Question about Canon ZR200 Mini DV Digital Camcorder
Canon ZR200 camcorder
My camera is almost new, only a little more than a year and I take very good care of this little camera. While I was filming in the house I noticed an unusual sound, I filmed for a few more seconds and stopped, I tried to replay the tape and it made the same noise and didn't replay. I turned it off and when I turned it on again it the LCD showed a red message "remove cassette" and it shut off almost immediately after that. I removed the battery and the tape then tried another tape and used eletrical cable w/o the battery but the same thing happened. I have no clue why this is happening and what to do to fix it, I showed it to a friend that knows more than me and he asked me to buy a cleaning tape and give it a try, but I can't find the item. Please help me! Thank you very very much for reading my e-mail. Mrs Yaky Fernandez
  • Yaky Aug 10, 2007
    Please explain for me what a capstan motor is and if there is anything that I can do to fix it. I appreciate your help.
    Thanks,
    Yaky Fernandes
  • Yaky Aug 13, 2007
    X-tian. Thank you for your help, When you say to open your camera you mean, unscrew the body and see inside or is this something you can see with the body of the camera as is? Please expain. I love using cameras but I am not knowledgable on the mechanism. Thank you
    very much.
  • 169 Answers
Mechanical problem. maybe the capstan motor is not running
Posted on Aug 08, 2007
  • christian tope Aug 11, 2007
    it is the motor that responsible for moving of the tape....if you can open your camera check the small fuse located at the power supply section and have a mark of letter H and N ....just follow the battery connection or the dc input of the camera...
SOURCE:
Can I hook up to the DW 100 Canon burner with my ZR200 to burn mini tapes on DVD?
No. The Canon USA web site says the Canon DW-100 has a USB terminal and works with "USB 2.0 Hi-Speed (with compatible Canon camcorders only)." In other words, the Canon DW-100 burner works only with Canon's USB 2.0 camcorders. I have a Canon ZR200. The ZR200 has Firewire 400 digital video output, not USB 2.0 output. The USB port on the ZR200 is ONLY for still images. Video will not and cannot be output through the USB port on the ZR200. (Page 121 in the ZR200 manual mentions using the USB port on your camcorder for transferring still JPEG images to your computer.) You need a DVD burner with "DV Input" (also called Firewire 400 or IEEE 1394) to hook up your camcorder to burn Mini-DV tapes onto DVD. The Sony VRDMC10 Stand Alone DVD Recorder/Player has DV Input. The ZR200 camcorder did not come with a Firewire cable, but you can buy one at any electronics store or at a cheaper price online. Make sure that you get the right kind of Firewire cable, 4-pin to 4-pin or 4-pin to 6-pin, whatever the DVD burner you choose requires. (Your ZR200 has a 4-pin DV port on the camera's end.) USB 2.0 Hi-Speed (with compatible Canon camcorders only)
Mar 15, 2011 | Canon ZR200 Mini DV Digital Camcorder
Canon ZR200 sound cuts in and out on playback
This is usually caused by an oxidized or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Mar 03, 2011 | Canon ZR200 Mini DV Digital Camcorder
Canon ZR200 has no power. Charging light does not come on when trying to recharge the unit. The ZR200 was working fine, we turned it off then 5minutes later tried to turn it back on - but it was totally...
This is usually caused by a failed component in the power circuit within the camera and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
Aug 28, 2010 | Canon ZR200 Mini DV Digital Camcorder
Canon zr200 will not except tape.
Give it a good smack and see if that works. I am not kidding. Look at the other posting of this problem and see all the solutions.
Oct 22, 2009 | Canon ZR200 Mini DV Digital Camcorder
Canon zr200 wont format new 4gb sandisk card...why?
The ZR200 is able to read a card of maximum of 2 Gbytes !!!
The 4 GB SD card it is a so called SDHC = Secure Digital High Capacity ! Every SD card with more than 2 G Bytes it is a High Capacity and the old hardware will not be able to use these SDHC.
Jan 11, 2009 | Canon ZR200 Mini DV Digital Camcorder
Canon ZR200 camcorder mini dv
Have any of you tried using a mini DV cleaner on your cameras? I'll try this soon and report back.
Nov 27, 2008 | Canon ZR200 Mini DV Digital Camcorder
Could I get a new manual for my Cannon ZR200 Digital Video Camcorder sent to me?
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=326&modelid=11004
Nov 22, 2008 | Canon ZR200 Mini DV Digital Camcorder
Misplaced manual for my Cannon ZR200 Digital Video Camcorder
Hi - You can download the manual by clicking the link underlined in blue below:
ZR200
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 19, 2008 | Canon ZR200 Mini DV Digital Camcorder
Canon zr200
This is the description of the feature you need: "Have friends in far-off places? Turn your ZR200 into a Webcam for Internet Video Chat with Microsoft Windows Messenger through IEEE1394. It's all possible thanks to the DV Messenger2 software, available as a free download for ZR200 owners. DV Messenger2 allows you to control the zoom and focus of your ZR200 or the camcorder of the person you are chatting with. Preview thumbnails and transfer photos. You can even watch and control the video playback of either camcorder right from your computer." You can download DV Messenger Version 2 only after registering with Canon, see the bottom of the following page: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=326&modelid=11004 I believe the drivers are included in the download. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 12, 2007 | Canon ZR200 Mini DV Digital Camcorder
Canon ZR200 Mini DV Digital Camcorder Logo
187 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
