Question about Pool & Spa
What size and kind of fuse does blue diamond pool cleaner remote caddy use
I need a code for a blue diamond tv model number BD40DL fev10
Remote Code for Blue Diamond TV - Boards.ie
www.boards.ie > Talk to... > Sky Ireland
Aug 7, 2015 - After checking our database for remote codes we don't have a codeavailable for your particular make of TV, Blue Diamond. I will be sending ...
Horizon UPC Blue Diamond LED Remote Control - boards.ie
www.boards.ie > ... > Cable & Digital TV > Cable & MMDS & IPTV
Dec 11, 2013 - I have bought a BLue Diamond TV and upgraded to UPC Horizon HD. ... the code for Mitsubishi who from what I can see make Blue Diamond Sky Remote COde
May 29, 2015
Anyone code for programming sky remote bluediamond tv?
Dec 10, 2012
More results from www.boards.ie
Dec 10, 2015 | Televison & Video
It immediately shuts off after I press the "on " button!!
The power converter is bad and needs to be replaced. Check and see what warranty the manufacture might supply. ( I deal with this all summer long at our store)
Mar 25, 2014 | Water Tech Blue Diamond Pro Robotic Pool...
Smartpool nitro won't run
if caddy has power bad drive motor if no power to caddy check transformer or board
Jun 12, 2012 | Smartpool Nitro Robotic Cleaner and Caddy
My Dolphin 5 is completely ignoring the "remote" commands. Only 1 week old!
I would start with contacting the manufacturer directly for assistance. They can go thru basic troubleshooting over the phone and determine what the best course of action is to get it resolved. You can reach them thru www.maytronicsus.com or 1-888-DOLPHIN.
If that doesn't go well please post a comment to this thread and I'll do what I can to assist you further.
John
Apr 14, 2011 | Dolphin Dynamic Robotic Pool Cleaner...
What size suction line is needed to make ulta pool vac work. is a 1 inch line big enough.
not for a navigator... what kind of pump will you be pulling the navigator with
Jun 02, 2010 | Hayward Navigator Pool Cleaner
My caddy handle cracked badly. Are there replacement parts
Yes there are. Contact us through www.arrowpools.net for a parts breakdown and we can quote you what you need.
Aug 24, 2009 | Smart Pool Inc Dolphin Diagnostic...
Need to use the smartpool Orion pool cleaner on 240 volt 50 hz power. A friend bought one in the USA (100v, 50Hz) but is using it in Cyprus where the home voltage and current are different. He has a 240 to...
It will not work on 50 Hz. You could try a variable frequency drive to up the cycles or check with an electronics shop to see if they have a lower cost way of stepping up 50 to 60 cycles, otherwise it won't work.
Jun 27, 2009 | Smartpool Dolphin 3001 Commercial...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
