Question about Vehicle Parts & Accessories
Radio control Volume control is not working right
  • 25 Answers
Ok,
what is it doing.
Posted on Apr 30, 2013
Radio volume control on 2008 Subaru Tribeca does not work, but remote volume control on steering wheel works. Any suggestions on repairs?
Replace the volume control(rheostat) inside the radio. Only way to fix it. I would personally just live with it until one or the other quits working. Then replace the radio.
Jun 07, 2015 | 2008 Subaru Tribeca
The radio plays full volume on right channel when turned on.
Anything I tell you is going to be a guess, since there has been no testing done, and we don't have the model number of the specific radio involved. However...
For a 20 year old radio, the volume and balance is almost certainly controlled by a potentiometer that has input into one leg of the fixed resistance, and the other leg (of the fixed resistance) is grounded. The movable center tap is the output to the amplifier - and its position controls the volume to that channel. If the ground leg becomes disconnected (broken wire, or a cold solder joint, or even a break in the resistor within the body of the potentiometer) then instead of "dividing" the volume, it simply provides a slight resistance inline - short answer: It goes full volume.
You can try running the control full range back and forth, and even just the old time "slap it" approach, to see if you get any static or change. If you do, that pretty well confirms the diagnosis. [If not, it just means the break is not close to touching - still almost certainly the right answer though.]
Only fix is going to be disassembly. You then may be able to find the break (and resolder it), and/or replace the volume potentiometer. Note that if you have remote volume/balance control (controls on the steering wheel), then there is some extra wiring that can likewise be involved. jk
Feb 27, 2015 | 1995 Jeep Grand Cherokee
How fix talkback in magnum delta force
you need to check the audio path from the chatback board to the audio circuit
usually the audio out the board will go to the center connection
on the volume control
sometimes people use a resistor to attenumate it to a level
or a T pad
and connect it to the left side {audio out to amp}
so a volume control works like this
left center right
ground audio into control audio to amp
so usually the center is used as the volume will track up as your sets volume is increased
so simply connect the audio out from the chatback
to the right audio to amp section
on the chatbacks ive made and installed in the past
had a small pot on the board
this allows the volume from it too be increased
so look for this first
if you cant find it you can make one up like this
100K log pot 3 pin
1 2 3
L M R {left middle right}
1= ground
2= audio from chatback
3= audio to the right right audio to amp on the cb's volume control
then no matter what level the actual audio from the set is set too
the chatback can be set to a standard level for all
hope this helps you
i used too build chatbacks for the rnid year back and fit them free
Dec 02, 2014 | Magnum DeltaForce CB Radio
Need to replace volume potentiometer on BC-60 XLT scanner
make a trip to radio shack for a replacement volume control..
Feb 02, 2014 | Uniden Radio Communications
Radio volume control on 2007 Subaru Tribeca does not work, but remote volume control on steering wheel works. Any suggestions on repairs?
Radio volume control on 2008 Subaru Tribeca does not ...
www.fixya.com/.../t25735073-radio_volume_control_2008_subaru_trib...
Jun 7, 2015 - Radio volume control on 2008 Subaru Tribeca does not work, but remote volume control on steering wheel works. ... does not... Replace the volume control(rheostat) inside the radio. .... Oct 09, 2014 ' 2007 Subaru B9 Tribeca.
Nov 04, 2013 | 2007 Subaru B9 Tribeca
Milwaukee Jobsite Radio 49-24-0200 Ser.-414c Volume Fades
the volume control needs to be cleaned. if you can carefully take the back off, the volume control may have some small openings in the housing. spray contact cleaner (or even a small amount of wd40) in it and work the control back and forth and see if that does it
Aug 09, 2009 | GE Superadio III AM/FM
Volume will not change for the Radio in a 2000 FLHTCUI Harley
Radio was damaged in wreck, needs to be repaired. www.ironcrossaudio.com
May 14, 2009 | Harley Davidson 426290 AM/FM Radio
Harmon/Karden 2006 Radio/CB/CD Passanger control does not work
The passenger controls on the rear speakers are pretty easy to diagnose.  The wire for Volume up is Pink/white, the volume down is gray/white.  If the Pink/white wire is shorted to ground somewhere, then as soon as you turn on the radio, it will be like having the volume selector pushed up, and it makes sense how you describe it goes to mute and then returns to full volume as soon as you let go.   You don't say what model it is (I doubt it's a Road Glide, gotta be an Ultra), so it's not too hard to get at.  Pull the outer fairing and look on the back of the HK Radio.  There are 2 big connectors, when looking from the front you want the connector on the right.  Pin 23 is down volume, pin 34 is up volume for the rear controls ONLY.  So I would check the continuity to ground at pin 34 first, in other words pull the connector off the back of the radio, take a test lead and hook one end to +12v. Touch the tip to any grounded metal and it should light.  Now touch the tip to pin 34 on the harness side of the connector.  If the test light lights up, you have a short to ground on the pink/white wire.  Now go to the right rear speaker on the tour-pak and disconnect the 6 pin connector and try the test again.  The pink/white goes from pin 34 on the radio and runs through the harness to the passenger controls and nowhere else.  It shouldn't be grounded anywhere.  Let me know what you find out.
Jan 13, 2009 | Harley Davidson 426290 AM/FM Radio
Radio, CD Player
The volume control is digital, the circuit that controls volume has a problem, have it repaired, there is nothing you can do to fix it.
Sep 24, 2008 | 2001 Chrysler 300M
No sound in one ear
Have the volume control to be repaired, they a cellphone repair shop. If they can't... suggest to bypass the volume controls to its maximum control and buy an earphone that has volume control on it.
Jan 02, 2007 | Aiwa CR-LD120 AM/FM Radio
Vehicle Parts & Accessories Logo
22 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
