Question about Cycling
Equus BC1020 odometer sensor
Programming
  • oatcakekid Feb 17, 2014
    What is your question?
Doesnt connect to pc
with Innova Equus 3130 live data software loaded to the pc
it needs the correct input cable
should work..... just push the right buttons on the scanner
https://www.youtube.com/watch?v=bEkQvg55ZYs
May 19, 2016 | Innova Equus 3130 Diagnostic Code Scanner
Reset speedodometer after replacing speed sensor 2000 mitsubishi eclipse
you may have to reset the cpu program with a scanner to cater for the new sensor.
Dec 27, 2014 | 2000 Mitsubishi Eclipse
I have 2003 tribute it has these 3 codes can anyone help U2098/Po7e0/P0100
Not sure about the first code. The second likely has some meaning to your code reader. The P0100 code, however indicates a problem in the MAF sensor circuit.
That could mean a dirty or faulty MAF sensor, a bad wire or connection somewhere, or possibly (though less likely) a faulty engine control module (computer).
Sep 10, 2014 | Obd2 Code Reader
2002 Mazda protege code p0117
OK i looked this up on my mazda shop manual an this is what is says:
DTC P0117 = ECT(Engine Coolant Temperature sensor) circuit low imput
-PCM monitors ECT sensor signal at PCM terminal 38. if voltage at terminal 38 is below 0.20V,PCM determines that ECT sensor circuit has malfunction.
POSIBLE CAUSE
-ECT sensor malfunction
-Short to ground circuit between ECT sensor terminal A and PCM connector terminal 38
-ECT signal and ground circuits are shortened each other
-PCM malfunction
Feb 20, 2013 | Equus 2002 Mazda Protege Obd2 Can Code...
Paint coming off side passeninger door
This is usually caused by chips in paint or salt damage if the vehicle wasnt in a accident or could have been factory flaw if it was never repainted
Dec 13, 2012 | Equus Scan Tool for 02 2002 Saturn SL1...
2011 equss sunroof inop all fuses are good ????
2011 Equus is still under warranty. Take it to the nearest Hyundai Service Department & have it diagnosed & repaired under warranty.
Aug 31, 2011 | 2011 Hyundai Equus
Need a user manual for an equus ace wired bike meter. I lost mine. Thank you D.G.M.
I have an Equus ACE and I am not sure where to put the sensor to get the proper reading on the spokes. Do I put it at the top of the spokes near the rim or towards the center of the spokes towards the screw in the tire?
Jul 18, 2011 | Cycling
I need to know how to wire up my equus model#6076 tackometer
The instructions should have come in the box with the tack
if not an auto supply shop can tell you but you will need to know the make and model of it.
Jim Hart
Jun 20, 2010 | Equus 6086 Black Tachometer Measures 2 12...
Cycling Logo
56 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
