Dayton 2x440 drum switch wiring diagram - Heating & Cooling
2 Suggested Answers
  • 108 Answers
SOURCE: Wiring diagram for a Dayton thermostat
Contact Dayton on the internet for this problem. The diagram should be available on their site. Or they will give you a number for customer care. They can give you step-by-step instructions. I am a technician and this is what I would do as their are millions of wiring diagrams. Many are noy up to date.
Ray
Posted on Dec 07, 2008
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
WIRING DIAGRAM FOR A DAYTON EXH. FAN FOR A GREENHOUSE. tHE FAN GOES TO A THERMOSTAT THEN TO ELECTEICAL BOX
So far, I cannot locate a wiring diagram for an installation. However, this is a single phase "shaded pole" motor.
For a single speed, shaded pole motor, there are only two power wires. For a dual speed motor, a third wire provides a second speed. One wire will be one side of the motor coil(s)...connected to the white power wire. The other wires are the opposite side of one or two motor coils, connected to the black power wire or through a thermostat. A thermostat is simply a temperature operated switch. An additional wire may (should) be a green "grounding" wire.
Specification Sheet from Grainger.
http://www.grainger.com/product/DAYTON-Exhaust-Fan-4C361
Installation manual.
ftp://207.99.53.68/array1/pacs/AS-BUILT/D1112-50-GLOBAL-Terminal&Container(15KV_ARC-RES-Swgr_Outdoor)/D1112-50-O&M/D1112-50%20Global/BM%20%23%20549%20Exhaust%20Fan.d20100210-u113426.pdf
Mar 23, 2014 | Dryers
Wiring diagram for Dayton IKRT9 portable electric heater
Sounds like it's the on/off switch.
what colour are they. . Usually one is the power supply to the switch and the other will be the return from the switch to the load.
Check these wires with with a multi meter.
Jan 06, 2014 | Kitchen Ranges
Wiring diagram for Dayton winch 4zy95 forward and reverse switch
Contact WW Grainger.
They own Dayton manufacturing
May 26, 2012 | Electrical Supplies
How to install a three speed switch on a dayton 5m188f motor fan?
Is it 3 wire or 4 wire ? And what color of wires are they ? If you look at old switch it should have numbers or letters to signify wire placement follow diagram from old to new and all should be good .
Jan 24, 2012 | Dayton (5M188) Fan
To palaboy: when you talk about a switch on the left most terminals, you mean with this switch im enable the timer???
Question is not clear.
You posted about Dayton on-delay timer?
This timer has two contacts, and wires similar to a light switch.
Connect 120V power to terminal 1
Connect wire going to load to terminal 3
Maximum Load is 1 amp so this timer should be wire to a contactor/relay and not directly to Load.
If you have Dayton off-delay timer, open following link for wiring diagram, and to see examples of contactors:
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
If you have a different timer, then add a comment with clear description of timer or in-focus photo of timer posted on Flickr
Jul 11, 2011 | Amperite Dayton Solid State Timer On Delay...
Is the button NC or NO? I have it currently wired this way but still it does not work and I'm using a switch not a button. Any suggestion?
The switch is OFF or NO normally open
See wiring diagram at following link
The way the timer works is this::
You click switch ON
When you turn switch OFF, the Dayton begins the timing sequence
The Dayton turns on the circuit going to load for 1/2 second => 5 minutes depending on model of Dayton timer
Grainger sells 120V push buttons if you don't want to turn the switch on-and-off each time
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=push+button+switch&op=search&Ntt=push+button+switch&N=0&sst=subset
http://www.grainger.com/Grainger/IDEAL-Push-Button-1XWT9?Pid=search
Oct 12, 2010 | Amperite Dayton Solid State Timer On Delay...
I need a wiring diagram for a farm duty 6k714k
It is generally located on the nameplate of the motor or inside the wiring housing where the outside power is brought in. These motors are usually convertible from 115 to 230 volt by merely switching a couple of wiring connections inside the wiring housing. If you can do so, 230 volt operation is much preferred due to the high speed start-up available and you can use wiring 1/2 the size required for 115 volt operation. Good luck!
Jun 05, 2010 | Dayton Audio Dayton 6K138 CapacitorStart
Wiring diagram for dayton ac electric motor
i need wiring diagram for a dayton electric motor 4mb22
Dec 13, 2008 | Dayton Permanent Split Capacitor Motor Fan
Ray
Dec 07, 2008 | Dayton (3E379) Heater
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
