Question about iRobot Roomba 560 Robotic Vacuum
Stops after a short time and says recharge roomba
    Problem Solver:
  • 8 Answers
Replace battery
Posted on Jun 12, 2013
  • vacuumlad Jun 12, 2013
    the battery might be fried replace the battery
SOURCE: Brushes are clean, but Roomba stops and says clean brushes
I decided to take it apart and see if I could fix it because even if something inside went "SPROING" and I couldn't get it back together, it wouldn't be any worse than it was already.
FIrst, remove the dust bin part and the brushes. Then, there are four screws on the bottom gray panel which have to be removed first in order to get to the gears which hold the brushes. I did not remove the little sweeper brush on the front, but I just slide it through the hole in the gray panel.
Then in order to get out the orange section which actually holds the brushes, there are four screws which must be removed. The orange section is attached to a blue section. This entire unit comes out by sliding it toward the area where the dust bin goes, being careful not to tear the light gray rubber gasket which covers the side.
Once that section is removed, there are two screws on each side. These screws hold the orange thing to the blue thing. Once the screws are removed, lift up only the side which has the white squares into which the brushes are inserted. These are actually the back side of little gears. There is a face plate on the outside of the orange part on this end. The other end contains a bunch of wires and I was careful not to disconnect any of them.
The face plate has six screws which must all be removed. Use caution when removing the face plate. Hold it up so that all of the stuff doesn't fall out. It has a bunch of gears, little brass looking fittings and grease. Take care to only remove the gears which have the squares which hold the brushes AND do it one at a time unless you like working jigsaw puzzles. I used tweezers and a pin to clean the "gunk" consisting of hair, fuzz, etc., out of the little gears.
Reverse the process to put it back together. Hazel, my little Roomba, played me a happy little song and immediately went back to work. She seems as good as new.
Posted on Nov 20, 2008
SOURCE: roomba 415 bumps into something 3 time, stops
Txs for not helping me out unless I pay for it!!!! :-(
Posted on Jan 03, 2009
  • 61 Answers
SOURCE: spins, stops and can't find dock
The problem is your Roomba's bumper. Tap it with your hand about a dozen times, blow it out with compressed air, and then try running the Roomba. If the same thing occurs, call support at 1-877-855-8593. (Be sure to have the Roomba with you when you call.)
Posted on May 29, 2009
pic498
  • 32 Answers
SOURCE: roomba starts and stops.
try pulling the battery out and holding down on the power button for 5 secs. if this doesn't fix the problem--you need a new battery.
Posted on Jun 15, 2009
  • 58 Answers
SOURCE: Roomba goes a few minutes after a charge then stops
you can try cleaning the battery and charging contacts with some rubbing alcohol or contact cleaner, but its also possible the battery has reached the end of its service life.
Posted on Dec 13, 2009
Roomba 560 fully charges. Runs for 2 seconds fully green and just stops. And lights up red.????
Set him on the floor, after powering him off and then back on, and press the "Clean" button three times. This will reset him.
Sep 11, 2014 | iRobot Roomba 560 Robotic Vacuum
Stops
I had the same problem when I renovated my kitchen. With boxes of stuff everywhere it was impossible to use Roomba. When I tried to use it again a few months later, it would stop after only a few minutes work. I had to buy a new battery which cost in excess of $100. Its better to loan it to a friend to be used than to put it into storage.
Apr 30, 2013 | iRobot Roomba 530 Robotic Vacuum
Roomba model 4210 starts and stops after a few minutes only going in short distances and then turning allthough it hit nothing...
Inside this Roomba, the cleaning head module is clogged badly with debris. Open up your Roomba and remove all debris.
Aug 08, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
Roomba is only operating for about 10 minutes at a time and then the red light comes on and it stops
Hello. Most likely, your rechargeable battery is on it's last legs and needs to be replaced. Joe
May 01, 2010 | iRobot Roomba 500 Series Virtual Wall...
My roomba was not used for a month. Now it does
Hello
You can revive the dead nicd batteries in your tools.
There is a simple guide that can fix all nicd batteries in few minutes, available here.
Thanks
Nov 29, 2009 | iRobot Roomba 560 Robotic Vacuum
Sep 13, 2009 | iRobot Roomba 560 Robotic Vacuum
Spins, stops and can't find dock
May 17, 2009 | iRobot 530 Roomba Vacuuming Robot, White...
Roomba cuts off after a minute or so.
If you have a 400 series Roomba, try removing the battery, then holding down the power button for ten seconds, then recharging the unit before you run it again.
If you have a 500 series Roomba, don't take out the battery-- just press and hold the "spot" and "dock" buttons for about fifteen seconds. The Roomba will play a tune, and you can then charge it and try running it again later.
May 13, 2009 | iRobot 4150 Roomba Vacuum
Roomba red 4100 cleans in small circle stops starts agains cleans small circle stops then status light comes on and clean button blinks.
When the status light comes on, the Roomba is going to sing "uh-oh," and then beep a number of times. Count the beeps. They're a code that tells you what's wrong with the Roomba. You can check iRobot's website for a chart of beep codes. Search "What is Roomba saying to me?" on the troubleshooting page.
Apr 06, 2009 | iRobot Roomba Red 4100 Bagless Robotic...
Roomba 415 bumps into something 3 time, stops
Jan 02, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Open Questions:
See all iRobot Roomba 560 Robotic Vacuum Questions
iRobot Roomba 560 Robotic Vacuum Logo
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
