Question about Toro Lawn Mower. 22 in. Personal Pace with Blade Stop System Self-
Toro Personal Pace sounds like it is running at half power
Toro Personal Pace that doesn't have an adjustable choke sounds like it isn't running at full speed anymore. Like the choke is on half power if that makes sense. I have replaced the air filter and cleaned out the carburetor bowl and no change. Starts up with out any trouble. Briggs 190cc engine only a few years old.
  • 25 Answers
Got oil in it, or do you add oil. Left outside alot, fuel line clogged. Is the gas old. Check the blades and the exit portion of the clippings. Does it have a drive train for ease of moving. those can bog down a mower. good luck
Posted on Apr 30, 2013
Testimonial: "Just changed the oil and had drained out the old gas, put fresh stuff in. Blade seems okay, underside of deck is clear of any grass and debris. Wish I could adjust the choke on this model because that's what it sounds like it needs, but it is not adjustable. I'm not sure if a fuel line is clogged, but I did clean everything around the carb bowl and the also the line that goes to the back side of the air filter. Thanks for your reply. I can't find anything on the web regarding this yet and it is very frustrating for such a new mower "
  • Dreamingneonblack May 03, 2013
    Figured out what my problem was. Ended up being the spring that connects to the linkage above the carb. I must have had a stick or something get up there and stretch out that spring. The tension was very loose. Once I compressed that a bit, all was good. I will order a replacement spring for that. Thanks for the help though.
tbreeze47
  • 3083 Answers
SOURCE: My Toro lawn mower runs
The following website has a lot of information about Toros:
http://www.ehow.com/toro-lawnmower/
You've done most of the things, except you didn't mention ceaning the air filter, but perhaps you incuded that cleaning the carb. You could have a cracked gas hose,
This page might be of help to you also:
http://www.ehow.com/way_5890404_toro-lawnmower-gets-hot.html
Good luck, and hope this helps you out.
Posted on Dec 13, 2010
2strokeJim
  • 577 Answers
SOURCE: Toro GTS 20332 (bought it 12 months ago) won't run
I believe that Toro Guarantees to start 1 Pull, was gas left in it all winter?, If so this is'nt covered under warranty, cause gas is to be ran out or dumped out at end of season this will prevent any gumming up of carb . did you completely disassemble carb? does it have a primer on it, those gskts need replacing, clean out the jet in bottum of float bowl,small holes,sometimes missed and remove and check your needle/seat to make sure that when float drops gas runs out then lift float up and gas should stop. hope this helped you,another thing spray carb cleaner in carb and pull over and see if it will start that way enough to keep running with choke to see if it will **** gas into it
Posted on May 16, 2011
kel1guy2002
  • 3740 Answers
SOURCE: The motor on my lawn mower starts easily and runs
This is usually caused by either a fuel float that is heavy due to taking on fuel where there is supposed to be an air cavity or.
There is debris in the float needle seat allowing excess fuel to over-fill the float bowl. The float needle has a rubber tip that seats against a tiny fat rubber washer called the seat. If there is debris in between the seat and the needle tip the fuel will NOT shut off causing the symptom you descibed.
If you provide a model number I will look up the inexpensive repair parts that will correct this symptom and provide you with a parts source.
Thanks for choosing FixYa,
Kelly
Posted on Aug 11, 2011
2strokeJim
  • 577 Answers
SOURCE: Have a Personal pace Toro with electric start that
sounds like you will be making a trip to the dealer for a new coil
Posted on Aug 22, 2011
  • 6468 Answers
SOURCE: 2004 6.5hp toro personal pace runs for 2-3 sec. then cuts off. New plug,fresh gas, new air filter, fuel filter appears clean
could be dirt in the carb
Posted on Mar 30, 2012
What is spark plug gap on toro lawnmower model#20332?
Toro has your manuals here depending on year of purchase. If they don't mention the gap, I would use to the contact page to ask.
https://www.toro.com/en/homeowner/walk-behind-mowers/22-personal-pace-20332
22 56 cm Personal Pace 50 State 20332
Apr 14, 2016 | Toro Power Lawn Mower
Toro personal pace 20372 starts, runs for 45 minutes then dies
Possible fuel blockage,or ignition source getting hot,electronic CDI unit ,check for spark at the plug when it stops.
Jul 21, 2014 | Toro 20372 Recycler Personal Pace...
Replace right rear hieght adjuster on a toro self pace mower
Remove wheel, remove screws mounting adjuster, straighten or replace.
Oct 02, 2012 | Toro 22 in. Personal Pace with Blade Stop...
Toro 2009 personal pace mower transmission went out
You should post this question in the lawnmower section so the proper expert will see it..
Aug 29, 2012 | Toro Lawn Mower. 22 in. Personal Pace with...
How do I replace the torsion spring in the handle of a Toro Personal Pace lawnmower?
Thanks so much Jamie. I had the top of the handle off but couldn't get any
further. I had to use a screwdriver on one side to get the brass bar out of the
plastic channel (I was afraid I would crack the plastic but didn't). I was able to remove the bar from the handle by myself with lots of effort ( BTW in your
solution did you mean your son pulled vertically up on the handle while you pushed vertically down on the bar?). I had one foot on one side of the handle and pulled up on the other side while pushing down on the bar. Isn't the web and Google amazing. The Toro sight didn't have a service manual. So I just typed "How to replace the torsion spring on a toro lawnmower" in Google an the question came up. I think Toro has a design issue with an overstress point on the spring. That part is on back order at the factory.
I did it.
May 01, 2012 | Toro Personal Pace CARB Walk Power Mower
My Toro Model 20070 that until now has always started on the first pull, won't start at all now. It started fine last week. It's getting spark (a little more yellow than blue). I replaced the plug,...
Hold the butterfly valve (behind air filter) open with a screwdriver, while somebody else tries to start it. Toro has had problems with atuomatic chokes. If it fires right up, thats the problem! If so, just wire it open, or contact Toro for a repair kit. Try using starting fluid, not carb cleaner, and spray directly into the head through the spark plug port. If you didn't do it already, blow out all the ports in the carb with compressed air, or carb cleaner. Also, be sure the safety lever is engaging correctly (top bar on handle) at the engine. Lawn mowers are pretty simple, so the problem is most likely simple too.
Sep 24, 2011 | Toro Personal Pace CARB Walk Power Mower
What type oil i use toro personal pace push sae30?
SAE 30
detergent oil with an API service classification of SF,
According to their manual.
May 12, 2011 | Toro Personal Pace CARB Walk Power Mower
It seems as if my toro personal pace mower is stuck in the choke position, it will not increase the RPM's. Could the be caused by a dirty air filter?
check to see if the idle spring on carburator is connected, if the pop off the engine will only idle a very low speed or choke out. plus it doesnt hurt to clean the air filter
May 05, 2011 | Garden
Toro Lawn Mower. 22 in. Personal Pace with Blade Stop System Self- Logo
264 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
