Question about Garden
Toro repair manual
How do I replace the primer bulb on a 1990 Toro walk-behind lawnmower, Model 20692?
5 Suggested Answers
SOURCE: Toro walk behind model 20025 Gas running through the carburetor
Carb. float must be stuck open. First if you have no fuel in the tank it must all be in the crankcase.Drain the oil and refill and also check the carb as the float has to be sticking open. Hope this will help you. Donnyb60
Posted on Mar 18, 2009
  • 5 Answers
SOURCE: I have a toro lawnmower moel 20695 and whem i
check the gas line between the carb and bulb. Or it could be the plastic primer bulb itself. -a small tear or slice could easily go unnoticed.
Posted on Aug 05, 2009
riceski
  • 1851 Answers
SOURCE: Toro walk behind model 20016.
Remove the rope case and see if it is the mower -also - remove the spark plug and try it - also - - after removing the spark plug - also -try spinning the blade. If you remove the top you will see the problem sooner.
Gary @ Fix Ya
Posted on Sep 09, 2010
  • 6468 Answers
SOURCE: model 30317 toro walk behind breaking drive belts at rate of 3 or 4 per season
check the pulley alignment also check for plat in the blade bearings
Posted on Apr 21, 2012
What is spark plug gap on toro lawnmower model#20332?
Toro has your manuals here depending on year of purchase. If they don't mention the gap, I would use to the contact page to ask.
https://www.toro.com/en/homeowner/walk-behind-mowers/22-personal-pace-20332
22 56 cm Personal Pace 50 State 20332
Apr 14, 2016 | Toro Power Lawn Mower
Where is the primer bulb o my toro lawnmower
Typically a primer is only used on 2 cycle engines not on lawnmower engines, so it would not have a primer bulb.
Jul 15, 2014 | Toro Garden
How to replace carb. Primer?
If you don't see two screws diagonal of each other than there is a little ring holding in your primer bulb. Be careful when removing ring as to not bend out of shape usually new primer bulbs don't come with them. If there are the two screws diagonally, than just unscrew and lift holding plate remove old primer and reverse for install... Good Luck....
Jun 20, 2014 | Toro Lawn Mower With Toro Power Tools
I took my toro 6.5 lawnmower carb apart and cleaned, now fuel spurts out of red tube into the air cleaner. Why is this happening?
Sounds like you assembled something wrong when reinstalling the carb. Or your missing a step or two.
Mar 18, 2012 | Toro Power Lawn Mower
My Toro Model 20070 that until now has always started on the first pull, won't start at all now. It started fine last week. It's getting spark (a little more yellow than blue). I replaced the plug,...
Hold the butterfly valve (behind air filter) open with a screwdriver, while somebody else tries to start it. Toro has had problems with atuomatic chokes. If it fires right up, thats the problem! If so, just wire it open, or contact Toro for a repair kit. Try using starting fluid, not carb cleaner, and spray directly into the head through the spark plug port. If you didn't do it already, blow out all the ports in the carb with compressed air, or carb cleaner. Also, be sure the safety lever is engaging correctly (top bar on handle) at the engine. Lawn mowers are pretty simple, so the problem is most likely simple too.
Sep 24, 2011 | Toro Personal Pace CARB Walk Power Mower
Toro model number 200065 won't start. New gas, new spark plug, cleaned air filter. Doesn't feel like fuel is in the primer bulb when I prime it.
some toro primer bulbs don't fill up with fuel but blow air into a chamber in the carb that has fuel in it so when you press the bulb, the air sprays fuel into the carb ( just a little) So since it won't start, the bulb probably has a very small crack in it. replace it and then try it.
Aug 10, 2010 | Toro Lawn Mower With Toro Power Tools
I BOUGHT A BRAND NEW TORO LAWNMOWER, MODDEL 20330,
don't waste time looking for the primer bulb. probably wont work anyway if its over 6 months old and repairs probably wont do any good either. bad design for a primer system.
Apr 08, 2010 | Toro Lawn Mower With Toro Power Tools
Aug 02, 2009 | Toro Lawn Mower With Toro Power Tools
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
