Lands Phones Logo
Anonymous Posted on Apr 30, 2013
Vodavi Model 8003
Problem dialing out on this model from hotel room.
czarboom
Level 1:
  • Contributor 25 Answers
  • Posted on Apr 30, 2013
czarboom
Contributor
Level 1:
Answers
25
Questions
0
Helped
7423
Points
93
Cell phone? Are you staying in a hotel with cinder brick if so there is metal in the brick, and it makes a emi/emf shield. If not and its a land line, check the battery, microphone, and phone line. (u will need a tester for that)
good luck
Testimonial: "Read the question before replying with answer..."
1 Related Answer
Anonymous
  • 448 Answers
  • Posted on Jan 08, 2009
SOURCE: set up of replacement Vodavi 5000-00
If this hasn't been solved, I am a certified Vodavi tech. Give me a ring
My toy blast game is stuck on waiting and won't work and won't let me delete it
The Omega Model 8003 Nutrition Centeris Omega's single gear, masticating juice extractor that will serve all of your juicing needs and many other needs, such as mincing, grinding, homogenizing, etc.
The 8003 model replaces the 8002 model. Both models use the single gear extraction method, and feature a patented auger that features two stage juice extraction which helps to increase yield over other single stage auger juicers. In addition, there are less parts to clean with the 8003 than with the previous 8001 and 8002 models.
This unit is a "multiple use" appliance that actually does all of its uses very well. Most appliances that are built for more than one use tend to compromise one task or another. But the Omega Model 8003 Nutrition Center excels at all of its functions.
The 8003 auger turns at a low 80 RPMs to ensure that nothing is lost through heated elements in your juice. This low speed also helps the Omega 8005 foam less than a double gear style juicer.
This heavy-duty juicer features a patented, stone mill-like screw, made of hygienic U.S. FDA-approved melamine, which prevents poisonous heavy metals from mixing with your fresh juices.
The Omega 8003 Nutrition Center's low speed of 80 RPM's ensures full taste and the highest nutritional value.
The Omega 8003 Nutrition Center is easy to assemble and disassemble for quick cleaning.
The Omega 8003 Nutrition Center assures you many years of trouble-free, dependable service. Ten-year warranty on all parts and labor.
The 8003 has multiple uses:
1.Vegetable Juicer
2.Fruit Juicer
3.Wheat Grass Juicer
4.Mincing/Chopping
5.Grinding
6.Soy Milk
7.Frozen Dessert Maker
8.Nut Butters
9.Baby Foods
10.Pasta Maker
Just look at some of the things the Omega 8003 Nutrition Center can do:
Vegetable and Fruit Juice Extractor
Omega 8003 Nutrition Center efficiently juices fruits and vegetables. It will even juice citrus fruits, usually one of the hardest fruits to juice. In addition, it will juice vegetables like carrots, beets, celery, peppers, and radishes without destroying the natural flavor and nutritional benefits. Fresh taste and full nutrition are guaranteed with this unique extraction process.
Wheatgrass and Leafy Greens
Wheatgrass, kale, chard, cabbage, spinach, and pine tree needles are just some of the natural products that can be juiced with the Omega 8003 Nutrition Center. Enjoy the best that nature offers in raw foods of all kinds and juice them for full nutritional benefits.
Food Processor
The Omega 8003 Nutrition Center chops and minces, proving natural flavor and nutrition from garlic, scallions, red pepper, ginger and most other foods, including herbs and seasonings. Soft foods for special diets (i.e. babies and geriatric patients) are quick and easy to prepare with the mincing set-up. The Omega 8003 will also allow you to make pasta. You simply make the pasta dough, and let the machine extrude the long pasta-like shapes.
Homogenizer
Make fresh frozen desserts, natural baby food and nut butters using your fresh ingredients. Tip: Try peeling some ripe bananas, freezing in a zip lock bag, and then put it through the 8003!
Grinder
Grind coffee beans, flour and even boneless meats.
Did you know Omega just released the Omega 8004? They took the 8003 and made it even better!
Specifications:
*.Single Gear "Masticating" Extraction
*.Low Rotation Speed of 80 RPMs. Powerful motor chews the plant fibers and penetrates membrane to extract vitamins, enzymes, and mineral content.
*.Continuous juicing with Automatic Pulp Ejection
*.High juice yield - very dry pulp
*.Single gear produces less foam than double gears
*.No heat rise promotes a healthier juice
*.Includes 6 nozzle (end caps) to extrude pasta shapes.
*.Heavy duty construction using the highest quality materials
*.Engineered for quiet operation and long-life
*.Built-in "reverse" prevents clogging
*.User friendly - easy to assemble, operate and clean.
*.No separate attachments needed
*.10 year Limited Warranty
*.UL and cUL approved
*.LABELED for HOUSEHOLD and COMMERCIAL USE
*.120 volts 60 Hz 150 watts
I run a hotel and put a phone in a room that was a storage room and never had one before. I have a dial tone but anything I press doesn't register. I cant get out and when I dial 0 for the front desk, I...
Hello -
Since the telephone works fine when plugged into phone jacks in other rooms, then, the problem is with the phone line in the room which was a storage room.
You will need to find an hire a technician who is familiar with new phone line installation and switchboards.
Best wishes.
Vodavi Starplus STS No Dial Tone, Plugged in to phone line
yes
These phones 3501-71 is that the model number ?
Are digital phones that you are plugging into an analogue phone line.
what you might need is a 3501-00 Vodavi/VerticalStarplus STSe Basic KSU
https://www.pcliquidations.com/p2820-vodavi-vertical-starplus-stse
or
http://www.americantelebrokers.com/vodavi-stse-3501-00-basic-key-service-unit-4x8x2-bksu-refurbished.html
these experts may be even able to advise if I am on the right solution .
look up on internet what a PABX is to get a deeper understanding .
2answers
What sized beds are typically found in hotel rooms?
In hotel rooms, you usually have the option ofchoosing between queen and king d bed as the main bed in the room.
Jul 30, 2012 • Furniture
4helpful
Can't access Vodavi STS Starplus voicemail to program it
THE VOICEMAIL OF OUR PHONE SYSTEM IS NOT WORKING RIGHT...
11helpful
3answers
Cant figure out how to make it ring.
I am a Vodavi tech. Go to station 100 and with handset on hook dial **3226 and tell me what it does.
Set up of replacement Vodavi 5000-00
2answers
Wireless in hotels.
Most hotels provide a service using different providers. Check with the hotel your staying at. It will work in the US and Canada.
Can't get outside line
If this hasn't been solved, I am a Vodavi certified tech. Give me a ring
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
