Question about Vauxhall Astra Double Din Fascia Panel Stalk Interface Stereo Patch Lead
Radiator removal how do I remove the coolant radiator
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 139 Answers
Typical removal
drain fluid in a pan. Draincock on drivers side at the bottom, hand screw out.
take off upper and bottom hose.
take off fan shroud.
unscrew oil and transmission cooler lines if equipped.
pull out fan.
installation in reverse steps.
fill coolant One inch below neck line.
hose down any excess coolant splatter not collected in pan to neutralize to protect cats, dogs, pets.
Posted on Jun 09, 2014
How do you remove a radiator
remove radiator no problem, just drain radiator using clean large drain pan.you can buy drain pan at any auto parts stores.just drain radiator remove top radiator support and cooling fan.then remove top and bottom radiator hoses and remove the transmission cooler lines.when replace radiator good time replace all coolant hoses and replace thermostat and radiator pressure cap if good time replace radiator with new coolant.
Mar 23, 2013 | 2000 Ford Taurus
How do i remove a radiator from a 2002 jaguar typex
FIRST YOU DRAIN OUT THE COOLANT SYSTEM.DRAIN THE EXPANSION TANK REMOVE EXPANSION TANK HOSES FROM RADIATOR.REMOVE COOLING FAN MOTOR AND SHROUD.REMOVE UPPER RADIATOR HOSE, REMOVE RADIATOR LOWER COOLANT HOSE. REMOVE CONDENSOR TO RADIATOR MOUNTING BOLTS.DISCONNECT TRANSMISSION COOLER LINES FROM RADIATOR.REMOVE RADIATOR SUPPORT RELEASE CLIPS OR BOLTS MOUNTING FIXTURE. THEN REMOVE THE RADIATOR.
Jun 13, 2011 | 2002 Jaguar X-Type
Looking for the fill plug on a 200 dodge darango 4 wheel drive front punkin all i see is a vent pipe
COOLANT-ADDING ADDITIONAL
Do not remove radiator cap to add coolant to system. When adding coolant to maintain correct level, do so at coolant reserve/overflow tank. Use a 50/50 mixture of ethylene glycol antifreeze containing Alugard 340-2 y and low mineral content water.
Remove radiator cap only for testing or when refilling system after service. Removing cap unnecessarily can cause loss of coolant and allow air to enter system, which produces corrosion.
COOLANT LEVEL CHECK
The cooling system is closed and designed to maintain coolant level to top of radiator.
WARNING: DO NOT OPEN RADIATOR DRAINCOCK WITH ENGINE RUNNING OR WHILE ENGINE IS HOT AND COOLING SYSTEM IS UNDER PRESSURE.
Remove radiator cap. The coolant level should be to top of radiator. If not, and if coolant level in coolant recovery bottle is at ADD mark, check for:
  • An air leak in coolant reserve/overflow tank or its hose
  • An air leak in radiator filler neck
  • Leak in pressure cap seal to radiator filler neck
TRANSMISSION and OIL LEVEL CHECK TUBES
Mar 04, 2011 | 2000 Dodge Durango
Were is the thermastat
Hope this helps, it it does please leave feedback and vote Thank You and Good Luck
Removal Procedure
84978514
  1. Remove the air inlet duct.
  2. Remove the necessary coolant from the radiator. Refer to Draining and Filling Cooling System.
  3. Remove the upper radiator inlet hose.
  4. Remove the coolant outlet bolts.
84978515
  1. Remove the coolant outlet from the lower intake manifold.
  2. Remove the thermostat gasket.
84978516
  1. Remove the coolant thermostat.
  2. Clean all the sealing surfaces of the coolant outlet.
  3. Clean the sealing surface on the lower intake manifold.
Jan 02, 2011 | 1999 GMC Jimmy
How do you replace the radiator in a 1997 Ford Escort?
Check this procedure to REMOVAL & INSTALLATION
(1.8L and 1.9L Engines)
CAUTION Never open, service or drain the radiator or cooling system when hot; serious burns can occur from the steam and hot coolant. Also, when draining engine coolant, keep in mind that cats and dogs are attracted to ethylene glycol antifreeze and could drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantities. Always drain coolant into a sealable container. Coolant should be reused unless it is contaminated or is several years old.
  1. Disconnect the negative battery cable.
  2. Place fender covers on the aprons.
  3. Raise and safely support the vehicle. Drain the cooling system.
  4. Remove the right and left-hand front splash shields.
  5. Disconnect the lower radiator hose from the radiator.
  6. If equipped with an automatic transaxle, disconnect the lower oil cooler line from the radiator. Remove the oil cooler line brackets from the bottom of the radiator.
  7. Lower the vehicle.
  8. If equipped with an automatic transaxle and air conditioning, remove the seal located between the radiator and the fan shroud.
