Question about Refrigerators
Hotpoint ffa71 drain blocked in fridge. i have tried to unblock it by using a nylon tube which went down about two feet and dislodged some food but its still blocked.can i unblock it how
    Master:
  • 482 Answers
You can dampen a small part of folded to 1/2" wide paper towel, and wrap the dampened paper towel around the end of a straw, stick that in the drain hole and blow.
Posted on Apr 30, 2013
SOURCE: How can I unblock my Hotpoint FFA70 fridge freezer
I have had the same problem and to solve it I had to turn the appliance off to allow it to defrost as the blockage was caused by the pipe freezing up.
Posted on Sep 25, 2007
ngfam1
  • 639 Answers
SOURCE: Hotpoint FFA70S fridge drain blocked
PEACE,
ngfam1 at your service,
Do not use sink chemicals!!!!!!!!!!!!!!
In the hard ware stores or home depot they have small short,
snakes that are flexible and thin that can go in the hole to clear it!
Tell the home depot guy to help you find what I'm
telling you to buy!Print this out and show him what I spoke of!
Bless you,
Please give me a good rating before you signe off
Posted on Sep 04, 2008
  • 66 Answers
This will work in most all cases of this type. You need a piece of copper wire, 14 guage, 12 to 16 inches. You can shortin it as you need to Turnoff the power to the fridge. Rap one end of the wire around the evaprorator heater and feed the othe end down the drain tube. This wire will heat up when the heater comes on and will supply heat down into the drain tube hopefully preventing the drain from freezing.
Posted on Nov 19, 2008
SOURCE: Hotpoint FFA71 fridge and freezer suddenly stopped working
Sounds as though the compressor has stopped working. It feeds both compartments with control from a printed circuit above the top door.Where all your red lights are ablaze! (This can be replaced by removing the 2 screws and "clicking" out the small panel) Check that the compressor is running at the bottom rear of the fridge/freezer before anything else.
Posted on Jul 11, 2009
SOURCE: hotpoint ffA71
ffa71 fridge and freezer warm and food defrosted. red light is on. Back of freezer making normal noise. Help.
Posted on Aug 22, 2009
Hi our CB18M/1c/FAN keeps gathering water under the salad trays please advice thankyou
You say it runs down the channels.
Is their a drain hole at the bottom?
If the drain hole is blocked then you will need to unblock it using compressed air or a thin piece of medium flexible wire.
It should drain to a pan near the compressor and evaporaste from
there. Sometimes a loose particle of food can block the drain, usually at the back lower position of the fridge.
Jul 25, 2015 | Refrigerators
Water leak fridge
The condensation in a fridge is generally routed to a small drain hole at the bottom at the back. The water drained off here normally drips onto the compressor unit (the big black ball thing at the back) where it gets evaporated off, due to the heat the compressor generates. Before taking steps to unblock the drain, you might consider defrosting the fridge first. When unblocking the drain, do not use wire, unless the fridge is switched off and unplugged, you never know where that wire will end up (electrocution risk!). There are two good ideas for clearing the blockage. The best way off clearing the tube is with compressed air, often difficult to get in your kitchen, but don't despair, there could be two solutions in your garden shed. If you have a Weed-killer Spray that uses a pump to pressurise the spray pot, you could use that to clear the blockage (with a bit of ingenuity). Clean the spray thoroughly first, you don't want to poison anything in the fridge, and use the spray with no liquid in it. You can take off the spray nozzle and use the pipe in the hole. If you need to manually unblock the tube, you could use a hard nylon "cord" that is used in a garden strimmer. Pocking that down the hole and into the pipe should do the trick. It's flexible enough to get around the corners in the pipe and when it emerges at the other end it won't electrocute you if it touches a live connection. Lastly, having removed the blockage, put a very tiny bit of "plughole unblocker" fluid in the pipe, that will clean out all the other residue not pushed out with the cord. Good Luck!
May 11, 2014 | Fisher and Paykel Active Smart E522B...
Clogged drain line, water build up inside food compartment
if lucky you can unblock it with a wire coat hanger, just unravel hanger and push down drain hole.
this does not work pull fridge out and u will see the hose running down to the dissapeter, remove it and clean
if you cant see hose at back it is internal and cannot be taken out
find hole above compressor where water comes from and try to unbock from bottom using coat hanger
if blocked with ice at bottom usually means insulation has broken down...new fridge needed
Sep 25, 2010 | Refrigerators
I have a 1 1/2 year old fridge, I'm getting a
yes the drain plug hole is blocked.get two pipe cleaners and screw them togather and plunge them down the drain hole to unblock..adrian;;;
Nov 14, 2009 | Refrigerators
Same Problem ...Drain Hole Freezing up.
After facing the same issue (defrosting, cleaning the drain, drain gets blocked again...start again: defrost, etc..) I decided to try to give it one last go:
1. Defrost
2. Clean & rinse the drain (ensure is fully clean and I can pass liquid through the drain).
3. Get a ~30 cm pure copper wire
In my case I took a 3amp power cable, and took the copper wire from one of the cables.
4. Wrap one end of the copper wire around the copper coil at the back of the fridge (where the coil is warmest)
5. Insert the other end of the copper wire in the drain (just above the drip tray). I inserted ~15cm of wire into the drain.
The purpose of these last steps was to ensure there was no "freezing" happening on the drain. The copper effectively will keep the temperature inside the drain above freezing.
Not sure how permanent this might be.. so far at least I'm getting more months than with the previous symptoms treatments ;)
Best of luck!
Jul 09, 2009 | Hotpoint RFA60 Bottom Freezer Refrigerator
Jun 30, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Freezer leaks into lower section
there is a drain pipe that goes to the bottom of the fridge . push a flexible hose down it to unblock it , it is for the auto defrost .
Apr 01, 2009 | Hotpoint  17.2 Cu. Ft. Top-Freezer...
Hotpoint FFA70
Nov 19, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
PEACE,
Bless you,
Sep 04, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hotpoint ffA71
Aug 27, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
