Question about Garden
Small engines Won't start.
  • 25 Answers
Ok, what have you tried to do, need details, either that or I would say put batteries in it.
Posted on Apr 30, 2013
Won't start
Check for power on the small wire at the starter with the key in the crank position. If there is no power than you will need to trace the circuit. A Year, make, model, and engine size would help a lot!!
Jun 16, 2013 | Cars & Trucks
Engine won't start
Check to make sure you are getting voltage to the small post on the starter solenoid when the key is turned to the "crank" position. if so, check all of you connections on the battery cables. If your connections are all good, your cables are in good shape, and you still do not get the starter to crank, I would have the starter removed and tested.
Apr 21, 2013 | 2004 Toyota Tacoma
Changed coils on Harley now it won't start just pop or small backfire!
Please remove sparkplugs and hold them on engine connected to cable and check for blue intense spark on both plugs after that when connected and if the engine still does not start if possible please try with a new set of sparkplugs maybe that should do,all provided the coils are engine specific, wish you good luck
Feb 22, 2013 | Motorcycles
2003 lexus es300 won't start... radio lights and windows work. Tried a jump start, still doesnt work...
Are you saying the engine cranks but won't start, or the engine won't crank ?
If the engine does not crank, you would check for voltage at the starter, the neutral safety switch, and the key switch as well as the ground connections.
Sep 18, 2012 | 2003 Lexus ES 300
My 2005 xb won't start and when you put your foot on the brake it is tight and won't move
The tightness of the brake is normal. as the servo doesn't work until you run the engine. It could still be the battery as the radio only takes a small amount of power, whereas the rngine needs a lot more, get it checked by an electrician.
May 19, 2012 | 2005 Scion xB
Tecumseh 4.5 hp engine won't start
First thing to check on a Tecumseh; pull the half inch bowl nut (main jet) out of the bottom of the carburetor. Give it a good cleaning with carb cleaner then pay special attention to the teeny tiny hole that is right at the very top of the threads. It's so small you can hardly see it and if it clogs, your mower won't start. Best of luck to you.
Oct 29, 2011 | Mtd 22" Yard Machine Push Mower
I have a 5500 ppg generator that won't start. I've verified the fuel lines to the engine are delivering fuel, but won't start. I've been able to pour a small amount of fuel down the carb...
Hello, ushicks/me hillybilly. One question how old is the fuel in then generator tank,Hey. If it has a fuel filter replace it. Modern gasoline is junk fuel and after a few months it looses some chemical proprieties. GB...stewbison
Aug 23, 2011 | Northstar Generator 9 Hp, 5500 Watt,...
1998 Jeep grand cherokee Laredo turning over but won't start. It sounds like it wants to start but just won't power into it. We changed spark plugs w/in last year, brand new battery, the alternator...
When it sounds like it wants to start but won't, it is almost always a fuel problem. When you first turn on the ignition key (radio off, in a quiet setting) do you hear a faint 'hum' from the rear of the car? If so, your fuel pump is probably alright, so the next check it to remove the small, light green plastic cap (it might be black, about the size of a tire valve cap) on the top of the engine-it is part of the fuel rail and has a small pin in the center of it. With a rag in your hand, hold it over the valve, and with the key on, use a small screw driver and push the pin in-the rag will keep you from getting sprayed, if all is alright, but if you get little or nothing, you have a problem with your fuel pump, filter, fuel regulator or you may have a plugged 'sock' at the bottom of the tank.
Jul 19, 2011 | 1995 Jeep Grand Cherokee
I need to check the fuel filter on my victa tornado whipper snipper (2 stroke) but don't know where it is! I'd like a diagram, it's no use talking about 'fuel manifolds' or whatever...
The fuel filter is in the gas tank on the big fuel line. You can use a piece of wire with a small hook to pull the line and filter to the tank opening. These filters are available from small engine repair shops.
Jul 16, 2017 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