  9. If equipped with an automatic transaxle, remove the upper oil cooler line from the radiator.
  10. If equipped with the 1.8L engine, remove the resonance duct from the radiator mounts.
  11. Unplug the cooling fan motor electrical connector and the cooling fan thermoswitch electrical connector.
  12. If necessary, remove the cooling fan thermoswitch for clearance.
  13. Remove the three fan shroud attaching bolts and remove the shroud assembly by pulling it straight up.
  14. On some 1.9L engines equipped with A/C, remove the upper radiator air deflector from the radiator and set it aside.
  15. Remove the upper radiator hose and the two upper radiator mounts.
  16. If equipped, remove the fluid cooler tube bracket bolts and coolant overflow hose from the radiator.
  17. Remove the radiator from the engine compartment by lifting it straight up.
2.0L Engine
(1997 MODELS)
  1. Remove the fan motor, blade and shroud assembly.
  2. Raise the car and support it with safety stands.
  3. Unfasten the left-hand splash shield bolts and remove the shield.
  1. Drain the cooling system into a suitable container.
  2. Disconnect the lower radiator hose and if equipped with an automatic transaxle, the lower oil cooler outlet tube.
  3. If equipped with an automatic transaxle, Unfasten the oil cooler tube bracket bolts.
  4. Lower the car and disconnect the upper radiator hose.
  5. Remove the radiator cap and disconnect the radiator overflow hose.
  6. If equipped with an automatic transaxle, disconnect the upper oil cooler outlet tube.
  7. Unfasten the four radiator bracket bolts and remove the radiator from the engine compartment.
To install:
  1. Install the radiator and tighten the bracket bolts.
  2. If equipped with an automatic transaxle, connect the upper oil cooler outlet tube.
  3. Install the radiator cap and connect the radiator overflow hose.
  4. Connect the upper radiator hose, then raise the car and support it with safety stands.
  5. If equipped with an automatic transaxle, tighten the oil cooler tube bracket bolts.
  6. Connect the lower radiator hose and if equipped with an automatic transaxle, the lower oil cooler outlet tube.
  7. Fill the cooling system with the specified amount and mixture of coolant.
  8. Install the splash shield and tighten the bolts.
  9. Lower the car and install the shroud, blade and fan motor assembly.
  10. Start the car and check for coolant leaks.
Hope helps (remember to rate this asnwer).
Nov 11, 2010 | 1997 Ford Escort
How to replace a water pump on a 2000 GMC Safari
drain the radiator coolant,remove air cleaner assy,remove the mass iarfow,remove the upper shruod,remove drive belt,remove fan and fan blade assy,remove coolant pump bolts and pulley,disconnect the coolant byoass hose and clamp,disconnect the radiator hose from coolant pump,remove the 4 coolant punp bolts coolant pump and the gasket,,revise at installation.
Jun 28, 2010 | 2000 GMC Safari
Where is the drain plug for the radiator
Should be a drain **** at the bottom of the radiator that unscrews out. It looks like a wing nut has been welded to a bolt on the end of it. Another way to do this is just pull off the bottom hose.
Mar 31, 2010 | 2001 Jeep Cherokee
How to remove radiator on 1992 pontiac bonneville se
Removal & Installation
  2. Drain the engine coolant into a suitable container.
  3. If necessary for access, remove the air cleaner, mounting stud and duct.
  4. Remove the upper fan mounting bolts.
On some vehicles, such as this 1998 model, remove the upper fan mounting bolts
  1. Unfasten the retainers, then remove the upper radiator panel.
Unfasten the upper radiator panel fasteners, then remove the panel
CAUTION When draining the coolant, keep in mind that cats and dogs are attracted by ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old. To avoid being burned, do NOT remove the thermostat housing cap while the engine is at normal operating temperature. The cooling system will release scalding fluid and steam under pressure if the cap is removed while the engine is still hot.
  1. Remove the cooling fans, as outlined later in this section.
  2. Disconnect the coolant reservoir hose from the radiator neck and the radiator hoses from the radiator.
Unfasten the hose clamp and disconnect the coolant reservoir hose from the radiator neck
Disconnect the remaining hoses from the radiator
  1. If equipped, unplug the cooling sending unit electrical connector.
On some vehicles, you must unplug the coolant sending unit electrical connector
  1. If equipped, disconnect the engine oil cooler lines from the radiator.
  2. If equipped with an automatic transaxle, disconnect the transaxle cooler lines from the radiator side tank.
Use a flare nut wrench to disconnect the upper transaxle oil cooler line
Jan 18, 2010 | 1992 Pontiac Bonneville
Radiator replacement
  1. Remove air cleaner and duct assembly.
  2. Drain the coolant.
    1. Remove the engine mount struts.
    2. Remove the cooling fans with the cooling fan shroud.
    3. Remove the radiator upper hose from the radiator.
    4. Remove the radiator lower hose from the radiator.
    5. Disconnect the transaxle oil cooler lines from the radiator.
    6. Remove the radiator brackets and bolts.
    7. Remove the radiator. Installation Procedure
    1. Install the radiator. Notice: Refer to Fastener Notice in Service Precautions.
      1. Install the radiator brackets and bolts.
        • Tighten the bolts to 24 Nm (18 ft. lbs.) .
      1. Connect the transaxle oil cooler lines to the radiator.
      2. Install the radiator upper hose to the radiator.
      3. Install the radiator lower hose to the radiator.
      4. Install the cooling fans with the cooling fan shroud.
      5. Install the engine mount struts. Notice: When adding coolant, it is important that you use GM Goodwrench DEX-COOL (R) or HAVOLINE (R) DEX-COOL (R) coolant. If Coolant other than DEX-COOL (R) or HAVOLINE (R) DEX-COOL (R) is added to the system the engine coolant will require change sooner; at 50,000 km (30,000 mi) or 24 months.
      6. Fill the cooling system.
      7. Install the air cleaner and duct assembly.
Jun 28, 2009 | 2000 Chevrolet Venture
Vauxhall Astra Double Din Fascia Panel Stalk Interface Stereo Patch Lead Logo
43 people viewed this question
Top Kenwood Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Kenwood Vehicle Part and Accessory Expert? Answer questions, earn points and help others
