Question about Tech Solution TS-2550 Shredder
My TS model 2550 paper shredder nylon gear that connects to the motor shaft is worn. I need a replacement. Is there any place where it can be obtained? Thank for the assitance you may give.
The motor runs great and is very powerful, however the gear that connects to the shaft is worn out and as soon as paper is fed the gear slips and the cutters stop shredding. I need to replace this nylon gear. Where can be obtained?
SOURCE: My shredder keeps running and won't stop in on/auto mode
Does the shredder have the electronic eye to sense paper? Sometimes dust will collect on the sensor causing it to keep running.
Posted on Apr 16, 2007
  • 168 Answers
SOURCE: Shredder suddenly runs only in reverse
Do you hear the motor moving in both directions? I just had the same problem with mine. On mine, you can hear the motor moving in both directions but it would only move the shredder teeth in reverse and the teeth would not move going forward. I took the unit apart and found out that the gear right next to the motor shaft was rounded out in the middle. The solution would be to get a new gear or gears if you can get them. Make sure you inspect all the gears to see if there is a lot of play. You might have to replace more than 1 gear. What I did on mine, was take a brass tubing that was just a little larger than the shaft, drill out the center of the bad gear and press the tubing into the center of the bad gear. This took up the extra play and my Tech Solution TS8000 is working again. Hope this helps. If you have any other questions, feel free to email me at macgyver69@netzero.net
Posted on May 30, 2007
JayBlair
  • 328 Answers
SOURCE: need gear
Have you tried EBAY?
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Jul 31, 2007
otacon
  • 1944 Answers
Did you check out this thread?
http://www.fixya.com/support/t135563-shredder_suddenly_runs_only_in_reverse
Posted on Jan 01, 2008
SOURCE: TS-6000 Shredder Problem
1800 639 3803 tech solutions service hot line for the ts6000
Posted on Nov 03, 2008
Nylon drive gear worn on one side
I have been told by the manufactutere that they do not make any replacement parts for their shredders. If it is less than a year old they will replace it.
Jun 20, 2010 | Aurora Electronics AS1018CD Shredder
TS3300 PAPER SHREDDER. I NEED THE SWITCH CABLE COMBINATION
where can i buy a gear for my paper shredder model ts 3300
Apr 26, 2010 | Tech Solution TS-4500 Shredder
Plastic gear is wore out. the motor shaft wore it
My friend, if the gear is worn out, your machine is worn out. By the time you get and in stall this part, you can purchase a new machine.
There is a possibility that Royal will sell you the part ... you could check with them. I have never had luck repairing any but LARGE COMMERCIAL shredders. Home and small office shredders are not worth the effort to repair.
Feb 13, 2010 | Office Equipment & Supplies
Replacement plastic gear for a Royal 150MX shredder
For parts call Royal at 1-800-524-0799; they should be able to help.
Don't forget to lubricate the cutting shafts on x-cut shredders.
Apr 02, 2009 | Royal 150MX Cross-Cut Shredder
Aug 18, 2008 | Tech Solution TS-6000 Shredder
Makes noise but won't shred
Had the same prob with a Schneider shredder. The roll pin that secures the nylon driven wheel to the blades shaft was sheared. Easy fix in a way but original pin was a metric size.
Jul 13, 2008 | Tech Solution TS-2550 Shredder
Ts 4500 blades not moving
From the sound from your description, it is Probably a cracked gear or a worn bushing.
To get a better idea, you would have to take it apart to see what is going on inside.
Good luck
Feb 06, 2008 | Tech Solution TS-4500 Shredder
Does not feed paper
Had the same problem. The gears inside the shredder have worn out. I overfed the shredder with too much paper and caused the nylon gears to slip and strip away the teeth. Now the motor won't engage the cutters when you attempt to feed the machine. If your handy you can take it apart, find the gears, contact the manufacture and have them send you out a new set for that model. If not, then you will need to buy a new shredder. In my case, they sent out new gears, it took forever to receive, and when I did get them one gear was the wrong size. I had them send out a new one, and again after weeks it was still the wrong gear, even after sending them pictures! I am now buying a new shredder, and I am spending a bit more to get a more robust machine that can handle more of the workload I need.
Dec 15, 2007 | Fellowes DM8C Cross-Cut Shredder
Need gear
Jul 27, 2007 | Tech Solution TS-4500 Shredder
Tech Solution TS-2550 Shredder Logo
23 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Michael Galve
Michael Galve
quennie732
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
