Question about Rival CZF530 Deep Fryer
Trying to ignite my 1800 gh broaster after relocating. does any one have pilot ignition steps?
I have a broaster that turns on but will barely heat the oil. Does anyone know what would be causing this?
Is it made by the Broaster Company or a spin off like a Henny Penny? Is it gas or electric? If by the Broaster Company would it be a 1800 or a 1600? Give me this information and than I can tell you what the problem is. Not an expensive fix either.
May 09, 2014 | Broaster Pressure Fryer
Self igniting hot water heater won't reset.
Today's water heaters have sealed combustion chamber and piezo igniter.
If igniter is bad, then water heater will not light... replace igniter.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#pilot
http://waterheatertimer.org/How-to-light-gas-water-heater.html
Gene h
Mar 31, 2014 | Water Heaters
Broaster 1800 machine is over shooting oil from top back steam valve and the valve that goes to little bucket in front
Dan,
Sorry, I am new to this site, and did not know about it until today. I am a Broaster distributor, and have the parts available. Couple questions if you have not resolved issue yet. Does your pressure guage work? If so how much does it read with about 8 pieces of chicken in a load?
Jon
jondf1@gmail.com
Dec 16, 2012 | Broaster Pressure Fryer
Middle section ticking sound with sparking as if trying to ignite even though knobs aa
see this steps and fix it. God bless yo
Relight an oven pilot:
  1. Turn all controls off, open the doors, and allow gas to dissipate.
  2. Hold a lighted match near the tip of the pilot on the burner assembly. If a burner does not light within two minutes, adjust the pilot, step 3.
  3. Turn the pilot adjustment screw (located near the pilot or the thermostat) in small increments and retest until the pilot has a blue flame.
  4. Check and replace an oven spark igniter:
  5. Turn all of the appliance controls off.
  6. Open the door and remove the oven bottom and the baffle (see above).
  7. Unscrew the igniter from its mounting bracket and inspect it for cracks or other defects. Replace it if it is damaged.
  8. To replace a faulty igniter, find the ignition control module, unscrew the cover, and disconnect the module. Install the replacement part and test.
Oct 02, 2012 | Fisher and Paykel GC36 Gas Cooktop
Im having problems with my Model 1800 broaster. The pilot light goes out once in awhile. But, sometimes when the Heat light is on the burner is not burning but the pilot light is on. It will just stop
If the problems are as you describe, they are actually two separate problems and aren't related. If your unit was manufactured before 1999, it has a standing pilot that should stay lit all the time. If it is just droppiing out intermittently, check the J-Block circuit. That is the two wires that connect between the Hi Limit and a brass adaptor that the pilot burner thermocouple is plugged into. These are some fairly fine wires that as the unit ages become brittle. It is lilkely that they are making intermittent contact, which is causing the pilot to drop out.
If your burner is occasionally quitting when the pilot is still lit and the Heat On light is still on, you need to check the voltage from the control panel to the gas valve (assuming this is a solid state controlled unit). If the 120V is still present, the gas valve is at fault. If the 120V is not present (and the Heat On light is definitely on) then the controller is at fault. If this unit has a mechanical thermostat and timer, then the only cause for the burner dropping out while the Heat On light is on is either a bad gas valve or intermittent electrical connection between the gas valve and the thermostat.
Jul 13, 2012 | Kitchen Appliances - Others
I need wiring diagram for a Broaster pressure fryer Model 1800E
I have a service manual for the 1600 and 1800 Broaster and it has wiring diagrams in it
Nov 03, 2009 | Kitchen Appliances - Others
Pilot light will not ignite on my bosch 10p water wizard system
This process is best performed at night so you can see the pilot light in action.
Important...*ensure all hot water taps are off*
1) press and hold pilot button (extreme left button)
2) press spark button (extreme right button) while holding in pilot button from step 1
3) with the pilot button still held in, observe the pilot light through the window. if there is no pilot light now, your heater is busted.
4) if you see the pilot light above, very quickly *completely* remove your finger from the pilot button while at the same time pressing in the flame button (second from left - this button will not work until you completely remove your finger form the pilot button so timing is important) - the pilot light should stay lit.
5) if it goes out or your timing is off, repeat these 4 steps until it lights.
This could take a number of tries and can be quite frustrating until you can get the timing of step 4 right. Good Luck!
May 26, 2008 | Video Game Consoles & Games
Rival CZF530 Deep Fryer Logo
59 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ric Shull
Ric Shull
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
