and the knobs get a little hot when the oven is on. Nothing that prevents me from using it, but enough to notice they are warm.
If its a newer stove, you should contact the manufacturer. Without knowing more info, I can only give a general answer.
If you're renting in an apartment then talk to the management or maintenance. If you're leasing the stove, call the company its being leased from.
Sep 30, 2015 | Kitchen Ranges
I just moved into a condo I am renting and the Tappan gas oven/stove stays hot when it is not even on. The part that is hot is the top between the burners. Is that normal?
Probably the pilot light. You should be able to lift the top of the stove for cleaning ... try lifting it ... to see and verify for yourself this is the case.
This is very typical of a stove fired by a pilot light.
Thanks for your question at
If you found this helpful, the courtesy of a positive vote will be appreciated. Thank you.
Sep 19, 2010 | Tappan TGF320 Gas Kitchen Range
Self light oven not lighting - gas fills the room
its the hot surface igntior that glows could be cracked might need replacing
Feb 02, 2010 | Tappan 24 in. Freestanding Gas Range...
Oven not coming on
I have a tappan gas stove the top comes on but the oven wont come on.
Sep 07, 2009 | Tappan TGF363 Gas Kitchen Range
HOT oven Range
Yes those are pilot lights and this is perfectly normal in fact only be concerned if they are not lit. This is just a fact of life with gas ovens. Little bit spooky huh? That's why I have always preferred electric ranges but gas is preferred by many.
Nov 28, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan TGFS26C, Oven igniter not even
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
Hope this helps.
Nov 20, 2008 | Tappan TGF363 Gas Kitchen Range
Older Tappan range oven not lighting.
There is no way to light the oven manually. The gas valve will not open until the oven ignitor draws enough current. But replacing the ignitor will fix ya up.
Nov 19, 2008 | Tappan TGF320 Gas Kitchen Range
Smell gas no heat
hi thanks for the question yes this problem is very popular in gas ovens even though theigniter lights up its not hot enough to ignite the gas and also with this problem it wont reach the set tempeture thanks the appliance doc
Aug 29, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan gas stove
yes the igniter can come on telling you its ok but these igniters break down they light up but not hot enough to ignite the gas replace the igniter thankstheappliance doc
Tappan TGF320 Gas Kitchen Range Logo
222 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
