Question about Dell Latitude D630 Notebook
Labtec lcs 1070
Speaker with control buttons only works if surround is on
    Master:
  • 663 Answers
The problem has something to do with the sound driver. I suggest that you update the sound card driver in your computer. You can use RadarSync to scan and update the driver/s in your computer. This software will cover all driver-related problems.
David
Posted on May 01, 2013
NR626 - no sound
If none of your speakers gives any sound, perhaps you pressed the mute button on the remote control?
Make sure you have a source selected, that will give sound. Choose a low volume, before switching anything. You can destroy your speakers, when switching on with full volume.
If some speakers work, and only the surround does not work. check if you have surround sound as input. If you only feed 2 channels you can't expect to hear more than 2 channels.
Jul 01, 2014 | Onkyo TX-NR626
Philips troubleshoot
It an issue with most Home Theatre.The surround speakers do not work automatically unless the system is set on surround mode.The audio mode or surround button can be used to select the surround mode.
Dec 22, 2013 | Audio Players & Recorders
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
Connect creative 4.1 speakers with laptop at time 2 speaker work
i assume ur mother board supports surround sound an ur using windows os. go to control panel - sounds and audio devices - speaker settings-advanced - speaker set up with the drop down menu. select surround sound - apply - ok.
if ur using surround audio drivers like realtek, etc. the settings console should have somewhat similar options like audio input/output (I/O) options. select surround sound speaker setting and configure which audio port should be audio output ports. driver settings can be accessed from control panel too. to access control panel click on start menu there u'll see the control panel menu.
Mar 13, 2010 | Creative Labs Audio Players & Recorders
Switch our tv to souround sound
Surround sound will come from the speakers from your surround system. So if you have it connected through HDMI 1 select that option from the source button on the remote control. If you have it connected through Scart 1 then select AV1 from the source button. It also best to turn the volume from the TV to minimum so that the sound only comes from the surround speakers.
Mar 23, 2009 | LG 47LG50 47 in. LCD HDTV
Lost my sound in my surround speakers
Check your speaker setup onscreen ( monitor) viewed configuration, be sure you are enabling SURROUND SPEAKERS, or REAR SURROUND if you are running 7.1, then check the AUTO input to be sure you are receiving a MULTI-CHANNEL SIGNAL within the DIGITAL/ANALOG source. Cycle through the DSP Analog modes ie. Pro-Logic, Rock Concert etc. and check your DIGITAL signal indicator for a 5.1 DD or DTS input, if you hit a unitentional button then you will just need to reset it back to prior operation before loseing the surround speakers.
Feb 20, 2009 | Denon Audio Players & Recorders
Reciever only allows 2 channels(speakers) at a time.
I had this problem too. Finally, after using the MCACC setup and making sure all the speakers worked, I found I had to set the source to FM, TV or whatever from the remote control and set the mode to advanced surround sound using the front panal button on the upper right. Had to fool with them a lot. Good luck.
Jan 03, 2009 | Pioneer VSX-818V-K Receiver
Only 3 out of 5 soround sound speakers are working on my surround
I had this problem with my surround. The way I solved mine was by hitting the "sound" button and it showed me a small symbol that looked kinda like speakers and I hit the button a few times untill all of the speakers were lit up. Your button may be different but you can use what I tried as a guideline on how to try and figure yours out.
Dec 29, 2008 | Logitech X-530 Computer Speakers
I lost my remot control and the manual
you can purchase this items thru phone calling jvc directly 1-800-252-5722 or on there website jvc.com. the remote will cost $27.01 and the manual $6.18 plus tax and shipping. you can pay with visa or mastercard. if you hear sound thru 2 speakers there's a surround button on remote that can get the rest of speakers working. or you will need to check speaker connection and set unit to right surround setting by pressing surround button.
Nov 17, 2008 | JVC THD-50 System
Dell Latitude D630 Notebook Logo
47 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
