When trying to turn my camera on in photo mode, the camera comes on for a brief moment and then shuts off again. I cannot get it to stay on. I can access the various tool bars and it will stay on in MP and Video mode. Is there something I can do to get it to stay on?
SOURCE: Digital camera samsung 301
The camera has died Get onto Samsung Tehnical Support for their solution
SOURCE: mode dial on samsung camera
You just have to turn it (not sure if its clockwise or counter clockwise).
SOURCE: Will not turn on
Sounds like your lens is stuck. Try a gentle tug and it should open all the way. Then you can power your camera down.
SOURCE: Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
SOURCE: On start-up, Samsung S860 beeps 3 times then turns itself off
first off,never use rechargable batteries in this camera or most digital cameras for that matter.2 use only lithium batteries,enegizer preffered.,also yes you can view all your pictures when connecting the usb,meke sure you turn the power on,and highlight the word computer,push ok.you should be fine.good luck .i hope i helped
