Electric circuit I need to repair my laptop
  • 25 Answers
What do you need to repair, a board, HVPS what.
Posted on Apr 30, 2013
Testimonial: "is the Electric circuit of main board Asus K42jr a secret ????!!!!"
  • Wasim Saleh Apr 30, 2013
    is the Electric circuit of main board Asus K42jr a secret ?????!!!!
What do I need to do when my PCM fuse keep blowing when I changed my fuel pump & my relay fuse
Diagnose the problem ! Test for a short circuit on the fuel pump circuit ! Go on youtube an check out videos on basic electrical trouble shooting , how to read a wiring diagram , testing for a short circuit . Go to http://www.bbbind.com/free_tsb.html free wiring diagrams an test the circuits ! If then you still can't figure out what's wrong take your vehicle to an automotive electric repair shop .
Apr 26, 2016 | Cars & Trucks
Why does my 20 amp auxiliary fuse keep blowing out immediately on my 2004 Chevy suburban
You have a dead short to ground on that circuit , You need to go to www.bbbind.com/ for free wiring diagrams an electrical distribution diagrams . You'll want to check an see what all loads are on that fuse . Loads = lights ,components,motors etc.. Then if your not familiar with automotive electrical circuits an trouble shooting I suggest you go to youtube an check out basic electrical trouble shooting an how to find shorts etc... Also it would be good to check out how to read electrical wiring diagrams . There is a wealth of information on you tube for beginner auto repair an even for professional Technicians . Do you know anything about auto electrical repair .
Jan 01, 2016 | Cars & Trucks
Lenovo t60 do not turn on
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
Jul 11, 2012 | IBM Lenovo ThinkPad T60
I have XPS M1530 DELL Laptop. DC JACK(power charging port has broken from mother with a very small piece of mother board)....I had tried to call customer care ..he told you should change the motherboard...
If this motherboard is a multi-layer motherboard then it is impossible to repair.
You can try to repair the motherboard by glueing the broken piece onto the motherboard with epoxy glue. Then identify the broken power circuit tracks between both parts of the circuit board, and then solder wires across these tracks or to the closest solder connections to re-establish the electrical connections on the motherboard.
If this does not fix the problem then most likely it is a multi-layer motherboard and you cannot bridge the internal connection inside the motherboard.
Jun 22, 2011 | Dell XPS M1530 Laptop
My son put pennies in the cd player of my new chevy traverse. is this expensive to fix?
It may be anything from a jammed mechanism to a total write off due to electrical damage by short circuits.
It is a job to tell. Take it to an authorised repair agent for an estimated repair cost.
Jan 28, 2011 | Computers & Internet
A105 won't power up...no power adapter light on
Did you experienced any overheating before that happened?
Apr 11, 2010 | Toshiba Satellite A105 Notebook
The start pad does not work. I have to move my
You must call repair since your start pad needs repair
or replacement, to get it fixed.
Sep 25, 2009 | Maytag Neptune MDE5500AY Electric Dryer
MY GATEWAY LAPTOP NO LONGER RECEIVES POWER.
Motherboard or harddrive? I'm betting it's more towards the motherboard. The DC Power Jack to be more specific. This is the port where the AC adapter, (Charger), plug is plugged into.
The DC Power Jack is not much bigger, than the plug for the AC adapter that plugs into it. There are small pin leads that are on the bottom of this jack, and they go through the motherboard, and are soldered to the motherboard.
Accidental bumping of the AC adapter plug, while plugged into the DC Power Jack, can damage the jack. It can break the connections for the adapter plug, and/or can crack the solder joints for those small pin leads.
[Laptops use DC electricity. A flashlight battery, and a laptop battery, are examples of stored DC electricity. DC electricity has two poles. Positive and Negative. The DC Power Jack has two connections. Positive and Negative. {Even if the DC Power Jack has multiple holes in it]
There is also another known problem associated with DC Power Jacks. It may stem from a bad motherboard design.
More to the point, the area where the DC Power Jack mounts on the motherboard. In this design, the DC Power Jack motherboard area, is almost a separate part of the motherboard. It's shaped like a Peninsula. (Think of an island, with one side connected to the mainland)
This peninsula shape, has the tendency to crack away from the main body of the motherboard. Circuit traces are broken.
When the AC adapter plug is setting in a certain position, it presses the two broken halves of the circuit traces together, for a momentary contact. As the AC adapter plug is moved from this position, the circuit trace halves are moved apart, and there is no contact.
(No distribution of electricity from one circuit trace half, to the other circuit trace half. Think of a circuit trace as a very, thin, flat copper wire. When a circuit trace is broken, there is essentially a wire that is broken into two parts)
Solution?
See if the DC Power Jack can be repaired, (Solder joint connections re-soldered), or replaced.
If the DC Power Jack motherboard area is the aforementioned peninsula shape, it may require replacement of the motherboard.
There are very FEW, computer repair shops that have the technical expertise to replace a DC Power Jack. Easy fix is to simply replace the motherboard. (More $$$$$ too)
However, some laptops DO require replacement of the motherboard for this repair.
Bad motherboard design, for the DC Power Jack area on the motherboard.
Re-solder DC Power Jack solder joints? (IF, this is the problem) Average is $50 to $75 (US)
Replace DC Power Jack? Average is $125 to $150. (US)
Replace motherboard? Depends on the Gateway model. Could be $225 to $400 (US)
[Yes, most of the time the cost warrants just replacing the laptop itself, as the cost of replacing, is close to the repair cost)
Just to SHOW you ab average DC Power Jack, and the repair involved of replacing. (Doesn't show you, that the entire laptop needs to be disassembled, down to the bare motherboard in hand)
This is NOT a recommendation to replace the DC Power Jack yourself! It is just for knowledge of what is partially involved. (You can accidentally burn the motherboard when desoldering, or soldering, rendering the motherboard useless)
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Sep 09, 2009 | Computers & Internet
My dell laptop suddenly stopped working without the power cord. power cord needed to be repaired, it had a gash exposing wires. fixed it with electrical tape but it is no longer portable, did i mess the...
It sounds more like the large portability battery has been 'messed' i recommend getting a new power cord. Whist you may have repaired the cabling and it may have appeared to work, the escape circuit for charge may have been broken but it is not required for the laptop to work, but is important when recharging the battery. I recommend getting a new adapter and then if that doesn't work a new large battery also.
Sep 02, 2009 | Dell Latitude D610 Notebook
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
