Question about Toshiba TP50G90 50" Rear Projection Television
Toshiba TN55X81 Projection HDTV
I'm in desperate need of some good advice. My picture went out on my Toshiba. It's just a sad black screen. When the power is one,there is this pounding vibrating noise eminating from the tv. Can you help me? Thanks, DW
Your Rear Projection LAMP has been expired , get it replaced with new one .
Posted on Sep 18, 2007
    Problem Solver:
  • 18 Answers
Have you opened it upto see if there is any illumination from the projector need more info.....
Posted on Aug 08, 2007
SOURCE:
What powers the picture tubes in a 55 inch model tn55x81
The tubes in the projection set among other things need: 200 volt screen source, filament voltage and high voltage.
Note that if set for example has a loss of vertical or horizontal sweep this will be detected and the tubes will be shut off to prevent the tubes from getting a burn mark on their screens.
Nov 06, 2012 | Toshiba TN55X81 55" Rear Projection...
Center bow on picture top and bottom with 1" black showing
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba TN55X81 55" Rear Projection...
My toshiba rear projection TV's picture just went black. Sound is good just a black screen.
high voltage is not coming up. possible fuse locates on power supply board on the right if you are sitting behind set with back off. if fuses are good, possible horizontal output transistor shorted. sounds horrible but easy repair
Nov 10, 2009 | Toshiba 42H82 42" Rear Projection...
I have a Toshiba TN55X81 that has sound but no picture. Turned it one one day and no picture. I don't see any error code blink when I power on the set.When the set is turned off a line flashes across the...
It shouldn't be the convergence chips. You may have blown a pico fuse on the power board.
You should be able to safely remove the convergence IC's and try the tv without them as they only do image correction.
Oct 13, 2009 | Toshiba TN55X81 55" Rear Projection...
Toshiba TN55X81 screen shifted
horizonntal circuit seems not to be working
May 26, 2008 | Toshiba 51H84 51" Rear Projection...
Toshiba TN55X81
Blue Convergence IC is bad = change both for reliable repair..
located on largest heatsink on chassis.............T.
Feb 02, 2008 | Toshiba TN55X81 55" Rear Projection...
Toshiba tv model Cinema series HDTV Model# tn55x81
my thought is that it's something with the closed captioning, fiddle with those settings in the menu, or with the devices like VCR or DVD if you're using something like that as a tuner.
Nov 16, 2007 | Toshiba 51H84 51" Rear Projection...
Toshiba TN55X81
What's the model number, the TN55X81, or the 51H84?
Jul 24, 2007 | Toshiba 51H84 51" Rear Projection...
Televison & Video Logo
177 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
